1930artdeco
Somewhere here is a thread dealing with rust removal via sodium citrate and washing soda. I keep losing the one I replied to and I said I would post the results of my gas tank rust removal. So here I go.
I used one of those 75 gal tote things that is encased in a metal cage. Cut it roughly in half for what I needed-plenty of room. The formula I had was derived from the UTube video (the gun smith one). I did not anticipate the volume of the tub so will need to double everything to make it work. I ended up using approximately 17 lbs of Citric Acid, 7 lbs of washing soda and 17ish gal. Of water plus some dish soap. These are the before pics of my tank. Not in too bad of shape for something that is 90+ YO and was hanging in an uninsulated garage for who knows how long. The inside was rusty though. I tumbled the tank with some rocks-got them all out by the way
Then I set up the solution and dropped the tank in. I didn’t have a tub when I created the formula so after dunking, it was half in and half out. I would let it soak for two days on one side and then flip it over. All and all it was in the solution for about 5 days.
What I learned was this:
1) it does work, although I think I made mine a tad on the weak side.
2) it does eat at primer at least. That is a lot of the red stuff.
3)even half submerged it left somewhat of a film so there doesn’t seem to be much flash rust.
Any questions feel free to ask. This tank is a spare so it will get pickled and put on a shelf.
Mike
Mike
