So here's a pic from this morning:
The wall is pretty much upright again. It doesn't seem to be climbing the sill too much anymore...I guess I'm gonna start jacking the wall up right at the edge of the rafters like falcon67 did in his thread.
Not a whole lot going on right now... while I'm waiting for things to shape up I'm gonna build a semi-proper workbench for my radial arm saw out of this:
Picked up some used solid core doors from the Habitat Re-store yesterday...3x7 1-3/4" thick...those things are heavy. Gonna use 'em as bench tops.
Anyway, not since there's not much else to report, I'll tell you guys a couple things that I learned thus far. While its not exactly rocket science, they are a couple things that I had to figure out since I'm not much of a builder...yet.
1). Clamps are your friend. Lumber is crooked, you need help to get it to go where you want it. Especially when you have one piece of new crooked lumber going up against an old piece of crooked lumber. Can not have too many clamps...I used them all over this project.
2). Cheap hardware can/will give you headaces. I started out using deck screws on this project. Actually, I started out using cabinet screws...and I couldn't figure out why they didn't want to drive into 2x4s. I didn't know they were cabinet screws, or that there was much of a difference until I looked at the box and went down to the hardware store. Cabinet screws have a different pitch, and the point is nowhere near as sharp as deck screws.
So I started using deck screws. I bought some bulk phillips head 3" scews from the local hardware store. Trying to drive those things through a couple 2x4s turned out to be really difficult. I had to put every inch of strength (and weight) into making sure those things would snug up...and not strip on the way in. ( I ain't exactly little, or weak). I probably stripped 50 of em the first day. After busting my *** for a while, I decided I'd see what else was available. A trip to Lowe's revealed there are many different kinds of deck screws now available - I had no idea. Different coatings, different drive patters, some made for different materials, etc. Anyway, those coated screws are pretty expensive (about $8/lb) but I thought I'd give it a try. Man, I am glad I did...I think I had to work about 1/3 as hard after that. This is what I got
They actually have a torx t-25 head on them. I think I stripped maybe two the whole rest of the project. The coating makes them bite and "drill" into the wood super easy. I never snapped one head...and have virtually no splitting, even in the old stuff I was attaching to. The other, and maybe biggest benefit was that due to the positive engagement of the torx bit on the screws (and them not wobbling around while trying to "start" the screw), I was actually able to drive screws left-handed. I'm right handed, and nowhere near being ambidextrous, but by the end of the project, I was able to drive with my left hand just as good as with my right. It might not seem like that big of a deal until you consider this: I only had to move the ladder half as much since I could stretch out on the left side of the ladder to run some screws in as well.
Anyway, thanks for reading.
