gm engine/transmission cooler line tool
Mr.Nutcase
USA
Does a tool exist to help remove these annoying clips? I remember seeing something
midshipmen89
They're called Jiffy-Tite fittings.
I bought the above kit several years ago, but I've had limited success with them. They're more trouble than they're worth IMO; I've taken to using a 90* pick to pull the securing collar off and slip the clips off the fittings entirely. Makes for much easier removal of the pipe, especially on higher mileage trucks.
Firebrick43
West central Indiana
Small 90 degree pick takes them off in seconds. Just replaced my lines yesterday
The covers turn off counterclockwise easily with your fingers.
Beamer
Northeast
Certain jobs I farm out to our mechanic and that was one of them after I took a look t how blind the tubing connections were at the transmission. He charged just over $50 to replace the leaking one. Best money I ever spent. Much cheaper than the therapy the job could have caused.
2ndGearRubber
Pittsburgh
I believe 3/8 is the common size for cooler lines, although there are 4 Jiffy Tite sizes commonly available.
Picks easily remove them once you find the end, however reinstalling isn't always the easiest to get the wire section back in. Plus it can be dropped into the abyss. If the connection is being replaced, like a new radiator, I typically use a pick. If the clip falls into a void in the subframe boohoo. If I'm reusing I will resort to a pick last, a pair of Knipex Cobras can rotate the tool in a crusty connection. Typically that will fail only on aluminum connections which will fill up with corrosion.
xjfish
I personally prefer a pick, almost never use Jiffy Tite tools, although I own common ones. Corrosion is a common factor in MN. I save, and keep a plethora of spare clips.
Semi-hole mechanic
I replaced the motor in my wife’s Cruze and popped all those clips on the fuel rail loose with a small screwdriver. The bigger ones on the radiator hoses were done with a 1/4” screwdriver.
Firebrick43
I thought it was going to be a terrible job as well but removing the transmission passenger side heat shield (2 bolts) and then removing the bottom line first made it a really simple job.
