YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 502
Considering doing a leak down test on my 2014 Acura TSX that's burning oil. Am I able to do this test with a tire inflator or even a hand pump. I have done this before in school, but never at home. Can I just use a tire inflator or hand pump? I understand the basic operating principles. But the cylinder in top dead center so intake and exhaust valves are closed. Put in a new pressure into the leak down test tool. Set the pressure into the cylinder. Leave it for so many minutes and see if it hold the pressure.
I'm thinking that say the target is 135 psi. Can't I just use my Milwaukee M18 tire inflator so that it goes to 135 psi, then open the valve so that the pressure goes into the combustion chamber as well, resulting in the pressure going down, then re-run the tire inflator so it's 135 psi and see if it holds it.
Also when I have done this before I was able to find procedures in like ShopKey or AllData. But I'm not able to find a procedure for a leak down test in this car in ShopKey. I can't like for example find what pressure I should use. I don't want to use to much.
Thanks for all help!
