SouthernIllinois
- Joined
- Jan 14, 2024
- Messages
- 1,705
Gotcha - if the HF website lists the tip size, I can't find it.Neither, for high build primer you need a 1.8mm tip and both of these, I believe, are only offered in 1.4mm for the purple gun and 1.3mm for the Spectrum.
In a former life, I did bodywork for a living. Worked in a high end shop. All our primer guns there were "bored out" Binks #7s. Used a drill bit to enlarge to tip. We didn't even use a pin vise...lolI've used an old purple gun for primer for 10+ years. I just enlarged the ID of the nozzle by hand with a small bit and a pin vise. Yes, I know not proper GJ procedure, you can't do that as it'll disrupt the flow and you need a $$$ gun, but it works just fine to spray primer.
Just found HF's parts website the other day, if anybody is inerested:...You may not be able to order parts today...
Thanks - bookmarked that for future referenceJust found HF's parts website the other day, if anybody is inerested:
