Also, pull the known GFCI outlets out, take the wires off and splice them together black-black, white-white and see if the dead outlet comes to life. It was a one time deal, but I have seen a GFCI that appeared to be working fine wasn't feeding out on the load side.
In a perfect world, yes. The wire could be half assed stuck under the clamp, A #12 could have been stripped with a #14 stripper hole and it's broken, or it's not stripped far enough and the clamp is tightened down on the insulation, among other possibilities. I like to bypass anything that could be a point of failure.Wouldn't it be quicker to throw a meter (not a non contact tester, a real meter) on the load terminals?
Also less chance of messing up what might already be a wiring mess
My guess is that this is going to have nothing to do with the GFCI's unless one is bad or tripped, and more likely to be a back stabbed receptacle.
I'll throw my guess out there: OP hasn't found the GFCI this feeds from yet
Possible, but the dead outlet hasn't worked for years. If it's actually a tripped GFI, there's probably something else not working that would have been noticed in that time span. Maybe it's the only thing connected to the load and the hidden and tripped GFCI has never been used.I'll throw my guess out there: OP hasn't found the GFCI this feeds from yet
It could be switched as well. The switch could be off and everybody has always wondered what in the hell that switch is for, not knowing the previous owner had it installed for Christmas lights.
Not if there is a tripped GFCI in the middle, and if it's connected to a working GFCI there's no reason to trace it. At 20 years old, I don't think the exterior outlets will be shared with a bath circuit, definitely not the kitchen. You should also have two exterior outlets, one at the front and another in the back, maybe more. Check the other(s), pull them out of of the box and check for backstabbing.Hi,
LOL!...
Well, there is no wiring "Mess" that I know of, at least not yet!
Shouldn't I be able to trace from the outside receptacle wires to the Breaker Panel, even if there is a GFI somewhere in the middle?
No. Is it logical? Maybe. But whoever wired it could have done pretty much anything.Hi,
Is it safe to say that this outside receptacle HAS to be going to one of the close Garage GFI';s???
We have one of those switches in a rental.Possible, but the dead outlet hasn't worked for years. If it's actually a tripped GFI, there's probably something else not working that would have been noticed in that time span. Maybe it's the only thing connected to the load and the hidden and tripped GFCI has never been used.
Crazy how easy it would be to get a blocking cover or just wire nut it permanently on...We have one of those switches in a rental.
The switch runs one half of a two story unattached garage? Someone put that switch on a stair landing inside the house. Each time we have new tenants, the switch is included in their "orientation". Nobody ever seems to remember. I guess the good thing is the ease of fixing their late night garage light problem.
I have seen GFI plugs inside cabinets. Probably installed for some old appliance that has been long gone.
I've seen (found) GFCI outlets in the damndest places, but never on a house that's only 20 years old.We have one of those switches in a rental.
It has a guard cover. I'm always amazed that someone went through the hassle of flipping the switch.Crazy how easy it would be to get a blocking cover or just wire nut it permanently on...
I have read many threads similar to this one. Lots of good diagnostic info comes out......and the threads usually end with "I found it"Hi,
I found it!
Feel like a *****, but I found the GFI...
It was behind a stand up 6' shelf that had been there forever. (full of **** of course!)
Thanks EVERYONE, for help on this, learning all the time!!!
