Skyman
Central Maryland
In 1981, right after I met this guy, we went over to one of my girlfriend's houses. She had a BIC lighter that wasn't working properly.
He disassembled it, reversed the flint, stretched the spring out a wee bit, re-attached the metal cap, and voila! Back in working order.
There's a reason this is the guy who does all the work on my vehicles. Doesn't matter what it is: he'll figure out how to fix it. He was ecstatic about fixing that remote - he loves a good challenge. The screw and nut at the top is the new "contact point" for the momentary switch - which is the part that was broken. (I had previously glued the unit back together multiple times and re-soldered the wires back onto the circuit board at least twice.)
He sounds like the kind of guy I'd like to have for a next-door neighbor.
Hooked
League City, Texas
Today’s goal was to fix this thirty five year old floorjack.
I loaned it out to a friend twenty years ago who bent it somehow, so it had a pretty hefty parallelogram to the frame. I straightened it out no problem, but it would immediately fold over again under load. To fix THAT, I welded plate steel to the bottom. After the repair, and since I had several other jacks, this one became the outside jack because it wouldn’t sink in the gravel.
Recently (this century, I think), the handle started jamming or popping out due to all the dragging and tugging it has suffered, and I had had enough. I unscrewed the handle capture bolt and found its little dog point had been jaggedly sheared off. I needed to make a new step bolt.
Here is the old and the new:
And the channel in the handle that the dog point engages: Focus!
BUT. To get to this point, I had to find a 3 jaw chuck, since neither of the chucks on my prewar Atlas Babbitt lathe would hold a small hex reliably. WTH, is that a 2.5 inch 3jaw?
I found a local machinist had a surplus new-in-box imported 5” 3jaw, and eBay had a cast iron back plate that would adapt it to my 1.5”-8 headstock with a little machining and a little drilling.
Viola! Chips!
And now I know a little more about what tooling this abused antique lathe needs. Also, I won’t have to crawl under another precariously-supported truck because the handle pulled off again.
Dog. Point!
I also have that same jack but mine has been sitting unused for many years since I procrastinate too much. It doesn't hold a load and I have tried to fix it after having been in a dire need for a jack immediately and bought a new one. ;)
oldman_pottering
Tinonee, NSW Australia
Viola! Chips!
Dog. Point!
Good job ! I think it's cool that you first had to modify your lathe before you could could actually do the job you want, so many of my jobs end up so far down other rabbit holes before I actually get the initial job done
nadogail
Coronado, CA
Mounted the new bracket and 4X4 connection box on my Table Saw, installed a two screw fitting and one load cable, mounted the DPST switch to the box cover, found enough terminal lugs for the three cables that will be terminating in the switch box.
I will be working on this project again on Sunday, because tomorrow we will be finishing the turnover on a rental.
Blue Chips
Maine
Just imagine, I recently flashed a generator in a 48 Ford. Raise your hands if you think it didn't have to do with clothing,
You might say there's a 'generation' gap. :rolleyes: Anyway, that brings back memories.
We always called it 'polarizing' a generator...restoring the residual magnetism in the field iron cores with the correct polarity. When I was in high school I worked for a small family-run business that built/repaired/modified transformers, generators, electric motors, etc. Most of the stuff we worked on was large industrial equipment, but we did a fair amount of automotive paraphernalia.
Blue Chips
Maine
Now that our new garage is almost ready for use, I'm in the process of vacating the storage unit that my 1954 Dodge M37 is/was in.
Today I brought the chassis home on my flatbed trailer. There are still about two pickup loads of body panels, etc., to bring home, which I might start picking away at tomorrow. The next storage unit rental fee is due in a couple of weeks, and I want to get it cleared out before then. I'd rather spend the money on M37 parts than on storage rental.
I'm looking forward to using my new car lift to finish the M37's undercarriage work, after which I'll probably move it to our old garage (my shop) to work on the tasks that are at a convenient working height without having to use the lift. My lower back isn't what it used to be, and the new lift should make the chassis work far more enjoyable and efficient.
kaymccampbell
Upstate New York
I "detailed" the interior of my beater '93 Toy Corolla--with a cordless leafblower. Opened all the doors and let 'er rip!
Worked a charm! It even got out the vacuum-proof dead wasps from between the third brake light and the rear window.
That and a real feather duster will make your sbox feel like new inside. It's how I do mine.
Magnum440d100
Indiana
Ethanol-laced fuel that sat over winter.
Brand new Chinese carb on ebay: about 9 bucks.
They need it back quicker than Amazon can drop it off.
I have the carb soaking in chemdip overnight. It’ll be back together by 7 or 8 am tomorrow morning whereas Amazon doesn’t usually deliver here until between 4pm-7pm.
bornbadbob
Oh it does.... Most only have pain in one area.....the area with the most pain wins...
I had just recently put a set of finger nail clippers in the garage. . . Then I had to clean the blood off them later. I believe that was a first cleaning blood off clippers.
I have been keeping nail clippers in the garage for years. They come in handy more often than you would think.
LeonardY
Southern California
Did you consider lopping the tops off it with an angle grinder?
I did but I checked Amazon and they had a shorter one. But while they were made by the same company as my other two, They were different. Metal shelves and the legs were different. They were folded back to hide the keyhole slots. There was a lot of distortion in the keyhole section.
I just ordered the same version as the other two I bought.
2001ZR2
Kansas City
After letting the Suburban airbox dry out,
I installed the blower motor. After finding the battery dead and putting on the jump box it started and much more out the vents.
Cleaned off the cowl for fixing the wipers...maybe today. Met the UPS guy with the Rock Auto delivery of A/C parts.
Put away tools and called it a day.
I have a pair "clipped" to my 4" crescent with a disc magnet in my left front pocket. all three are handy, the crescent for whatever it fits, the cillpers, and the magnet for verifying steel or not... Had that and a single AAA LED flashlight there for a couple of decades.
ATL86
Niget2002, I see the aforementioned Barker horizontal mill on a rolling table. It's got a swiveling milling vise on the table, a slab cutter in the spindle, and the overarm support above. The motor is hanging off the contraption at the bottom right, linked belt to the large pulley, V-belt (?) to the spindle pulley. Some major speed reduction going on there.
It only had one speed when I found the Barker. It needed to slow down considerably to use any sort of cutter. I thought about using a VHD but for cost, a pulley system seemed the way to go. Took a bit to figure it out but ended up with an 8 speed pulley system. Got the low speed down to 900. Perfect for a 3" cutter! Its quite the little horizontal mill.
PhantomEB
Medicine Hat, AB, Canuckistan
Today is transmission shifter linkage hooked up, make sure the 205 is filled up and see if everything is shifting within the C6 transmission before driveshafts go back in. Lots of trial and error/fabrication coming up. If that all plays out then I can put the side and rear windows back in on the soft top and drive it out for a car wash In the back alley. Photo ops too for the FB hater peanut gallery.
also need to cut and smoothen out the aluminum hood support as well plan for some steel purchase this week for an accessible storage platform in the back of the bronco as well scrap steel storage underneath my welding table. Oh and drive over fender extensions for the trailer. Figure 2x6 1/4 wall will never collapse when driving the bronco over them. Saves me time from having to pull the fenders out for clearance. Fender extensions will be removable if I need to but also designed for if I ever get another fast street car to take to the track.
larry4406
Northern Virginia
Unpacked a new measuring wheel.
My old measuring wheel the latch broke off which locks the folding handle in a straight position for use.
Called Lufkin to buy a replacement hinge. They said they don’t have that part but the wheel has a lifetime guarantee.
They had me fill out a form on line, send a picture, no receipt necessary, and they sent me a brand new wheel at no charge!
Hate to toss it as seems like an easy fix. Could splint it permanent.
jade97
Strip of metal, rivnut and a thumbscrew?
