Riding Mower Battery Life
D
D45
NW INDIANA
I have an Group 26 525 CCA/715 CA automotive battery in my 18hp Briggs powered golf cart. Seems to be holding up great
I might look and see what a similar sized automotive battery would fit in the mower battery compartment
D
D45
NW INDIANA
I picked up a 350cca UL1 sized battery today at Tractor Supply
Old battery was stamped 5/2019
New battery is stamped 5/2025
Installed and started up immediately
$60 with tax
bunks-tj
Manassas Va
the battery in my cub cadet will be 6 in oct, and i have never done anything but drive the mower. no tender, no removal or disconnection :dunno:
T444e
The battery in the garden tractor is from 2013. The first 5 years or so were not good for life expectancy, there was no charging until I remade the wiring harness. I just ran it until it died and swapped batteries. I know I did this for 5 years or so as I was too lazy to find the charging issue. I also had a sprayer mounted on it with an electric pump that was used twice a year. I believe I had to swap batteries 3 times or so to get through an application.
kctgb
If you got 5 years out of it you did well. I’m on 3 years on my John Deer and will replace it this summer. I did a load test on the battery, it’s only at 35 percent. Time for a new battery.
dchawk81
Looks like its time to go battery shopping...…..I didn't realize that 5 years was a long life
Atleast they are cheap
They'd last longer if you didn't run so much local. Gotta run 'er on the highway more.
andyvh1959
Green Bay WI
I just use a Deltran or Shumacher battery tender and leave it plugged into the battery on my riding lawn mower. Always charged up and ready to go, and it keeps the battery active all the time.
Old Man Roger
Palm Coast Florida
I bought an AGM for my JD Z840. Got tired of the out gas and corrosion from the standard lead acid type.
R,
HAP
AGM is still a lead acid battery, it just has glass mat between the cells that encapsulates the liquid acid.
I do keep them on a battery tender during fall and winter when not being used regularly.
lasted 17 years, and it's hardly ever driven. Always have a battery tender on it though
on Battery Tenders off season in a semi heated garage. I keep it at about 45-50F. I got 10 years out of the mower
I use a good tender and seem to get good life out of my batteries. Had an AGM in my Harley that lasted over 10 years.
10.5 years!!
My secret is that I have a quick disconnect on the positive terminal with a wing nut, then attach my battery tender.
8 - 10 years on a Interstate battery, one lasted 12 seasons. Once I finish using a machine, I back it in the shed, shut it off and plug in a BatteryTender.
I've found that putting a charger/maintainer on a mower a few times a year, especially before you put it away for winter, makes the battery last a lot better.
I used to get two years of I was lucky. Now the battery in my mower is going into the sixth year.
Seeing a trend here.lol
I came to post the advantages of a battery tender on a battery that sits a lot, but I think the message has been made.
And for the guys putting water in their batteries, you’re diluting it. Almost all auto parts stores sell electrolyte/battery acid.
djbmw
Ottawa, Ontario, Canada
Thats not true at all. "Battery acid" is a mix of sulfuric acid and distilled water (a 50/50 blend is common). Over time, and especially in hot climates, the water evaporates, leaving the acid behind since sulfuric acid's evaporation point starts at 150 degrees.
Filling up the battery with new battery acid will over concentrate the mix and is the wrong thing to do, unless you've flushed all of the cells before hand. Instead, using distilled water and givong the battery a good shake afterwards will yield the best result. You can also use a battery acid tester if you're worried.
Bert_
NW Iowa
100%
Old Man Roger
Palm Coast Florida
Not what the battery rep told me, but they do sell electrolyte too, so maybe he was sales pitching? Or he just didn’t mention getting rid of the the old and replacing it with new.
dchawk81
$60 with tax
Sounds like the mower is timing out. 😂
LowOiL
Heat kills batteries here in the South, you discover it usually in the cooler weather, but it is the heat that kills em.
Always wondered about just hooking up a car battery to mower if that would make a difference... but even car batteries don't last long down here.
pcmeiners
As to buying batteries, look at the manufacturer date. Home depot has batteries on the shelf that are 2 years old.
On my cub cadet I disconnect the dumb head lights.
For the season startup I used the battery recondition setting on my charger for my 2 year old mower with a dying battery, worked, the battery has a new life. When I replace it I am going to get a larger battery at a non rip off price.
djbmw
They're not "dead",.. just low on water. Top off the cells, give them a shake, charge, and be on your way.
Now...if you dont catch this in time and keep trying to charge a battery that's low on fluid then yes, you can kill it with Sulfation.
Batteries "die" one of three primary ways:
1) Sulfation (most common)
2) Freezing (and the damage that occures from expansion)
3) Physical damage
If you prevent the above three, your battery sill last many decades (though, over time, damage will inevitably happen from plastics degrading and sulfation slowly building on the plates).
andyvh1959
Green Bay WI
My dad used to be his own battery tender. Back in the 70s he'd take "dead" batteries, charge them, discharge them with a small 12v bulb, then charge again. Charge, discharge. And he'd get a free battery back to life. He basically was doing what a battery tender does.
dchawk81
3) Physical damage
What causes death from full discharge?
djbmw
Sulfation begins once the voltage in the cells dips below 12.4 volts. The lower the voltage, the more aggressive, and expedited, the build up will be.
Also, temps above 24 degrees celcius, and below -1 celcius will begin sulfation.
dchawk81
Okay. I accidentally left a vehicle running, it ran out of fuel, and then the battery died from the switch still being on overnight.
Wasn't a super old battery but wasn't particularly new either. Couldn't get any charge back in it so traded it.
Didn't know if that would be something other than sulfation.
Is there a charger out there that can rejuvenate that?
djbmw
It depends how bad the plates are.
You can drain the fluid and look into each cell with a flashlight to see how the plates look.
Battery reconditioning is generally done by applying a very high amperage current to the battery (80+amps) with the caps removed in an attempt to remove the sulfate crystals. You only do this in 5 min bursts though.
The "reconditioning" off the shelf chargers dont do a good job as they are relatively low amperage. This is where high amp car starters and DC welders can come in handy.
dchawk81
Gotcha. I've been thinking about getting a higher amp charger to handle my semi truck but still haven't. I only have one of those hand carries that maxes at 50 or thereabouts.
liliysdad
The battery that came on my Hustler in 2015 died last year with zero maintenance, and stored outside.
Nine years. … I do not expect it’s replacement to be nearly as good.
Toolfool
Columbus, Ohio
My JD lawn tractor is over 20 years old and I'm about 10 years into my second battery. No tenders or special treatment. But, living in the PNW and now Florida its "down" season is pretty short.
LowOiL
3) Physical damage
In the South, one of the first things we learned was to check battery water levels... It ain't that. There is a reason batteries have a shorter life span in the south (not Canada)... Heat scientifically kills batteries. We have weeks on end where it is around 100 degrees and hotter than that under the hood.
Car batteries typically last three to five years, according to AAA, spanning from 58 months or longer in the farthest northern regions of the U.S. to less than 41 months in the most southern regions. Inspections should be part of an owner’s routine maintenance, but it’s especially important to check before taking a long road trip.
jhendric
This is an interesting thread. Apparently I've been very lucky with car/truck batteries and very unlucky with Tractor/Mower batteries. I wonder if AGM batteries on Lawn Mower and Tractors will help? At least I won't have to wonder if it's my fault for not adding water.
2 of my cars are 2015 Toyotas with original batteries, I am burning through a Lawmower battery annually on my JD x350 and My Kubota is about 2 years per battery now.
nadogail
Coronado, CA
There are many variables that affect the service life of batteries.
Some batteries can be repeatedly deep cycled and others not, your recharging system is also crucial to a long life.
Batteries are often built to a price rather than to a quality. Cheap batteries may have thinner plates.
You may have local a Buttery Shop that can give you better assistance than some well meaning, but uneducated, people on the internet.
racer8432955
got a FVP brand battery from Menards. I'm on my 2nd or 3rd summer with it. best luck I've had so far with this 15yr old mover.
I don't expect it to live much longer based on past experience.
I take them out in fall and trickle charge in the basement occasionally.
Crazyjake8493
Upstate NY
I'd have to check my notes but I think I usually get 5-6 years at least from them, likely more. Current one is 3 years. I used to use the Wheelhorse for snowblowing as well, but since buying a tractor the mower battery comes in the basement for the winter.
