Finally back to work in the shop My C.O.E.
D
don long
southern california
Time sure goes by quickly, as I look back to the last time the old truck was in the shop.
Well today is the start of another round of work on the C.O.E. My SIL is here for a week to help push this project forward.
A couple years ago I got the grille bars chromed but then put them away so not to loose them before putting them on the truck . Problem was that I forgot where I put them. I found them by chance last week so I put the truck back in the shop and invited my SIL to come back and help me get this old bomb running now that I have the motorhome frame under the body with all the running gear (motor, trans and rear end ) together.
D
don long
southern california
Everything starts out with good intentions. Today we managed to put the bling on the motor while we wait for the wire harness to arrive.
With some down time today Rob (my SIL) and I started studying the truck more closely and discovered that the steering has an alignment problem and it was agreed that a Rack and pinion system would be the best solution for the problem. Then we moved our attention into the cab of the truck where I had welded in a 4" square tube to raise the floor hoping to get a little more leg room. After setting a seat into the cab it became obvious that we have a serious problem with leg room.
We settled on the solution of repositioning the motor lower and further back under the cab. So tomorrow we start tearing the body back off the frame
xtremek
St. Johns, Mi
Funny timing. I'm getting all the big pieces to mine finally together. I'm hoping before the summer gets here to start it. Please keep this up to date so I can steal some ideas. Like what's the plan for engine access when it's all done?
D
don long
southern california
Today was a very productive day out in the shop. We started at 7A.M. and quit at 7 P.M.
We started by pulling the cab off the frame.
Then the motor came out and the steering box was removed along with all the exhaust, gas and brake lines and several brackets were cut off the frame
With the motor out the mount brackets and Trans X member were retally available The goal here was to move the motor back 20 inches and drop it down 8 inches.
The trans x member was our first target. It was bolted to the top of the frame so it got unbolted and moved back 20 inches and bolted to the lower lip of the 8" frame rails.
Next was the motor mounts. They too were bolted to the top of the frame rails and also supported by the suspension cross member. Well they to had to move back 20"s and dropped down to the lower lip of the rails and we started building a support x member to add support for the motor.
We had to mount the motor back into the frame after moving the mounts to be sure that everything lined bak up and could be rebolted into the frame.
The motor looks much lower now so tomorrow we will remount the cab and see if we gained enough leg room
Before
After
jbmatth
Northern Ok.
WOW is not a strong enough word, when you said you were moving the motor back and down I expected it to be an inch or two in either direction. I would have never guessed back TWENTY inches and down eight, that is mind blowing. Hopefully it nets you what you need and once again I love this project.
JB
D
don long
southern california
Put the cab back on the frame this morning to check for more leg room and we did get a bunch
It looks like the motor will be below the floor and the carb will fit in the console area
After some long discussion we decided that the cab needs to be sand blasted before we start welding the floor braces in so now the cab is back off and the fenders dissembled and ready for the mobile sand blast co. To show up on Tuesday
Max Power
Lakewood Colorado
I'm blown away with the idea of a mobile sandblaster. But with your experience in the industry you must know a talented person. 40 years ago I was helping on a 53 Ford sedan delivery. It had some light rust / pitting. We peeled off the door skins and a blaster cleaned everything up and we reinstalled the skins and skimmed the pits with lead. It was the only job I ever saw that didn't get warped and was honestly metal finished with no plastic. (I was helping, not my skill)
drivesitfar
Nice work as per usual. I’m looking forward to seeing this big old COE finished but I think I really want to see a thread on your 56 if you put that big engine in it even more.
Hope all is well in your world and best of luck with all the things that you do!!
garagenvy
Change the plugs/cap/rotor/wires before you put the cab back on ;)
Enjoying the progress!
+1 - A friend owned a Bizzarrini - Italian body, Chevy 327. There was a cover on the top of the dash you changed the points through. The second time he asked me to change them I insisted we put in a Pertronix electronic kit.
D
don long
southern california
Finally got the phone and computer together so I can post pictures again from the computer files
Been working on cleaning up the C.O.E. cab, removing the rusty metal and covering the nasty spot welds and repairing dents all around the cab.
Finally got the cab into the booth tonight for a good coat of epoxy primer in the morning
Next I went to work stripping the paint off sleeper
Model A Fan
NW Washington
Before
After
The Mobil sand blast guy finally showed up this morning after standing me up 3 times over the past weekIMG_8480.jpegIMG_8483.jpeg
Two questions for you...
What does that engine hoist look like? It has probably lived a long life and looks quite weathered with patina. I'm just curious as it has lots of character and probably has seen a lot of projects.
Second question...
After sandblasting, how do you prep the body for storage if you're not able to paint it right away? Do you clean it with anything to get the dust off? I live in WA State where we have plenty of humidity, and I'd like to get a WWII Jeep body blasted, but don't have the ability to paint it right away unless I transport it to someone afterward. I'd be trying to avoid flash rusting as well as trying to put in patch panels. I'm just curious what your process and advice would be.
Your COE is pretty sweet.
D
don long
southern california
Well M.A. Fan
The engine hoist is nothing special, just an old snap-on hoist that sits out in the weather until it's needed.
I brought all the sand blasted pieces into the building out of the weather while it waits for some attention. I started with the truck cab and ran a Dual action sander with 80 grit paper on it before spraying an epoxy primer on it. I will follow the same procedure with each piece. I may do a little body work on those pieces prior to priming.
The cab is done for now
Model A Fan
NW Washington
Well M.A. Fan
Thank you for the information. I have a project I'd like to do, but my weather window is very short in NW Washington. The 80 grit sanding is to remove any burrs? I assume an acetone wipe-down is also part of the process? Is there a timeframe after blasting the bare metal should be coated to prevent flash rusting or will it happen almost immediately due to the wet sandblasting method used? I found a local guy who does mobile dustless blasting and would like to know a "best practices", and you've done a great job with yours. I had only mentioned the hoist earlier as the patina told a story of work and quality.
D
don long
southern california
I didn't use any acetone and surely would stay away from wet sand blasting. Here in So Cal I have pretty dry weather so my window before rust sets in is pretty big. A little surface rust can be scuffed off minutes before priming.
Model A Fan
NW Washington
Alright, I appreciate the insight on wet blasting. I thought that you got yours wet blasted, hence the mobile part. I don't know enough about the setups to tell that yours was done dry. Everything seems to rust quickly with the moisture in the air up here. Not rust out like in the Northeast, but surface rust isn't uncommon if you have bare metal. I may not even get to the body by the summer this year. I have an engine to get machined and (maybe I will try to put it) back together. Thanks again for the info, I'm always trying to learn and improve my knowledge.
