Beerhippie
Far NE Oregon
I'm on canning line maintenance for the week. Just got through lubing the canning line depalletizer--in an uninsulated and poorly ventilated steel warehouse, twelve feet from the floor. Glad I started that first thing this AM, as it's 90 outside and around 100 in the warehouse now.
Now to do a write-up for my maintenance schedule....
Real_PhillBert
Fargo, ND
Far out it must get cold where you live !
Is that plumbing that you run hot water through ?
This is setup to run hot water through to heat the slab, which in turn heats the garage. You can set them up to also circulate cold water if you want to cool the space, but I didn't go that far.
Here in North Dakota USA we see -40°F pretty much every winter, this should keep the garage comfortable year round.
Real_PhillBert
Fargo, ND
So, does the water flow constantly through that plumbing all year ?
No, 0 to 42 pretty much with that being both extremes, it's the middle of winter 6am at the moment at it's 13c
It wont be needed during the summer, but I'll start pumping heat into the slab in the fall and keep it warm until spring.
jawstight
I got so sick of cleaning out the pilot jets in the Mikuni carburetors on my Yamaha, that I sold the damned thing and have ever since - and forever will be - glad it's gone. If I let that bike sit for more than a coupla weeks, I could be certain it wouldn't fire on both cylinders until I got into those carbs again to clean out the jelled, ethanol-laced, fuel. The more times it happened, the longer the bike sat unused, and the more stupid it seemed to continue having it taking up space.
I had a Stihl weedeater that was that way. I learned over time that putting a shot of Seafoam in it and letting it sit overnight before dislocating my shoulder starting it did the trick. I've had other Stihl tools that were never that way though and finally gave the damn thing away after replacing it with a Milwaukee M18 weedwhacker. I don't miss the Stihl.
rcktpwrd
Raleigh, NC
Pulled my oscillating fan off the wall. I noticed that the fan didn't seem to be spinning as fast as it used too and wasn't moving as much air. Sometime in the early spring I had cleaned a very dirty cage and fan blade and that made a huge improvement. So I took the outer housing and oscillating mechanism off so I could lube the bushings. I had some 3-in-1 spray lubricant, so I gently sprayed that into the bushings while spinning the motor shaft. I could feel it loosen up and spin more freely, it wasn't a huge change but was noticeable! Put the fan back together and remounted it and turned it on, definitely spinning faster and moving more air! 😀
Beerhippie
Far NE Oregon
Folks are using heat pumps with the hydronic systems up here. We'll typically see -20F in the winter and 90-100F in the summer. With the heat pump, it's easy to switch from heating to cooling. We run a glycol solution in them in case of a power outage in the winter. Glycol also increases the specific heat of the water and keeps pumps running forever.
oldman_pottering
Tinonee, NSW Australia
I see, thanks mate
By crikey thats cold !
Beerhippie
Far NE Oregon
Here's my diagram for the instructions for lubing the depal unit:
Red is food-grade grease, black is oil (this might end up being B&W). I forgot one red arrow. Two grease points are out of sight, back upper corners, as are two of the chains needing oil.
Back to the write-up....
Real_PhillBert
Fargo, ND
Yup. this is also Glycol, I said water above but that's technically not true. You're on it! (y)
nadogail
Coronado, CA
Worked on the Table Saw Project, I needed to cut about an eighth of an inch from a 8-32 machine screw. Those used to be easy to cut with my crimping tool. Either the steel has gotten better or just maybe my right hand has lost some strength; got it done.
Unloaded some of the tools and materials from Saturday’s job from my van.
I found the missing electrical bits and pieces that I bought a couple of weeks ago. They can either be taken back to the store or I will save them for a future job.
Enjoyed a sandwich for lunch and will now go back to the garage for a few more minutes.
Beerhippie
Far NE Oregon
Electrician's crimper/stripper pliers aren't good at taking a very short piece off a screw. They're much happier taking a half-inch or more.
I run the screw into a die from the start side, grind the screw down to where I want it (being careful not to grind the die) then back the screw out. Perfect threads every time!
Similar, but I like to get a secure grip on the screw I'm cutting. hacksawing, or filing so I make these thread grippers - note the cut is made on the point of the nut so the flats will grip better The cut slot actually does a decent job of deburring as well:
micromind
Fernley, Nevada, about 30 miles east of Reno.
Same here. If you don't have a die, a nut will do but not as good.
nadogail
Coronado, CA
Got some tools put away. Moved some Root Beer and Cherry Coke Zero to the shop today.
Ran the power cable from the switch to where the outlet box will be.
Found a returnable Propane Tank in the Alley, neighbors are moving and are leaving it behind, the deposit on the tank is several bucks.
Beerhippie
Far NE Oregon
There's a special place in Hell....
PWC Repair
Arkansas
Today I did an R&R on a water jacketed header pipe from a late model 4 stroke Kawasaki Jet Ski. I've seen this a few times actually. People don't winterize properly and these things split wide open. This gave me an excuse to try my TIG for the third time since I've owned it. I sort of had to chase the puddles around a bit on this cast aluminum. It's not pretty, but it won't sink the Jet Ski anymore!
Beerhippie
Far NE Oregon
Normally when the boss asks you to write a job description, it's a good time to start writing a resume and CV. In my case, it's to make them wonder "Who the hell can we hire to do all this"?
kaymccampbell
Upstate New York
I wrote my job up once. It filled 2 4x8 bookcases and took me forever. The last time I did it, I had someone follow me like a puppy for a year.
rharman
SoCal
Built a 50% size mockup of the headboard my wife wants. Cardboard & 1x2. Now, we can tweak the design.
Started on a mockup of the bench for the foot of the bed. Amazon showed up in the middle of it with the M8 tee-nuts I need for the legs. Didn't get far before it was decided to revisit the design. Same legs though - they match the bed and were $175 for the set - non-refundable. They are very nice aluminum legs - 8" - sturdy as can be.
LeonardY
Southern California
Can you do a 3D printed one for the mockup? Use a solid dowel or metal rod in the center for support?
rharman
SoCal
For the bench, we're just mocking up one corner at full size so I can use the real leg. Trying to work out the ratio of skirt and cushion and nail down the construction detail.
Don't have a 3D printer - Can't justify it and I have never been able to get the hang of using any type of CAD program. Just don't have that knack.
