Pole Barn Window Replacement?
rpenterics
SE Michigan
Hoping someone can help, I have 3 of these windows in my shop that need to be replaced - what and how is the best way to do this?
20250515_185331.jpg20250515_190738.jpg20250515_185418.jpg20250515_185325.jpg20250515_185315.jpg20250515_185308.jpg20250515_185302.jpg
jack stand
Lakes Region Maine
You're need to pull the surrounding panels. That sounds drastic but the windows are nailed on first, before the metal and the 2-3 panels involved with each window can be removed in under an hour.
Buy new screws before you start. 👍
Bennylava
Cleburne, TX
What's wrong with reusing the old screws ... 😁
R
rpenterics
SE Michigan
Is there a certain type of window that I should be using for replacement? How do I make sure it's not going to leak? Windows are not something I've ever dealt with
BobnCO
Those are not flashed. Google how to flash windows and doors in metal buildings. Menards and the like have the flashing in several colors (there should be a brochure there to illustrate.
jack stand
Lakes Region Maine
That's a huge effort for your type of building that includes lots of expensive tape, flushing and a building wrap or drainage material that diverts any water that gets behind the siding will make it's way down below any framing.
For the most part it wasn't a consideration for a "pole building". I'm speculating that the thought process probably involved the fact that the framing for the windows/doors was incidental to the structure and only provided support for the window (not structural) and is exposed and able to dry freely.
mikedodge
Look at how they are installed. They aren't always behind the panels. At least your panels look easy to get off, mine has soffits over the tops of them.
R
rpenterics
SE Michigan
Well, I'm into it now, pulled the steel - surprisingly tough with 50+ yr old nails
found the wood around the old window to be in really poor shape and not well secured
R
rpenterics
SE Michigan
Started framing back
Bought an economical window from Duo-Corp via Amazon, mostly because it had integrated J-Channel first one arrived with the nailing flange broken
And ReGrip Screws from Jakes Sales also via Amazon - specifically for replacing nails, oversize washers
Hoping to get window installed and steel back up both with a healthy dose of Lexel this weekend
R
rpenterics
SE Michigan
Got the rest of the framing in
Went slightly bigger, old window was 18x36 new is 24x36. Unfortunately no in progress shots as I was fighting caulking and "sliding" the steel back into position.
I've got a couple more screws to put in but calling this done,
