The Official Reedsman thread. Reed made craftsman’s
AngryBeaver
Lake Milton Ohio
With the extensive research on my reed thread, I figure it’s time to put together a Reedsman thread after seeing a lot of wrong information on the social media platforms. This will apply only to reed made craftsman’s from 1943 to 1948/49
There are no tool catalogs from 1943 or 1944 that I can find. If anyone has any that list the vises, please, by all means post them up. This will be an ongoing updated thread. As if right now, an august of 1943 dated craftsman is the earliest on record and am early 1949 is the latest. I’m guessing that one was a leftover as 1948 brought the introduction of the rock island made 0519X series.
The only craftsman’s made were a 3”, 3-1/2”, 4”, 4-1/2” and 5” in both stationary and swivel models. The model numbers are as follows. There were all R series reeds.
5179 3” four bolt stationary base same as a 103R
5180 3.5” four bolt stationary base same as a 103-1/2R
5181 4” four bolt stationary base same as a 104R
5182 4-1/2” four bolt stationary base same as a 104-1/2R
5183 5” four bolt stationary base. Same as a 105R
5184 3” swivel base same as a 203R
5185 3.5” swivel base, same as a 293-1/2R
5186 4” swivel base, same as a 204R
5187 4.5” swivel base, same as a reed 204-1/2R
5188. 5” swivel, same as a reed 205R
Like most brands, the largest and smallest are hardest to find. As far as I know, the 5188 is the only 5” swivel base to surface in the last 3-4 years of searching. Quite a few 5183’s have surfaced. The 5184 (3” swivel base) is one of the more common ones, yet the 5179 seems to be pretty elusive also. None are “easy” to find. I would love to know the actual production numbers, as they were only produced for 5 years, and half of that during the war.
This was from a 1945 catalog. The 5179 is not listed.
There were a few changes from the introduction to the end. 1943 to 1947 models will have a meatball spindle and original color is a deep blue with a hint of violet. Starting sometime in 1947, they switched to a hockey puck spindle. With this introduction, the underline cast in logo was replaced with a metal heritage badge attached with brass drive screws. The color was change as well, to the 1940’s greenish grey. The hockey puck spindles are approximately 1/2” longer that the same model meatball spindle. Reed made this change sometime in 1947 and offered better stability, as the longer spindle would offer full thread engagement of the nut when the back of the slide was flush with the back of the static jaw. The meatball spindles only had half the nut engaged when the slide was flush with the back of the spindle.
The 1943 and 1944 models will have a cast nut. Sometime in 1944 they switched to a steel nut. I’ve had quite a few 1944 models, both with cast nuts and steel nuts with date stamps all over the place. I assume this was a running change based on using old stock first.
This is the earliest dated reedsman on file so far. 8/43. This 5180 (103-1/2R) had been repainted when I got it and the marks were very lightly stamped. This one had 1/4” stamps, where as most of the 1944 and 1945 stamps are smaller 1/8” or 3/16” stamps. I assume this was to help disguise them as I have never seen the smaller stamps on any reed branded vise. Every reedsman I’ve had has had the date stamp on the non logo side. Both on the static and dynamic jaw. This was done for warranty purposes. It’s either 3/43 or 8/43, but I believe it to be an 8.
A
AngryBeaver
Lake Milton Ohio
This is Barts 7/44 dated 5184
This is my 1/45 dated 5185.
A
AngryBeaver
Lake Milton Ohio
Here a a July 1947 5187. 1947 is when the hockey puck spindle came as well as the heritage badge along with the greenish-grey color that would remain until production of them was stopped.
Here is an 11/48 dated 5184 (don’t remember whose it was)
A
AngryBeaver
Lake Milton Ohio
5/44 dated 5183. Lots of color left on this one. Cast nut on this one.
Huntsfromtree
Missouri
I never was able to find much info on the craftsman reed manufactured vises with the metal tag. But you answered several of my questions. Anyway, here is my 12/46 dated No.5188.
Hoorn
Glendora, CA
Congrats AB on getting the 5183. Here is my Reedsman dated May 1944. I included pics showing the tight tolerance and fit of these awesome vises. The PDF is the original Patent request by Thorvald Petersen in 1936 to "eliminate the slack in vises as commonly made which very materially adds to the effort of the workman in the operation of the vise"
Patent No 2127008 that Reed saw fit to cast on their R models. all that Patent covers essentially is the main screw pin with a notch and a set screw in it.
This very day I bought 3 slightly different cans of blue spray paint to finally finish my 5183, and then I saw Angry Beavers most recent post of a Reedsman with a lot of original blue left and realized none of mine were that close. ABs past description of deep with violet seems spot on. Anyway, here it is.
  • 0.pdf
A
AngryBeaver
Lake Milton Ohio
Rustoleum satin navy is the closest off the shelf I've found. Rustolem's 2x satin midnight blue is close also. short of finding a mint one, and having the paint scanned, i don't think we will get a spray can to match spot on.
I find it ironic that your 5/44 date 5183 is the same date as mine, and the same cast nut, yet the 1/44 5182 is a steel nut.
MattGavriloff
Escanaba, Mi. South of Canada...
Just wanted to add, there must be some overlap with Rock Island before the 1948 date mentioned in the first post. I have a 5160 (Rock Island 571), that is slide dated 6/46. I also have a 5162 with no slide date, but i dont know when RI started or stopped dating them.
Not contradicting anyone, just adding to the info. Nice 'Reedsman" vises in here for sure!
Would that make mine Rocksman? Islandman? Doesn't flow as well for sure.
FARMAN33
Here is my 1944 5187. Led a pampered life it seems. Jaws still sharp and handles nearly unmarked. A true survivor!!!
Dlavallee22
East Bridgewater, MA
Here is an awesome recent find of a Heritage badged Reedsman 5184 3” jaws with date stamp of 3/46! Earliest Iv ever seen or found anywhere for a complete R series with the hockey puck meatball and it’s in absolutely great shape. Also does not have the dark blue paint and has some of the lighter grayish paint that Reed changed over too, just looks a little dark with the BLO over it
A
AngryBeaver
Lake Milton Ohio
Nice score and an update for the Reed and reedsman timelines. Really makes you wonder…. Yours looks very dark with the blo on it. I’ve only had two Grey reedsmans and it was reminiscent of the wilton grey of the 40’s as far as the hue goes.
Dlavallee22
Here are pics of how I got it. Someone clearly started cleaning it with what looks like a coarse wire wheel. Def shows the color better of the original paint before I put the BLO on it
bikebuilder
California
If found this 5180 in someone's garden caked in sand and rusted almost solid. I've got it dismantled and hope to have it operational and mounted to my bench soon. Definitely had several layers of paint, so I think I'll be redoing it after I get it cleaned and the rust removed. From the faint markings it looks like the stamp either says 1943 or 1043. From reading this thread I'm guessing the latter indicating October 1943? but I'm hoping someone here can confirm it.
bikebuilder
California
Managed to finish the restoration and get this mounted over the weekend. I've never done one of these before and I'm pretty happy with the results. I know the color choice is probably blasphemy, but as it's going in my shop, I went with what made me happy :).
Tom99
Some really nice vises in this thread, and excellent information from Angrybeaver.
Just wanted to share a nice 5186 I picked up last week at an estate sale. The first picture is a screenshot of the video they posted advertising the upcoming sale. It was amusing that the lady narrating the video pointed out the "tool bench with lots of new tools".
Anyway, I got there early and waited to get in, out in the cold, hoping it was a Reed. I was pleasantly surprised to find a Craftsman Reed in very nice condition. I think with Craftsman tools, being a brand targeting homeowners, you can sometimes find examples that were somewhat gently used, rather than beat to death in a commercial shop or factory.
Shiftless
East Bay SFO
I am excited to inform the group about this early 5182 I found on Craigslist and brought home yesterday afternoon. The 40 ish seller inherited it from his father but he didn’t need it so he sold it.
I looked it over carefully and couldn’t see any obvious damage but the thick speckled paint job might hide something minor. The jaw teeth are in excellent condition. Even the handle was painted black with a glob of paint preventing the handle from sliding through the nose all the way to one end.
Is the color of the vise posted 2 years ago (post #12) by Farman33 considered to be the original factory color?
Dosstramp
England
This site has been really useful. I live in the UK and picked up a bench vise from a flea market many years ago.
It cost me £5 ($6)
I knew nothing about bench vises at the time though I've got a collection of Leg Vises (Post vise)
I came across this site when doing some research.
My vise is a Reed 204 R
No problems with it after many years of use.
Joe-T
Hi All,
First, I want to say thank-you to everyone that has contributed this Reedsman vise thread. Such a great source of information!
A few months back I found a Reed 204R vise that I restored to use as my main bench vise. I really like that vise, but I decided it was just a bit small for my needs, so I had been watching Craigslist and Facebook Marketplace since then for 4-1/2” or 5” Reed-R series. It wasn’t until I found this thread that I learned about Reed made Craftsman vises. Just last week, I was lucky enough to find a Reed-Craftsman hockey-puck 5188 (dated 12-46) on Facebook Marketplace. Other than missing the heritage badge, the vise itself was in great shape, with the jaws showing very little use. The swivel base was missing one of the mounting tabs, but I figured I could fabricate a replacement. It wasn’t until I sandblasted the base that I discovered another mounting tab was cracked, and would need to be repaired.
I've included a few notes about my restoration/repair process in case others might need to do something similar:
I made the reproduction heritage badge using a water-slide decal that I printed on an inkjet printer, using an image that I found on-line. I applied the decal to a 0.8 mm aluminum plate that I cut to fit the recess on the vise body. I then topped it with multiple coats of clear acrylic, and attached it to the vise with two drive rivets.
The replacement mounting tab was cut from 1” thick, cold rolled mild steel flat bar. After cutting it to shape, I ground it down to approximately 7/8” thick to match the height of the three existing tabs. I enlarged the crack on the damaged mounting tab (top and bottom) with a carbide burr in a die grinder. The base and replacement tab were pre-heated in a small toaster oven to 400 degrees F before brazing. I MIG brazed the crack and replacement tab using silicon bronze MIG wire and pure argon shield gas. The assembly was then covered with sand to allow it to cool slowly. Once cool, I ground the repair joints smooth, and then filled imperfections with All-Metal two-part filler. Paint color is Rust-Oleum Smoke Gray gloss.
Below are pics of the before, during, and after restoration process.
Joe
mattyc603
Picked up this vise in Massachusetts yesterday. It came out of an old garage that sat vacant since 1991! Found a date code that looks to be 10/43.
Love this forum…
Matt
TacoKing
My neighbor just gave me a 5180 with 1043 stamped on it. His dad bought it new. My only question I have, is how do you get the main screw out? Also, what is the small screw below the “Oil” port for? I’d really like to restore this one and y’all have done some great work. Any tips would be greatly appreciated! Thanks in advance!
mattyc603
The small screw is a “ set “ screw for the larger main screw. At the front of your vise behind the “ meatball” there is a cast washer that as been split in half by design. With a screw driver, you’ll need to in thread that washer( which will come apart once removed) and take out the smaller screw under the oli hole. YouTube has some good content showing this.
Awesome vise my 5188 above your post is made the same month and year!
TacoKing
mattyc603, thanks for your quick reply and the info. I actually looked on YouTube before stumbling on to this forum, but I was looking for the wrong thing, and kept finding videos about 60’s vises and not this one, since I didn’t know it was actually a Reed. Now that I searched for Reed, I found a video with an identical vise tear down and rebuild, other than his is Reed branded, but it’s the same 3.5” vise I have. I’ll be sure to post it again after I tear it down, clean and freshen it up and get it back together. I’m really stoked about this vise because I’ve been trying to find a good one and have been watching and reading a ton of reviews and none under $250 seem remotely as well made as this one.
Thanks again.
TacoKing
Well I took her apart and gave her a good cleaning and degreasing. I used a couple coats of self etching primer, a couple coats of Rustoleum Midnight Blue Satin, then my wife did the letters for me, I chose gold to offset the blue better than I thought white would, and to make it my own. Then I sprayed a couple coats of semi-gloss clear on it. The paint is a little softer than I would like for a tool, but I think it doesn’t look half bad for a rattle can job. I’d gave every metal on metal part a good dose of Red ‘n Tacky grease as well and she’s as smooth as butter. I’ve hope when I’m 80 and a half years old I can move anywhere near that smooth! Great vise, so well made. I showed my neighbor who gave it to me and he was happy that I’m putting his dad’s old vise back to work.
682bear
West GA
Last week, I picked up a Reedsman 5180...
...after disassembly and some mild cleaning, I found what appears to be a 3-46 date stamp. Also, it has the 'puck' type screw instead of the meatball...
...but the backside of the 'puck' shows a joint between the puck and screw that makes me think it has been replaced ...
The mix of long C body, 3-46 date, and puck screw doesn't agree with a lot of what I'm reading about these vises.
So... do I have a mix master, or is this possibly original?
Thanks- Bear
Ry24000
CarWA
I just picked this one up this weekend. 4.5" jaws and a smooth operator. Check out the stand it came with. I wonder what the maker was using this for? The guy who I bought it from was gifted it from the PO. I put a third member from a Toyota land cruiser on it and it holds no problems. Really like these Reedsman's. I think I like these reeds better than my Wilton!
I am just going to run it for now until I get a 105.5 I have tore down up and running.
IMG_20250601_155041388_HDR.jpgIMG_20250601_155117361_HDR.jpgIMG_20250601_155124748_HDR.jpgIMG_20250601_173002188_HDR.jpgIMG_20250601_160747452_HDR.jpg
drivesitfar
RY: that’s quite the picture with your reedsman holding all that weight in its jaws.
I’ve always said I do love my old reeds and rock islands the best but the Wilton C series vises and bullets are not bad especially the older ones.
Mr. Wonderful
I saw that on MP. I'm glad it went to a member of the group!!
Ry24000
CarWA
IMG_20250621_081857783_HDR.jpgIMG_20250621_081928261_HDR.jpgIMG_20250621_081934884.jpgNeed that Logo now!
SoCal Vise
Hello,
New member, but have been lurking for years, spent my life in the toolmaking industry. Like a lot of people Reed Rs and Wiltons are my thing.
Regarding “There are no tool catalogs from 1943 or 1944”. I happen to find on the Archive site the Fall/Winter catalog from 1944. It’s essentially the same as the ‘45 catalog except for the Dunlap text under the vises. Just for completeness sake…if anyone cares.
drivesitfar
SoCal: Welcome to our group and a lot of us thank you for posting catalog pics. I had a couple laptop crashes so my vise pics and catalogs are in my head these days but nice to see them posted.
Did you post up any pics of your personal vises? Please do if you have time and follow along on the vise repair 101 thread to share some of that knowledge or maybe learn some more.
Have a grand day!!
