PhantomEB
Medicine Hat, AB, Canuckistan
just need to tight up hose clamps on the low pressure side and add in power steering fluid!
then when I add in battery cables to my remote battery posts in the rear wheelwell I am good to tackle a storage rack to hang off the cage in the back of the bronco. Maybe tackle the remainder of the wiring once I got power steering and brakes.
Yesterday, I put some stuff away, got side tracked on other things,
Late, I did disassemble a free B&D hedge trimmer to grease the clearly traumatized gears. with great difficulty! B&D used T-15 "tamper-proof" screws, and the countersunk holes did not allow for a TP bit in a holder. I searched through my other T type drivers and had a Stanley half drilled for the tamper-proof pin, and managed to get them out.
B&D's "Planned obsolescence" is pretty definitive in this POS - virtually no grease was on the gears, and they all looked dry; some small amount of **** slung off into one case half, but it its lubricant it wasn't intended to do more than keep the gears quiet for the warranty period. Moreover things got so hot parts of the case have melted. Not amused!
It's greased and completed enough that I need to get a couple more pairs of hands to reassemble today, and use something like ice pics or awls to keep the shells in alignment, then may need to clamp it past the plastic melt damage. If successful, hopefully it lasts long enough to hack the tons of ivy I'm fighting.
JEFFREYWisconsin
Not here in Oregon, either.
At one time, we had two red/green colorblind brewers. One day, they discovered that, while you can't hook up a CO2 canister to an oxygen regulator, you can easily do it the other way around and blew down a large fermenter with O2. Fortunately, there was essentially no pressure on the ferm, but it was a hell of a waste of O2. Turns out, the green O2 can and the gray CO2 can have the same grayscale density, so appear identical to an R/G colorblind individual. The one who still works here has learned to look a the valve (or the label) to be sure--and we rarely use CO2 in cans anymore.
I spent the first 5 years at my first ad agency as Creative Director with an Art Director who was colorblind. I had to fix some stuff some times, but other times he created stuff I hadn't considered that actually worked!
He was and still is one of the best artists I have ever worked with, he is a teacher now because the Ad game will eventually blow you out!
Beerhippie
Far NE Oregon
Ad business must be really tough!
JEFFREYWisconsin
There are more dangerous and harder ways to make a living, but the constant judgement from non creative people approving or disapproving of your work, the hours, the constant grind, the feast or famine of account management was trying at times for sure.
However for a lot of years, I loved it.
BetterDays
Progress on the new workbench
Change in plans, as this will now store more totes than larger power tools
I will be modifying the racking to store the power tools (mitre saw, scroll saw, router / table, etc)
**working to do less "put it down" when working on a project and creating a drop space.
I am also trying not to put stuff on the ground during the project, as it turns into a step hazard.
When done for the day, put it away.
Beerhippie
Far NE Oregon
I finished the 5/'37 220B I found yesterday. She's been rode hard and put up wet, but not too bad.
So you don't have to go looking for it, here's the before:
And after:
The original vent was bashed in on top and it didn't have a globe. I stole both from a 220E. The B vent is a darker green, but we'll just keep that between ourselves, OK?
I did get a nice globe, if not exactly period-correct:
I might still finish one 200A today, but I'm easily distracted by shiny nickel-plate.
Maybe I'll light 'er up when it cools off some.
TFL--
Spudd4242
Starts the morning making a trip to Lowe's to with my daughter to get a franklin stud finder.
When we returned I moved my parts washer so that I could store my power washer in its previous spots
After that, I hung my new HF 40' extension cable reel, and then put up a new garage sign, thought it would be funny to hand upside down since the guy who hit it in my yard certainly wasn't using care eitherZ
After that me a buddy spent a few hours doing two coats of. Drylock in mt basement.
Successful day and now I'm tired.
BetterDays
It's all gone too; my MIL and SIL came to visit :ROFLMAO:
One of the favorite childhood stories.
Mom made 2 strawberry pies (strawberries, gelatin filling, like a Bob Evans pie)
Put them in the basement fridge and she was taking them somewhere the next day.
My brother and his buddy come to the house, see the pies, and mom wakes up to two pie tins with a fork in each. Momma was not happy!!
This happened in the late 80s or early 90s (the 1900s! Gasp!) and still a story told with friends and family...
FLHCHAZ
Busy weekend in the garage... The Riviera got home about 4:00 on friday
When I got home from work I started getting 30 years of crud off of it:
and the dogs had to approve:
after a bath, I pushed it inside, not easy to push this beast, especially on gravel. Once I got in the garage, I started assessing things, its a little rougher than I though. Certainly not terrible though. I could not resist the temptation to see if I could get some shine on the hood
I think most of it will clean up nice enough to be a "driver".
also, about 3 years ago I built my wife and Sportster trike. She has no interest in riding it, so it was listed on Market place, and traded for this:
KwikFab
Central Valley, CA
"the 1900s.." my dude I'm gonna put you on ignore, why are you aging me like that :ROFLMAO:
MercLSU
Baton Rouge, LA
More of the weekend than "today". Setting up pallet racking, moving cabinets and contents. Been a long time coming. The rolling stairs are a game changer but setting up the racking and shelves is still a PITA by yourself.
Beerhippie
Far NE Oregon
You know those jobs where you take one look and go "WTF?"
A few years ago, we expanded the kitchen into what had been our bottling line room. That area is now the prep room. There's a free-standing, four-legged sink in the prep room.
We just got a new back-of-house manager and yesterday she let me know that the drain plumbing had been falling off the sink on a regular basis. Her predecessor had simply been putting it back on, but she wants it fixed.
The sink sits almost right over a floor drain, which is back against the wall. The sink drain drains into that with an air-gap.
WTF? I'm betting you can tell what's new and what's old. A co-worker did the plumbing and I had never really taken a look at it. Why a P-trap for an open drain pipe? Why did it wind back around one leg of the sink when it's a straight shot to the floor drain?
Now to find out why the lawn sprinkler system ain't sprinkling... and how my drip-irrigation timer for the flower beds got changed to water for an hour instead of ten minutes....
Beerhippie
Far NE Oregon
The hose for the front lawn sprinkler--we use in-ground pop-up for most of the lawn--had been stuffed full of leaves, which ended up in the sprinkler, which is mounted on a ten-foot pole, making access easy. Fortunately, I had a spare, so just swapped it out.
That and the timer I'm putting down to feral children... which are why we can't have nice things anymore.
Spudd4242
Dropped my kids off today to my in laws, swapped out the handle for their door into the garage from the house; and then swapped an on outlet in their garage they were duck taping the plug into. My father in law could fix these things; she usually gives him a few weeks and then asks me: so not my garage but a garage none the less
Blue Chips
Maine
I put my 1954 M37 up on my new lift for the first time a few days ago. I did some experimenting to determine the vehicle's center of gravity (CG) in its current state and weighted the rear of the chassis to shift the CG so that I could place the CG directly over the center pivots of the lift for stability while allowing clearance for the tires at the ends of the platforms. I think I got it very close.
It seems very stable, the safety locks work well, and of course I make sure the locks are fully engaged before walking under the lift. I can raise the chassis several inches higher than necessary to stand up under it. With the top and windshield installed, I wouldn't be able to raise it quite as high. The garage has an 11-foot ceiling.
My cunning plan is to 'attempt' to install the new brake lines, fuel lines, and wiring before winter, after which I would move the chassis to our old garage (my shop), which doesn't have a lift, but I think most of the remaining work could be done at a more convenient height, so theoretically no lift should be needed. That would allow me to park my daily driver truck in the new garage over the winter. I would just drive over the lift as if it were a speed bump.
I'm in the process of installing a standby backup generator for our home, which takes priority over the M37 for the next week or two, but things seem to be moving in the right direction.
Skyman
Central Maryland
It seems very stable, the safety locks work well, and of course I make sure the locks are fully engaged before walking under the lift. I can raise the chassis several inches higher than necessary to stand up under it. Of course, with the top and windshield installed, I wouldn't be able to raise it quite as high. The garage has an 11-foot ceiling.
Would you care to share more info about your new lift? Looks intriguing.
Blue Chips
Maine
It's a model "AK-X95 Full Rise Scissor Auto Lift." It seems to be quite well constructed, and so far it works really well, although I wish they would have put more effort into producing a decent English-language instruction manual. There are multiple sellers here in the US, but I don't have any way of comparing them. Feel free to PM me if you'd like more detailed feedback.
DAVE94LIGHTNING
Machined my first part on the Home CNC mill. Shot some camera phone video of the process. Had my finger on the STOP button the whole time hoping it wouldn't crash and burn but it did pretty well and machined a usable part without any catastrophic consequences.
LeonardY
Southern California
Killed about 8 mosquitos with the electric swatter. One fly... Well I stunned it and then stepped on it.
Did a bunch of measurements of the 3D printer. Working on another modification.
Dug through a cabinet and decided that a lot of the stuff can live in the shed. But I didn't find what I was looking for.
strength_and_power
My GF is a middle school teacher and had been joking about needing a “fasten seat belt” sign for her classroom. Bought a DXF file of said symbol on Etsy, sent it to my friendly fan shop and had it cut. Used an old enclosure for an alarm system at work, cut and mounted the sign to the front with a $14 pool light from Amazon as the light source. Spent way too much time playing with the light’s remote and app. She should be happy.
