Innovate1
I have this valve in my water system that has a very slow leak around the stem. It isn't wet but has some rust as can be seen. It also leaks very slowly into the downstream side when off. I see a hex under the handle that looks like a packing compression nut (I guess nut is the proper term?). It would take a thin wrench to tighten without taking the handle off but easy with the handle off. Before I give it a try I figured I would ask here. Anyone done this on this type valve? Could tightening the packing stop the downstream leak? Thinking it might leak around the packing to get to the other side. Or am I likely to just need to replace the valve?
