Between 485 & 705 SQ/FT Bob Heine's Auto Emporium
madison069
Monroeville, PA
@Squankum, a mobility scooter is probably a better idea. To avoid the possibility of driving the Corvette in the rain, I'd need a trailer to transport it. None of my vehicles have any towing capacity (Cadillac CTS-V and PT Cruiser are rated for 1,000 lbs) so I'd need a truck. To make up for those extra expenses, I'd need a camper for the truck bed and it would have to have cooking and food storage facilities.
If a 2000 Jaguar type S can handle a scooter lift and a scooter, I don’t see why a corvette can’t handle it.
Bob Heine
Boca Raton, Florida
@Squankum, I interpret the first photo as a less expensive solution than a truck and trailer to tow my Corvette to the Tail of the Dragon:
  1. Buy a 2001-4 C5 Corvette Z06 (that black brake duct in front of the rear wheel opening gives it away as a Z06). They only came with 6-speed manual transmissions so I need to pass a driving test as soon as I get it home. I found a yellow one with 58,000 miles on it with at least one accident. Already has long tube headers, cam, FAST intake, larger throttle body and new tires. Price has come down $2,000 to $18,999. With the modifications and new tires I can almost guarantee it needs a clutch. A new GM clutch and flywheel is only $460 but installation is about $2,000 at a shop and at home it has to be done with the garage door open so one can remove the entire exhaust system, disconnect and move the entire rear end including the rear suspension, transmission and differential package from the rear. A tube containing the driveshaft connects to the bellhousing. If you want to see what's involved in a clutch replacement, which seems to be required every 30,000 miles or so, here's a 45 minute video:
  2. Buy a trailer to carry the autocross tires, jacks and tools because cheap all weather tires are available for a C5 Corvette Z06: https://www.tirerack.com/tires/Tire...iameter=18&rearSortCode=54700&performance=ALL
  3. Maybe just buy a set of 18" rims and high performance tires for my C4 Corvette. Cheapest package from Tire Rack is $2,000 plus mounting, balance and stuff for another $400 or so.
And there's enough room for a big box of bandaids.
Kay, if I stick with the C4 and drive with the top up I have room for the big box of the Bandaids and a large package of XL Depend. It's a challenge to reach the takeout windows at the fast food drivethrus but that's OK.
Bob Heine
Boca Raton, Florida
Hey Bob, It seems like the chevy pickemup, The SSR be something you could get interested in? I think it was an all-Corvette suspension. I'm not a chevy guy so I'll defer to the experts on GJ. Haul all your stuff and pull a trailer/camper as well?
Alan, at least it has a 2,500 pound towing capacity. Not enough to drag the Corvette on a trailer but maybe one of the tiny travel trailers.
CNC_RICK
Wisconsin
Bob, I get you with the little circles, that should be as close as possible (clocked, almost) to the valve stem, on new tires. I did as I should and always tried to line things up. I don't know if it really made a huge difference to my cars. But I wasn't mounting tires for a Corvette, more likely for a pick-up truck. Even my Mitsubishi Eclipse had 17" rims on it with what I call "rubber band tires" on it. What a pain in the tail end, trying to mount new tires on those rims on a Coats 1010 Powerman tire machine, made years ago.... Along with that, those wheels were (let's say modern) with deep offset to them .. cripes, I could barely get a quarter turn to the cone-shaped nut for the center post on the machine... At one point, for the deep offset wheels, I made a collar on the lathe... I put it in the 4-jaw chuck, very off-center and bored out the center hole. I split the thick side on my band saw. Then setup in the milling machine to drill/ tap a hole for a bolt that would tighten up around the center post of the 1010... Darned it, they have to keep changing things and make your equipment obsolete...
CNC_RICK
Wisconsin
I just had a hearing test done, by the Company... First one in about twenty years or so. I had to fill out a questionnaire before I could enter the semi- sized trailer in the parking lot. So far, everything's as expected... The questionnaire, I had to tell some things I've experienced along the way.... Any explosions? Sure, a rear tractor tire on an Allis Chalmers Model B... That thing was LOUD when that tire went off ... Only about ten lbs of pressure in it when it went... I lost my hearing for about ten minutes over that one. You wouldn't think that low of pressure would be so loud. It really was. Much more than my second explosion, meaning the cannons fired off at Fort Snelling in the Twin Cities, one fine afternoon on the 4th of July... I didn't lose my hearing from the cannons, at all. The tractor tire was a bigger (louder) explosion.
CNC_RICK
Wisconsin
Bob, you should see my tire balancer... Made in the days when rocks were still being invented... My machine is MECHANICAL with a capital M... old, but good. I can do static balancing on it as well as dynamic balancing on it.... Let's start with static balancing... Put said mounted rim on it in the vertical spindle condition... Step on a pedal and the spindle goes 90 degrees to horizontal, but takes out the play in the spindle bearing. Make a mark on your tire, at about 12:00 position with a piece of chalk. Start with your chalk line at 12:00. If it spins and stops, add weight to the top of the rim. Try again... As you get closer, it doesn't spin any more. It is static balanced. Time to put the spindle vertical. The spindle bearing becomes loose again, like a ball. Then it's time to put the motor pulley against the outside of the tire and spin it to... ( I always picked 60 mph). About 700 rpm on a 15" rim. Once that happens, the tire/ wheel should be spinning about flat. If not, there's a lever to pull and there's a plate mounted on a ball shaped mount underneath... Stop the tire/wheel assy. Step on the pedal and put the spindle horizontal again, then there's a built in gage of sorts, like a dial indicator in machine work. That indicator tells you exactly where to put weight and how much. Sounds cave man like, but it really works...
CNC_RICK
Wisconsin
I always worried about spinning a tire/ wheel assy at 700 rpm next to my body, let alone the windshield of my truck, let alone with newly applied wheel weights, so I always had a chunk of plywood between me and the machine, and my windshield. 700 rpm on any tire/wheel assy is not for the faint of heart...
CNC_RICK
Wisconsin
Another thing I'll give Kay credit for is her knowledge of electronics and computers. I'm somewhat "book smart" with my degree as a technician, nothing above that. I know theory, but have no "hands on" experience. Kay has fixed many things along the way. I haven't fixed anything... Ha, I hate that Kay is smarter than me.. but she deserves the credit. :)
kaymccampbell
Upstate New York
I wish I had room for tire machines. Instead I have these halfassed flying monkeys that live in a big garage down the road. The upside is that the wicked witch that owns them, keeps them on a pretty short leash.
Wiz02
Southeastern PA
As long as we're on the subject of mounting tires, I bring 2 wheels, one that I curbed with a tire mounted and one "new" wheel to my local tire shop.
I wanted the shop to transfer the tire to the new wheel. They wouldn't do it because the tire was over 4 years old. They claimed that they have had old tires explode when they tried to remount them.
I hardly drive the car and it's garaged so the tire looks brand new. I took it to another shop who grumbled a bit but did the job.
Is this concern about a tire that less than 5 years old legitimate or a scam?
driftpin
Bob, congratulations on your test being [-]. A great sigh of relief.
I may have posted these pictures before on GJ, but in this thread, I know those who appreciate older iron will be happy to see them.
I liked your discussion of the use of Evaporust. I'm cheap, I use cleaning vinegar. I used 6% to do this wall decoration:
A 'sad face' pedal car now a wall hanging. This took maybe 2 days, and the vinegar is reuseable. I screen the liquid, and return it to the gallon container for another project.
A rusty motorcycle body panel, covering an airbox, exposure time, ~36 hours, 6% cleaning vinegar:
I was impressed by the results of this soak.
One of my friends has an SSR Chevy, I think it's either a 6.0 or a 6.2 litre GM engine, and a manual transmission. He's had two or three, buying cheap because of needing work , fixing them, and selling them. He owns a collision shop.
He also owns this, and has for many years:
A 1967 427 Tri-Power.
He does vintage car restorations, and C1, C2, and C3 Corvettes he likes the most. Below is a 1969 small-block, one-owner/family car he had in for installing AC into it, using original GM parts, some of which he told me, were 1-year-only, making his work much-harder. However, he has a lot of contacts in the Corvette world, tracking-down parts. Who orders a FL car w/o AC? Well, that's corrected.
He has many neat cars coming through the doors, check-out what's in the background.
In the middle of things (below):
They also multi-task, here's a 400 Pontiac waiting to go into a vintage GTO {below}:
kaymccampbell
Upstate New York
I vote scam. 10 year old tires are edging into the iffy range. Tire shops sell tires with 5yo dates on them, if they're on their shelves.
xtremek
St. Johns, Mi
Bob, glad to hear you got a cleanish bill of health. Now can you do me 2 favors? Slow down, you're making the rest of us look bad. Second, can you look to your right, just a little more. That's it. now keeping looking that way for 5 more minutes. And don't come looking for your now missing air jack in my shop. :lol_hitti
Bob Heine
Boca Raton, Florida
I guess you could buy the class III hitch kit, and a scooter carrier. You might hafta spring for air shocks for the little extra load that vorketttes aren't designed for.
Kay, I checked on the towing capacity of our PT Cruiser and Curt says their class I hitch is good for 2,000 lbs and 200 lbs tongue weight. I believe the '87 Corvette towing capacity is limited by how much the driver weighs. At 211 lbs this morning I am pretty sure the Vette is already overloaded. Maybe one air shock on the driver side.
Rick, I used a tire machine a few times in my youth but putting snow tires on our '68 GTO involved the bumper jack base to break the bead and a few pry bars for tire irons. Did it once and decided to buy tires and 14"x6" chrome rims (I think they were $30 each) for the summer tires and left the snow tires on the original black steel rims.
One of the small side effects of my time under the train was my right eardrum being punctured. They called in a neurosurgeon while the orthopedic surgeons were patching me up because blood was coming out of that ear. He somehow determined it wasn't a brain bleed so I guess they didn't just stop work. Even went to the trouble of bringing in a plastic surgeon to do my chin and the gash on my right temple. He sure liked sewing -- I was told he put 180 stitches under and on the skin to pull it all back together. For a long time I had very little hearing in my right ear but I kinda enjoyed it. Lay on my left side with the stump under the pillow to keep the remaining muscles from contracting meant my deaf ear was the only one noise could get to. I slept like a rock through storms, kids crying, the fire siren at the station across the street and the train horns (we've always lived near railroad tracks).
Liane had a couple of episodes of vertigo a few years ago and ended up at an ENT (Ear, Nose and Throat) specialist who gave told her to do the Epley Maneuver thing and offered her a free hearing test. He suggested she get fitted for hearing aids and she left. As time passed, it seems her hearing was getting worse but I was absolutely certain she wouldn't wear them for long. I ended up buying her the $300 ones advertised on TV and sure enough, she wore them once and put them away. When she was watching TV by herself, she would crank the volume up little by little and I'd walk into the room to sounds that hurt my ears. Turns out the music and other background sounds were drowning out the voices. Turning up the volume didn't really help but it was her only solution.
It occurred to me the 77" Samsung smart TV might be smart enough to fix the problem. Turns out the TV doesn't but the sound bar Samsung sells does have a solution. There's a Voice Enhance Mode and as soon as I figured out how to get the TV and sound bar to communicate through Bluetooth it was better. When I turned on the Voice Enhance Mode it was a night and day difference. Instead of the volume being 75-90 she can have it at 50 and understand the dialog. I had avoided sound bars because Liane hates Surround sound (something to do with Jurassic Park animals sneaking up behind her) but I figured $120 was a worthwhile gamble.
https://www.amazon.com/dp/B0DY1Z934F?tag=atomicindus08-20
My tire balancer is in someone else's possession. It used to be the local tire store but now it's the mobile tire service guy. He brings his setup to my house, does my tires and takes his equipment away, along with a small wad of my cash.
I take it a step further. When the mobile tire guy is working on my tires in the driveway I am inside the house sitting at my desk and watching him do his thing with the security camera system.
I give Kay credit for being an amazing human being. I deal with caring for five fingernails using my teeth to rip off the torn bits while Kay does artwork on all ten of hers. She gets stuff done that I only dream of and she's had a traumatic brain injury. My brain defect is genetic, probably from whoever my father was.
Kay, I'd probably add an engine hoist and little utility trailer to the hoard before I'd even think about tire machines. We drive so few miles I would completely forget how to use the machines when the tires age out. Also, the halfassed flying monkeys at the big garage near me are free range and their trainer not only taught them to throw feces, he throws his own. The mobile tire guy has expanded and hired real humans and taught them how to do the job right and expects them to do the job as well as he did. I'm sure I'm paying a little more but the convenience and competence are worth it.
That's the funniest and most accurate description of what I see at the average tire shop I think I've ever heard....thanks for the laugh this morning!
Logan and Dan, I completely agree.
Howard,
Consumer Reports recommends replacing tires that are 10 years old or older. Tire manufacturers recommend 6 years but that might be lawyers' or marketing advice. There are also real factors affecting tire life:
  • Heat: High temperatures, especially when combined with underinflation or overloading, can accelerate tire aging.
  • Storage: Tires stored improperly (e.g., exposed to sunlight or extreme temperatures) will age faster according to Consumer Reports.
  • Driving Conditions: Frequent driving at high speeds or on rough roads can put more stress on tires.
  • Underinflation: Driving on underinflated tires can cause them to overheat and age.
  • Spares: Even spare tires should be replaced after 10 years.
All that being said, you should check the tires regularly and look for signs of cracks in the sidewalls or tread. Like you, I keep the Corvette (and the Cadillac) in the garage so the sunlight rarely gets to them. The garage rarely gets hotter than 82°F and most days it's 77°F. The Michelin Pilot Sport tires I took off the Cadillac had no more than 18,000 miles on them and the Sumitomo tires I took off the Corvette had less than 10,000 miles on them and the tread depth was 0.87" (22mm). The new Toyo Proxes tires have 0.908" (23.08mm). When I bought the Corvette in 1991 it looked like it had new tires on it but they were RECAPPED Goodyear Gatorbacks. One of them came apart at 20 mph on a right turn. Had to buy four new Gatorbacks and when one of them went flat sitting in the garage 8 years later, they were like brand new but the Gatorbacks were no longer being produced so I couldn't buy one. Bought four Sumitomos in 2007. At 18 years old, they had some very fine cracks at the base of the treads (none in the sidewalls) so I put the Toyo tires on. The two "new" Toyos on the left side are dated 3124 (July 2024) and the ones on the right are dated 0625 and 0825 (both February 2025) so I guess I have to replace two of them in 2030
Aside from one of the brand new Riken tires on the PT Cruiser being underinflated and destroyed because the halfassed flying monkeys at Tire Kingdom didn't know how to install a clamp on valve stem, one of the six month old truck tires on my father's '53 Olds blew up on a paved road in Alaska. It might have been because of the 1,500 miles of dirt road that led to the paved section. I mean, we also had five flats on that unpaved road and carried two spares in the trunk.
A friend in the Corvette club had a pristine 1968 Corvette convertible with flawless silver paint. He put four new Goodyear tires on the car and one of them blew up six months later. The tire tore apart the front fender and Goodyear eventually settled on the fender replacement and complete re-paint.
Philip, I rarely have big rust removal jobs to do and when I do, they are too big to put in a vinegar bath -- I'm talking Corvette frame crossmembers and the frame itself. I've been using the same Evapo-Rust for seven or eight years and it still does the job on the items that fit in the ultrasonic 6-liter tank.
I am happy for the people who own fabulous autos. There was a time when I was jealous but my bucket list overflowed a long time ago. I have no problem driving my cars and park them in convenient locations. I don't park at the farthest corner of the parking lot and I don't do inspection walks around them before I leave. Even if that '67 is only the 400 hp (hydraulic cam) 427 and not the 435 hp (solid lifter cam) I would be afraid to leave it anywhere. Like the split window '63 Corvette, those '67 435 hp cars are not all that rare. GM built 10,594 1963 Corvette split window coupes and 3,754 1967 Corvettes with the 435 tri-power engine. GM only built 2,085 Cadillac CTS-V sedans in 2011 and only 26 were produced in Thunder Gray.
Kay, 10 years is my understanding as well. I'm also told synthetic motor oil has a 5 to 7 year shelf life. :tantrum2:
Tires have a shelf life....see this article for a explanation. Shop saying after 4 years is BULL...
Mark, tire dealers also offer to fill tires with nitrogen, which is supposed to increase tire life. How exactly do I check to see if the gas in my new tires is 100% nitrogegn? They charge $70 to $180 to fill new tires with nitrogen, or $30 per tire for draining and refilling existing tires. Then it's another $5-7 to top them off if they lose pressure.
Most manufacturers want you to swap them after a week. That 6 years **** is new, trying to line their pockets from gullible customers. Michelin has said 10 years, for a long time.
Kay, I believe the: "We can't plug your tire, it has to be dismounted and patched from the inside with our unobtanium patch." Or: "The hole is too close to the sidewall so you'll have to buy a new tire." And: "They don't make that tire anymore so you'll have to buy four new tires to be safe."
Bob
Happy 4th of July to you and all the friends here
@gman007, thank you and I'm sorry to have missed the chance to reply on the actual holiday.
Kirk, first, thank you. Second I'm doing a huge number of things in my dreams but my waking hours are mostly spent looking for thihngs I know I have but can't remember where I put them. Thank goodness you found my jack, when you put it back, don't tell me where so it will be part of my waking search parties.
kaymccampbell
Upstate New York
I've been plugging tires for 60 years. I learned to do it when I was first told I would have to buy a new tire because of a nail. As for plugs in sidewalls, they work just fine. We're, mostly, not driving autocross, so all that BS is just that. My poor Journey, RIP, used to collect an amazing amount of road debris in its tires. The right front had over 30 string plugs in it, and the others had at least 10 per. And all had at least one sidewall plug. And as for that BS about all tires must match. Well, it's a nice to have, but not a mandate. We're, hopefully, not racing our little sboxes, where it might be important to traction control and ABS.
kaymccampbell
Upstate New York
Liane really needs the hearing aids. I went from 96 to 10 on the TV. Before, others could drive up, and hear the TV in their closed cars. Now, I'm ****** stealth, and if the house is closed up, they only hear the dog's barking and go away.
Oh, also play with the equalizer, and boost the mid-range. It'll make a difference on dialog.
Wiz02
Southeastern PA
Consumer Reports is a shill for whoever pays them the most. I can't count how many things they've lied about.
My criteria for purchasing vehicles is completely opposite of CR's. If CR recommends it, I wouldn't touch it with a barge pole.
If they say it's too noisy, ride is harsh, uses too much gas and is too powerful, then I'm interested.
Ford52PU
Coatesville PA
Good Morning Bob,
Happy 4th on the 5th to you!! You got me started a week ago with the airbag jack, then Jon got one also. I could no longer stand feeling cheated not to have one so thanks to EBay I got one also. A little different I got the handle long reach version to get to the rear on my 52 F1 but it goes down to 5.5" so it fits under the Spitifre also. I used it to raise the rear of the Spitfire as I'm replacing all the brake lines, brake parts and running a new fuel line as well. With my shoulder the airbag was great much easier than pumping my floor jack up and down. Now where do I order one of those halfassed flying monkeys everyone is talking about?
gilr
Richmond, VA
Hi Bob,
As for the cost to fill or add nitrogen to tires, my local Costco uses nitrogen to fill new tires they install and they have external tire fill stations beside the tire service center that dispenses nitrogen to add to your existing tires at no charge (other than your annual membership fee). I find that the nitrogen holds pressure better and doesn't drop as dramatically when the temperatures drop in the winter here as opposed to just filling with air. I have found Costco to be a great place to get new tires, the guys here are not flying monkeys' and they use actual torque wrenches to tighten the wheel lug nuts. When I bought new tires for the Vette, they told me their machines couldn't handle the large size the Grand Sport required and suggested I try Discount Tire, which I did. They, here in Richmond near me, are great to work with and did the installation with no drama. The new Michelin Pilot Sport 4S run flats are much quieter than the 6 year old original Michelin Cup tires it came with new.
madison069
Monroeville, PA
I’ll have to look into that Samsung sound bar. I use close caption when I watch tv but I do like to listen to something. I’ve worn hearing aids since I was 2 so I’ve learned to live with them. But, it pays to have a person to tune them cause they **** right out of the box. After 3-5 visits, the settings adjustment becomes acceptable and I don’t have to make as many visits for adjustments.
Bob Heine
Boca Raton, Florida
Kay, as usual you beat me. I've only been plugging my tires for 50 years. I bought the Sears (might have been Craftsman) kit that came with the hole file, needle and a pack of plugs. Last time I used it was at a huge garageless gas station. Filling up with gas I noticed the left rear tire on our Lincoln Town car was bulging so I checked the pressure. Sure enough, it was a screw in the shoulder of the tire. Completely irreparable so I removed the screw, plugged the hole and used my little Craftsman air pump to refill the tire. Didn't even get the jack out of the trunk. I now keep a kit in each car and it seems to ward off the flats. I do need to buy some fresh string packs because some of them might be 20 or 30 years old.
I have changed my criteria for tires. In my youth it had to be one of the big name tires like BF Badrich, Firestarter and Goodluckyear but now I shop by price. If they are round and fit my car I'm good. The Corvette and Cadillac have ABS and traction devices in the differential so the rear tires need to be real close to the same size. I could replace them in pairs but because we drive so few miles the other pair is already past their sell-by date. The Cadillac has smaller tires in the front so I can't even rotate them. The PT Cruiser has directional tires so I can only rotate front to back on the same side. These Toyo Proxes only have an 'outside' designation so they can be swapped from side to side and front to back.
I can bring a horse Liane to water but I can't make her drink. She still smokes cigarettes when they are more than $100 a carton and she will bleed out before leaving the house without her makeup on (firstborn was almost a home birth because of that). What starts out as a civil discussion of any of her quirks degenerates into a "Do you remember when..." tirade starting with the very first mistake I made in our marriage. I love her too much to even try to match the tirade and I fear for my life if she actually quits smoking. At this point we're co-dependent because we couldn't live without each other -- she remembers the things I forget and I remember the things she forgets.
I couldn't agree more. I used to pay for a subscription and based some purchases on their ratings. They weren't wrong 100% of the time but as they years passed they got a lot closer to a failing grade for me. I only quoted them because they don't actually make or sell tires.
Howard, when I got their yearly car buying book I always looked at the lowest ranked cars first. That's how I picked a GTO when gas prices were doubling and the Vega GT when I wanted an economy car. I never drive the Cadillac in Sport mode when Liane is in the car -- she still wants the Crown Vic we rented in California in 1994. Our '78 Lincoln Town Car stalled on left turns for me but not for her so she thought the new manifold and Holley carb was a waste of time and money. It eliminated the stalling and mileage took a hit but that 460 puppy could pull a huge stump out of the ground without a hint it was straining.
Good Morning Bob,
Dennis, that's a great jack and I was tempted to go for the wheels and handle version. Its only drawback to me is its compressed height. The one I ordered is a two- rather than a three-chamber air bag so it's Vevor's lowest model. Before I ordered the jack (from Vevor), I measured the ground clearance on the three cars that would see it used on most often. The Corvette is the lowest at about three inches.
Vevor claims a minimum height of 4.5 inches.
My measurement came out slightly higher but I haven't tried standing on it with the relief valve open.
The Corvette has 4.5", PT Cruiser has 5" and the Cadillac has just over 5" of ground clearance. I tested the jack on the Corvette and it doesn't clear the ground effects.
Hi Bob,
Gil, I love Costco (especially because I own some Costco stock) but I can't seem to get out of the store without spending around $700 and that's not going near the tool or tire departments. I did buy tires for one of our cars at Costco but they didn't have anything near my comfort level for the cars I drive. They also wouldn't put anything but the original size tires on my cars.
With nitrogen comprising 78% of our atmosphere, I have a hard time justifying using pure nitrogen in our tires!!
Gary, I would have to have all my cars' tires drained of air and filled with nitrogen for this to work. Even then I am certain I would grab an airline in the garage and pump the tires back up with air from my compressor. Maybe a tag on each reel's quick connect to not use it on my tires.
That's fine I only mentioned it because Costco uses it without extra charge, and it truly seems to maintain the pressure in my tires better than straight compressed air.
Gil, it's a good deal and I do believe it is less prone to expansion and contraction with temperature changes. I don't want to say I'm a cheapskate but I just modified a fancy oil dipstick I had on the shelf so it would work for the '87 Corvette when the plastic handle on the original snapped off last week. Spent 45 minutes instead of $48 for a reproduction.
Hey no fair Bob! With you missing an appendage, it puts all the rest of us at an over-weight disadvantage!
It was good to see you posting, always enjoy your "thoughtful" replies!
Fred, when my doctor tells me I need to lose some weight, I ask what part he would suggest I cut off.
xtremek
St. Johns, Mi
I'll take my rides to Dismount Tire and let the flying monkeys do the heavy work for me. Since I have so many vehicles/trailers, Dismount gives me a fleet discount. I think it's 7% discount, but don't quote me on that. And having to buy 2-3 sets of tires a year, it does add up.
driftpin
I take mine to Adirondack Tire. Used to be Park Tire. Nice folks. Have a do it right or make it right attitude. The flying monkeys are on short leashes. Not overly greedy. Too honest for their own good. Their lot is jammed every day, all day vs the competition, who have a few cars lined up.
When I was working fire-rescue here in So. FL, on the rescue squad I normally-worked, Jimmy, one of my co-workers, was from Brooklyn. One day as we were riding around, he was speaking about a softball team he played-on, and he was listing the bats he liked. "I use an Ah-dare-un-dakkk sometimes," he said.
I about spit-out my coffee, "what kind of bat did you say you used?" I asked.
"An Ah-dare-un-dakk," he answered.
I decided to poke the bear. "Can you spell that?" I asked.
"No, but that's one I use," he said.
"When I was in the Boy Scouts, we used to spend time hiking in the mountains of upstate New York. The "Ad-uh-rawn-dak" mountains," I told my co-workers.
Jimmy died of cancer years-ago, but I still remember that day. A bit of down-time, on fire-rescue, when we all had a good laugh.
kaymccampbell
Upstate New York
And when I'm in a mood, it's Ah-DEER-on-dak.
Squankum
Southeast
Say, Bob, is that a Flexzilla hose? Air or water?
Squankum
Southeast
"Old tire 'splode!" where tire = 5 years old sounds like hogwash to me.
But I just remembered my local Wal-Mart tire & auto dept. (not a place I haunt much at all) told me once they couldn't mount a used tire and balance it because there might be road debris in it that went flying when they spun it, sorry, insurance regs. Now, just like your case, I'm sure the overarching policy is "SELL NEW TIRES" but I can kinda see that.
My Mexican tire guys aren't worried about that. They don't worry about much! More on them in a few minutes.
Squankum
Southeast
Yeah, I don't have an conspiratorial attitudes towards them, but they are unrelenting nerds. I remember in the early 90's, they did a comparison test of the VW Jetta Mk 3. vs Nissan Altima vs. I forget , and one of their top five complaints about the VW was that the starter motor was noisy. How much of your drive is plagued by that noise?
