Hello All: I recently bought the set (P/N 81298T) which consists of a (1/2” - 81371T, 3/8 - 81267T and 1/4” - 81016T) ratchets. I analyzed all ratchets and found excessive drive gear side-to-side per the 3/8” drive ratchet in the set. the 1/4” drive ratchet has excessive drive gear side-to-side as well, surprisingly enough the 1/2” drive ratchet has very little drive gear side-to-side. I also noticed excessive side-to-side play at the flex joint. In order to eliminate the excessive side-to-side play at the joint I added some Blue lock tight to the threads and put the Torx head bolt back and tightened to the point where the side-to-side play was virtually eliminated. Has anyone bought any Grearwrench locking flex head ratchet or ratchets and experienced the same issues I encountered with Grearwrench locking flex head ratchets? I have attached two short videos showing the excessive drive gear side-to-side play.
Video #1:
Video #2:
Video #1:
Video #2:
