Most hated tool
e-tek
Saskatoon, SK
Thanks for this thread - it's SO good to hear how so many others hate the mutha-puckin grease guns too!!!!:bounce:
Skin
Boston
What is the most aggravating, hateful tool you have ever used? For me, undoubtedly, it is a handheld grease gun. I get pissed off every time I pick one up, because I know it's going to make me furious before I put it down, anyway. It can pump great, but the minute you climb into a piece of machinery or under a car, it will make 2 pumps and quit. Reloading and priming one is another adventure unto itself. I have used all the major brands for over 45 years, and have yet to find one that won't end up ruining my day.
Rant over. Your most hated tool?
i have both an old fashioned manual and a pneumatic and never once had a problem. If i were going to blame anything for poor grease gun performance i'd go after bad zerk fittings.
i'll nominate irwin vise grips. Really enjoy their release mechanism that they never once changed. Usually i use a pair of pliers or whatever else i'm holding so my fingers dont get crunched when it snaps open.
second to this would probably be the adjustable wrench. no matter how many times you set the thing you always end up with too much play in the jaw.
lastly, air ratchets. Its not so much the tool as the noise it emits. If a banshee escaping from hell made a noise, i think that would be it.
2drx4
Northern BC, Canada
That dude we hired a few years ago... never did anything, and when he did - it was usually in error, always on the dmnd phone or texting, had a faux hawk and smelled like peaches or something - what a tool.
Got one of those at work now. Really makes me mad. I don't swear at any of my work tools, 'cept this guy.
The last thing he did was paint our hangar floor. He was supposed to be painting the door jambs on a helicopter, but neglected the whole drop cloth thing... The overspray he laid on the floor is more consistent than the paint he got on the machine.
DIC
Those dam test lights with the probe that pokes a hole in your finger every time you use it.............:mad:
jam0o0
Katy, TX
SNAP RING PLIERS. honestly i don't know fi there is a set of these in the world that work properly
my cheep manual grease gun - why doesn't the hose stay on the zerk. why does the handle open 4 inches wider than my hand. why are the seals on my truck stronger than the seals in the grease gun.
philips - it looks like it should work but nooooooo. they are all terrible. all. i think i end up spending more time cleaning them out or grinding them into a new shape.
my dremel - i don't know if i got a bad one or what but i have to wear a glove to keep it from burning my hand. i've even left it in the rain but it wont die.
BerBer5985
Crofton, MD
A drywall spackling knife! After redoing our house and fixing so much Sheetrock, I hate them! I don't ever want to touch one again!
Moose-LandTran
The Brink of Insanity (England)
any tool that i need to do tires (i hate doing tires)
I've spent enough time doing tyres that it's all good. I do prefer to use my own levers though. Doing tyres really isn't all that bad, from the work aspect. From the job aspect it blows.
Knipex Precision. :thumbup:
feltciera
Kingston, ny
My most hated tool is the one I'm using at the exact moment the tool fails to perform as designed. For example I have a set of larger Craftsman raised panel wrenches 20-25mm, in one particular application the open end of the 21 mm wrench is the only tool that can be used and every time I use the Craftsman wrench it opens up, slips and damages the fitting. Wrench gets tossed, foul language gets yelled and possible knuckle busting occurs. If I use a co-workers Snap-on 21mm wrench it does the job just fine, but I still go for my Craftsman wrench every time and still haven't replaced it with a Snap-on, so its my own fault. Just on example, I've similar stories involving spring compressors, tire machines, screwdrivers and just about every tool mentioned so far!
srmofo
SW ohio
trouble lights. It doesnt matter what fancy mechanism they have to hang them or hold them, they always swing around and end up pointing right in my eyes instead of what Im working on. Im convinced thats why they are called trouble lights, because they cause me nothing but trouble
NAYLOR
Frearson drivers/bronze screws. I would rather turn 1,000 slotted screws by hand than try to back out one of those little sob's.
stereobbq
i hate screws, bolts, nuts whatever. they always get stuck at the worst times lol. and someone mentioned spring compressors, what a PAIN. :)
michael murder
My most hated tool is my 1/2" mustard colored black and decker drill. It's handy but I hate that it does not have reverse, I've gotten it stuck in a few places and had to back it out with a pair of pliers.
Stick Figure
Omaha, Ne
These cheap new Jacobs chucks. I picked up a pair of these, one from a hardware store one from HF. They do nothing but slip. The chuck key is such a cheap POS you can't even think about getting the chuck tightened up. I have a couple of the vintage Jacobs chucks and they are awesome. Probably more dollars worth of metal in the old chuck keys than the entire new chuck.
wafrederick
Holton,Mi
The pickle forks,I never use them.I call them boot rippers if any ball joints and tie rods are in good shape.I use a BFH instead,Tie rods come out of the spindle after 2 or three hits on the side with the BFH.I was taught to do it this way.
MFortie
San Diego County
Any tool related to plumbing...
I HATE doing plumbing work, hence my disdain for plumbing related tools! (Drywall is a close second...)
NOTABLAZER
Gas trimmer for sure,anything else mentioned I could tolerate for the most part.
Buck_nekid
Northern WV
A tool that breaks while trying to use it. It's typically a special purpouse tool that you have no backup for. You are then resorted to rigging up a tool that ends up being better for the task than the one you bought.
WVBrady
WV
A Sears fluorescent work light that is so easy to turn off that it seems like every time I move it, it turns off. Maybe I'll put a guard over the switch, if I can figure out some easy way to do it.
fergus
Yolo County CA
Allen wrenches. Actually allen screws in hard to reach places like on the intake manifold on my VW . Then you need the exact right allen socket to back it halfway out, then the right allen wrench/key the rest of the way (probably a ball end allen). Then when you get to the very last one, that lil ******* strips out. Then you spend the next two hours taking other stuff off so you can put some channel locks on that one you just stripped out. Then you go kick the dog.
don-vee
The dead coal city of Wilkes-Barre, PA
Any staple gun I have ever owned, doesn't matter if it's manual, electric, or pneumatic, doesn't matter if it's old or new, cheap or expensive. We can put a man on the moon, but can't make a staple gun that's capable of working one solid hour without jamming tight!
Busted_Knuckles
Northwest Illinois
Look into a Hitachi, if you need a pneumatic stapler in the future. Ive got one, Ive run at least 10k staples through it doing house wrap, and have yet to get it jammed once. I'm also shooting Hitachi staples...
