Thanks. I'm just a retired HVAC master of none type who needs to hire a GC. The
first GC Ive talked to wants me to have my draftsman draw plans so he can make a bid. I'm assuming I can take these drawings to other GC's for their bids, but which lumber/truss company they buy from is their decision. But Ive heard my draftswoman isn't certified, but "if she has a question, she will ask her husband", who I'm assuming is. Kind of sketchy, I know. But that's how things work out here in the sticks.. Like I mentioned, the
Iowa County zoning department doesnt even have a number. But you need to submit a
Pre-Construction Application.
I'm a draftsman. K. Not really, but I could be. I had some CAD training and have done architectural plans. Drafts people draw stuff. They're not engineers or architects. I think you're not going to get any help there.
100% the more definitive you plan is, the better the bids will be and are subject to less ambiguity. More detailed is better. 100%. Framing plans are a must, at least for me or the framers are going to throw stuff up willy-nilly.
I'm in the sticks too. I've seen houses built off "napkin plans" - people can do that. But if you want a wind-rated structure with a stamp, you're going to have to hire an engineer, architect, or a get a supplier with software to generate one. Maybe the same even if you don't need a stamp. There's a lot of "in between" especially in areas with no final construction inspection, but it may be the case that P&Z will want a "stamped drawing" - your application isn't specific about a stamp being required, just that they want "blueprints".
If you want to figure it out yourself, here are some resources:
1) International Building Code 2021
2)
American wood council (Frame construction for high wind areas)
Lots of this is building geometry limits, span limits, how you tie things, even down to how things get nailed or screwed together. I don't know these codes very well.
This non-enforcement has me concerned that whoever I end up hiring may take shortcuts is why I feel I need to know what the codes are for 115 mph. Im not going to insult any GC and ask them what the codes are, implying they may not know them.
I agree with you 100%! Better NOT to let them build something that doesn't meet a specification you don't know well. They build to plans, you specify the plans. That's the key with GCs and subs not to take shortcuts. If they have a major structural deficiency, do you think they'll reframe it at no cost? Not around here. Not a chance.
If you're going to do this yourself, why not contract wood and truss suppliers? Here GCs will absolutely use my suppliers. Take a TON of guess work out of it. Otherwise seems like you depend on a GC or framer to do it right, which is exactly what you're trying to avoid.
From what I can see Iowa Building code defers to a bunch of other construction codes, like IBC, and maybe not the current version. It's a lot of reading to parse out.
If I want to be my own inspector, Ive got some reading that gtae07 gave me to do.
I do not recommend you be your own designer and own inspector. You're already your own inspector (you're going to supervise this thing going up). I hired one of the adjacent city's inspectors who did some moonlighting... But you really want someone that is familiar with structural inspection / wind code. Probably not a generic small-town building inspector.
Your contract with subs/GCs should state phases of construction and that they are subject to inspection and PASSING inspection before final draw.
