Retaining wall for garage site leveling?
Jetsurgeon
Orlando, FL
Hi, so building a 24x50 metal building (garage) in Central Florida. The building will fit, but will be about 3' in front of my well and pressure tank, seen behind the building location(planning on building a "lean to" to protect it from the Sun after the garage is built). The yard slopes about 24 inches from the front corner by the house to the side and back marked in Yellow.
My question is, should I have a retaining wall done for the Yellow area then backfill the area, or? There really isn't enough room at the back to just use fill dirt and slope it down in the back (at least by the well). Obviously being Florida, most of the "dirt" is sand to begin with, and I don't know if you can do that big of a turn down?
u2slow
BC
I had my shop built with a 3' stem-wall on one end because of the sloping grade.
Couldn't you have the building tailored/adjusted for the same thing?
andyvh1959
Green Bay WI
When I built my detached shop, its on an area that sloped up to a grade for my neighbors yard. I determined the slab level I wanted and put two rows of 8" block on the slab for a stem wall perimeter. That also gets the sill plate of the walls well above grade. I planned my walls for 8' finished from the sill plate to the top plate, and with the 16" of stem wall I have a floor to truss height of 9'-4", so if you did a three row 8" block stem wall you'd get 10'-2" inside. Depending on your struss designs it would almost be high enough for a car lift.
u2slow
BC
In addition to the 3' stem wall on the back, the rest of my shop has about a 1' stem wall; with reliefs for mand-oors and the OH door.
