Stone Pavers in a Cold Climate ?
Weedwaka
Anybody using stone pavers for your walks, patios, driveways etc in a cold climate ?
We would like to use paving stones for our driveway and walks. I love the look but I am worried about maintenance and the effect the ice and cold would have on all the seams. We get a lot of snow.
Gary S
Bismarck, ND
I built a couple of walkways out of pavers a couple of years ago. They are too new to know how they will stand up over the long haul.
I had over 8 feet of snow last winter and temperatures down to -44. The walkways show no damage or shifting yet.
sammerdog
West Michigan
My previous house had a pair of walkways made out of standard sized pavers. Winters would get them moving around a little, upward and downward. Over the coarse of 12 feet, we're talking an inch of undulation max.... not a big deal for a walk, but would look goofy for a driveway. About every fourth year, I would lift them all up, re-pack and level the sand underneath, and re-set them.
They came with the house, not sure how fancy the prep work was. Shoveling snow was hard on the shovel - kept catching brick edges.
Along those same lines, a friend of ours had a brick driveway.... he got sick of the maintenance and paved over the thing a few years back. He has a good sized Deere with a thrower on the front. I think that thing contributed to his problems also. The asphalt kinda holds all the bricks together nowadays.
Stuart in MN
Minneapolis
I have a concrete paver brick sidewalk, and it's held up very well for 20 years in Minnesota. It's all in the preparation of the base - if that's done well the pavers will stay in place. My next door neighbor used conventional bricks for his driveway; it's only a couple years old but it appears to be staying nice and flat.
Frank Elson
Lancashire, UK
I built a patio, 15ft by 50ft out of what we call paving slabs here, pavers for you.
It sits under snow for a month or so every year. That's a day here a day there. Then it's wet a lot. Then it just freezes a lot, have to be vary careful on my way to my workshop.
Hasn't moved or lifted yet, been down nearly 20 years. Like the man said, it's all in the laying. I use a lot of cement for bedding down and a lot of dry mix brushed into all the cracks as a grout.
W
Weedwaka
Thanks for the reply's !!
We are on gravel. I would do a lot of prep work prior to laying them down for sure.
Getting the snow off is also something I have been pondering.
ImportTuner
I love the look of the Stone Pavers too; had a outfit come out to do a estimate and (I have a small 2 car driveway) they quoted $18,000 .. eventually they came down to $13,000 which was still too much for my budget .. :(
fotoflojoe
Boston, Ma/South Shore
Used all the time here in NE not a problem if the pad is done righ.
Ding, ding, ding... We have a winner!
-B- is absolutely right. pad prep is the key to success.
I'm west of Boston. Three years ago, we installed a 4x20 front walkway, and a 16x20 patio out of pavers. Make sure you compact the surface every step of the way; compact the sub-soil, compact the crusher run, compact the pavers after they're in. Also make sure you use edge retainer strips.
FWIW, last winter, it was cold, wet, with a LOT of snow - much nastier than usual. Pavers never budged.
xroad
It is all about the base. The more varied soil condition you have across the paver stone area, the thicker the base have to be to isolate the varying soil condition. The soil will heave in the winter. Pack the soil base tight. Then pack the gravel/stone dust base tight, thin layer at a time. Do not dump 12 inches on the soil and expect to pack it tight. Pack one inch at a time. Any variation in flatness, or lack of, will show up on the paver surface. No amount of sand will help you. The sand will fill the fine gaps between the bottom of the paver stones and the top of the base.
If you'll be running shovels over them, choose pavers with rounded edges so they won't catch.
Surrounding soil should e able to drain water or else the patio will be like a bowl holding water. If your surrounding soil has lots of clay, build the patio slightly higher. "ramp" the edge to transition to the lawn.
Not rocket science. Just lots of sweat labor. You can go read on this topic till the cows come home.
quatroad
Westchester, NY
Agreed. With the right footings, the pavers will not budge...EVER. We have three patios and two walkways that were put down 15 years ago. Everyone snickered and said our stone mason was over-building and over-charging for the job. Well, they've all done, re-done, and re-re-done their jobs several times over at far greater expense and aggravation. Our Portuguese stone mason comes back to our place a lot, but never to re-do a job. He's too busy doing new work, "over-building" each one of 'em :))))
W
Weedwaka
Do you have any pics of your paving stone work ? :beer:
v7guy
Hudson valley, NY
we have a lot of pavers in the long island NYC area and they seem to hold up fine. One of my buddies that was in construction even comented that it's all in the prep, if the contractor or person doesn't do it right they'll be back every couple of years.
tcianci
Walpole, Ma
The base is certainly the key, we did a couple of paver walks at my mothers house a few years ago and there is absolutely no movement at all. They were filled inbetween with poymeric sand, which goes in like reguilar sand but hardens up like a grout once it gets wet. The workmanship and durability is outstanding.
kirk.g
Toronto Ontario
Why does your Portugese stone guy keep coming back.?....should I look for a Portugese installer?...would a Polish or Italian work?
kbs2244
As everybody said prep is the key.
But it is backbreaking work.
This is one of the times I would find an experienced local guy with good references.
For snow removal I would go with a blower not a plow.
You can set the height of the scraper bar easier so you don’t keep nicking the edges.
If you pick a darker color the sun will finish off the snow removal.
kirk.g
Toronto Ontario
I need to fix the driveway,Its been a few years since it was ripped up down one side of the house to do weeping tiles.The guy with the backhoe shows up early and I didnt get a chance to get a saw.However ive priced some paving contractors and the job is 1000$ and thats with them doing the house 4 doors down at the same time.Its about 4 ft wide down the side of house its may be 175 ft sq.......Ive priced out the low end paver stones at 2$ sq ft. I need to get the house appraised soon and It would be nice get the driveway looking alittle better.............I used to be able to go to a local asphalt plant and pick up a small amount in a pickup.But they have since got a larger silo its too high and the guy says if he drops aton or more then that would be the end of my pickup box.....................Im thinking 400$ for pavers plus aton of limestone screening 40$ edging ? specialized sand 40$? ashalt saw rental 40? plus how much time ? and its getting colder out....................and I should prob buy a wheelbarrow?................i dont know?....Kirk
jhelrey
MN
Pro landscaper here... We did a driveway with 12-16 inches of base packed every 1.5 inches and wetted. I've seen fully loaded dump trucks, cement trucks, etc driven on it. Hasn't sank at all. Owner uses a skidloader with a nylon blade to plow.
kirk.g
Toronto Ontario
Can you elaborate pls.Are you saying 12-16in deep of base.Most of what I need is close to the house and only cars and a pickup parked.What is the base material?Here its usually limestone screening.But limestone is usually a light gray and sticks out against the dark asphalt....Also what did you use to pack it?.....thanks Kirk
theoldwizard1
SE MI
Yep, it is all in the prep.
I have an area between my drive and the house that I had done a few years ago. A very odd shaped area that was always filled with mud because of the pitch on the drive.
I told the guy I wanted it dug down at least 24". He wasn't too happy when he found out it was all clay ! He used broken concrete and gravel for the first 12-14". Then just gravel and whatever he used as the final layer. Each layer was compacted.
Water still runs off the driveway in that direction and I will have a puddle if it rains hard, but the puddle never last more than a few hours !
It has raised/dropped about 1/2" in some places, but I am still quite happy !
kirk.g
Toronto Ontario
Im in Toronto Ontario.Limestone sceening is readily availabe here 40$ a ton.I can get in my pickup.the other three aggregates that are cheap and plentifull here are; 3/4 crushed clear stone,pea gravel,and clear sharp sand (mostly for cement mixing).The ground here is sandy not hard packed and no rocks.If you go down about 4.5 to 5 ft then you hit shale rock..........Kirk
theoldwizard1
SE MI
Stay away from any stone that does NOT have sharp edges ! It will not "lock" into place no matter how many time you run a compactor over it.
treasureseeker
I have did a patio and a walkway with slag sand and have to do them over after the first winter. I did a small area with the correct base and it didn’t change at all from the winter but the plastic border I put down that the pavers go over and takes the long spikes didn’t hold. Like everyone else mentioned with the right base no problems but also research the edging/ border
kirk.g
Toronto Ontario
you will need to be a bit more explanatory sorry for the ignorance.........on another note I just drove past a bakery outlet I go too a couple of hours ago.They were closed but theres a contractor there tonight taking up all the paving stones in the parking lot and walkway.Hes using a backhoe but there is more than enough there for what I need.Their doing it tonight so they can replace it in the early am with redimix........thing is the pavers are red and if I had my choice I would go with charcoal grey....the store owner doesnt want any trucks there when the store opens,,,,,,,but new or old they should work the same......Right Kirk
Jeff Ivers
Oklahoma
I live in OK and have concrete paver walks and patio I built about 35 years ago. They are now getting to the point of needing some serious maintenance. When built, I dug down at least a foot (as I recall), put in about 8" of gravel compacted, 2" of sand compacted and then the pavers. Locally they did some paver streets by installing a concrete underlayment followed by the pavers. Those are holding up even better than my home stuff but obviously at a much higher cost
andyvh1959
Green Bay WI
Like the song, "Its all about the base, bout the base, no trouble, all about the base bout the base no trouble."
Like others said, the base makes it work. Its almost like building a driveway under the pavers to get it ready, which is also why a contractor charges so much for a paver driveway IF its done right. At my previous house 30 miles south of Green Bay WI I graded it down to the subsoil which in that case had some clay. So about 8" below my intended final grade I compacted that soil, laid a gravel layer on top of that, compacted, laid a compacted limestone chips layer, then finally a screeded sand layer to level and lay the pavers. Once set, compacted the pavers into the sand. However, at that time I did not use the right sand to broom into the paver gaps, so eventually I had anthills all over the damn place. So its best to broom in polymeric sand. I put down six pallets of pavers and they never moved.
slowtwitch73
Hellgate
^^ mix in some Portland with the sand to thwart the ant's.
Over time they will move enough material out to cause the pavers to sink in conjunction with rain.
