Caa311
Virginia
I have had the standard set in my cart for awhile. It comes down to that price often but I don't really need it
ching0n
I've got a big kit of cobalt bits that I cracked open recently to go through some tool steel. I was so thoroughly impressed that I'm ordering a few smaller kits to keep around the various drills. I'm not sure how well they work in hand-held drills being that they're super hard and likely brittle though:
6$ 16 pc (note; only the 1st row of bits is cobalt; also metric, vendor also has an 8$ metric w/steel index for 10% off when combined):
8$ 13 pc; imeprial:
9$ 13 pc ruggedized case:
another imperial:
10$ 13 pc w/steel index & 10% coupon; imperial:
Another imperial steel index:
I ordered 3 different sets. 2 just got here (the metric and the "rugged case" one). The drills are indeed stamped or lasered w/SSCo on them, I ran the 3/16/4.8mm @ 750rpm and they punched w/o issue on 1/4" mild and SS304. I compared against an HSS/HF warrior cheapo that struggled (though it may be blunt) and a HSS USA made one that also got the job done but not as fast. I ran all bits w/cutting oil b...even though one got 'blue hot' (I skimped on the fluid and was going fast) I didn't feel it slipping or chirping. Both bits ran true to my eye.
We'll see how long they last but AFAIK, you can get true cobalt bits for a bargain in 2025. Also, although the "ruggedized" case may look the part, it really is not, it's thin plastic and the holders are even thinner blow molded plastic. It may do a better job of keeping the bits in place while on the go but I don't know about long term. The metric metal index ones I have no complaint about and the Co is stamped instead of lasered which may wear out.
edit: I chucked them all on a hand drill and run out looked good on all (Much better than the last 10$ HF set I got :D). Lastly, Cobalt is one of those 'conflict metals' that I'm not sure with deregulation we are caring much about ethical sourcing, but I definitely don't think the Chinese are.
edit 2: the third set came in. This one's not stamped or lasered cobalt (5th in the list), has the typical titanium oxide gold coating instead of the darker straw color of the other two. From what I understand the color isn't indicative of much since cobalt bits can be coated. It just says HSS but did a decent job punching holes on mild and stainless. The box has HSS4341 on the case (and a "cobalt" qrl) which denotes a "budge friendly" HSS steel that's softer than cobalt alloy. I may or may not return since they performed well but I'm not thrilled about the potential false advertising and overpaying.
edit 3: I'll be returning the above and ordered these:
edit4: I tried drilling SS w/a hand drill and started well but chipped one cutting edge for one of the sets (9/64"). These bits may be too hard to hand drill when not perfectly straight. I can sharpen of course but won't get the 135 deg double grind. Maybe the larger bits are fine?
also found these
9$ https://www.amazon.com/dp/B0D9JPHMCK?tag=atomicindus08-20 13 pc metal case
10$ 15 pc plastic case; vendor also carries 13 pc metal case. This set has repeats of the smaller bits and skips some of the medium ones but adds 2 larger ones.
PugetDude
Superstition Mountains, AZ
I'm a Prime member and I don't see the coupon box either...
An algorithm determines whether or not you need to be offered a coupon, based on your order history. Have you ordered similar items in the past, and at what price point? Have you selected similar items based on delivery dates? Will this be a one-off purchase or do you buy similar items frequently? Sorry, Bryson but we don't feel we need to entice you to buy this item with a coupon. We predict you will buy it (or something similar) anyway.
ching0n
ching0n
Looks like a complete plastic junk. Besides, the title shows 2200 lb capacity whereas, based on the description, the total capacity of all four wheels together is 1100 lb (which is a wishful thinking anyway). Maybe it would work for a chair or nightstand though.
I have a set from the same vendor I paid 42$ for on ebay. Die cast aluminum body, some hard durometer PU for wheel. No comment on durability since it's a lathe table project in the back burner at the moment. Individual on ad lists them as 275lb/per, so I'd go with that to be on the safe side. Packing was flimsy so may have lost a nut or two....metric if I recall.
I want to see if this will work out as a layout fluid/applicator. Good option to cover your envelopes/recycling before you toss it too.
Cruzan80
Denver, CO
The 2.5" shows 550# per caster, so you have the 2200# overall (theoretically).
Is there an easy way to drop these onto the wheels and then move them back to stationary, or do you have to "re-level" each time you take it off the casters?
ching0n
I thought I saw the listing as 2.5" & 2200# but it must've been a different vendor. I dunno why these guys opted to "double" the specs in the title...
Think of them like race car on-board jacks. The load gets jacked and wheel lifted off the ground and if you need to roll, you gotta ratchet the jack short. I guess to answer your question, I don't think there's an easy way to relevel unless you mark the floor where these go and mark the landing pad at the housing level line (red lines below). Vendor carries this cheaper one but same principle.
Cruzan80
Denver, CO
Yeah, was really hoping for more like the old CM ones I have (not the same weight rating). You lower the pad to where it is on the feet only, and when you want to roll, you step on a lever which has a J channel. When it gets to the (left) end of the J, the wheels bear the weight (it lifts the pad as you push down on the lever). At the top of the J, wheels are retracted and it sits on the feet. Adjust once for needed travel, repeat swapping back/forth as needed.
These seem like the wheels are for the rare occurrence, and then you spend a bunch of time re-leveling once you get it in position. Though I guess you could "count" the ratchets down and then back up?
ching0n
I think the one's you're talking about are like some I've posted before but they jut out increasing the floor space (image below)? You still gotta relevel if not moving back to the same location right? I'm not sure I understand how this wouldn't be a problem unless returning to the same spot.....
edit; I think I understand what you mean. You level the machine's/table's feet, then rely on the lever casters below to move and when it's back on the same spot, you drop them on the preset feet. They make these removable, so only the receiver remains on the machine:
ching0n
this was a bit of a fail (the intent; not the product). The rollers do a good job of covering completely with a few rolls and come precharged w/black. Both the black and blue ink is a bit "waxy" though which dries fine on paper but remains wet on an impermeable surface...makes sense since you wouldn't want this to dry while sitting unused. I haven't hit it w/a heat gun yet to speed up the drying but at that point, a fat blue sharpy or buying dykem is the better option. I think dykem is likely alcohol/acetone based w/a shellac mix so dries fast and hard. The lacquer surface makes the scribe pop as it chips around the scribe making it bigger. W/this stuff the line is super thin & hardly visible since you're cutting into "oil"
I'll have to find my can of purple PVC primer and give that a shot. Anyway, you can get twice as much volume of the original as my experiment for 11$ or 9$ shipped from walmart or zoro or 4x as much for under 20$; hindsight and all that.
https://www.amazon.com/Layout-Fluid-Steel-Red-Dykem/dp/B007IAVMMU/?tag=atomicindus08-20 11$
https://www.walmart.com/ip/Dykem-80396-Steel-Red-Layout-Fluid-Brush-In-Cap-Bottle-4oz/ 9$ if you buy 2
https://www.amazon.com/gp/product/B00BXT3ZWW/?tag=atomicindus08-20 18$
https://www.amazon.com/gp/product/B007464BQM/?tag=atomicindus08-20 17$ < under other sellers box
njc41980
Idaho Falls
Ohio Andy
Columbus, Ohio
Anybody need a set of cheap SAE wrenches.
These are the Facom pattern that I like, and for ten bucks, they'd make a great set of emergency travel wrenches if nothing else
The ratcheting version is $20
Etchase
Hawaii
I bought a set over a year ago. Plating has held up perfectly. The open ends measured 0.005 over maximum. Makes a great gift. I gave mine away for Valentine’s Day. lol.
pbon
Thanks vwpieces — those are useful wire harness disconnect tools for later model Euro cars. I already had the curved one so now I will have the straight as well.
tarbellb
Oregon
Nicer comprehensive Deutsch connector set- $99 usually hovers around $140
IWISS DEUTSCH DT Connector Kit in 2,3,4,6,8,12 Pin Configurations, Size 16 Stamped Formed Contacts(AWG 14), Wedgelock & Pin Extraction Tools, Ideal for Automotive Aftermarket Service, 519PCS​
Chuckster in NJ
Hunterdon County NJ
I have a similar kit and it is handy for wiring repairs instead of splicing wires……. I have used it for working on pinball machines and cars instead of soldering and crimps.
ching0n
Picked up crimp tool. Here's another pair of those pliers for a buck less & some other shapes that appear to work on fuel lines too:
if for some reason you need 6mm heim joints (I did). SAE or other sizes are available too at maybe 2x the price ; just an fyi...also don't expect critical application quality:
