Restoring Double Hung Windows
Buckaroo5
Central Ohio
I am working on double hung windows in a 100 year old house. Most of the sash cords are broken and I was considering using chain rather than rope. Any reason not to?
Wrench97
Southeastern Pa
When I was a kid my dad replaced the sash cord on a late 1700's early 1800's farm house we had, used the cotton cord, my uncle was trying to talk him into chain dad said the cotton will be here long after I'm gone he sold the house 15 years later and moved so I guess he was right.....
Stuart in MN
Minneapolis
I thought I responded to this yesterday but I don't see a post...anyway, I'd stick with regular old sash cord. The originals presumably lasted for most of those 100 years, so the replacement cords will still be there long after you're gone. It's what I use in my house whenever I have to repair a window (I have Andersen windows, original to the 1913 structure.)
Fav Onefour
MN cold and hot
I have not used chain. Do you need different rollers?
I redid all the windows in one of our houses using regular sash cord. Two of the rollers were shot and replacing those was more work than doing cords. The home was built in 1914 and the windows are all original. Not sure how often the cords had been replaced? I had six broken cords in 28 double hung openings.
BTW, if you are already doing one cord in an opening, just do all of them. Cord is cheap. Make sure you get the right size.
Buckaroo5
Central Ohio
Good point about size - I was figuring they were all 1/4".? The opportunity for the knots on the weights to become untied is the reason I was considering chain along with the longevity. This is my son's house but I did a number of windows in a house I owned in the '80's - 90's and used cotton cord so I know how much effort is required - for me, this will be a long term effort including reglazing/repainting the windows. The windows have frosted pain outlines on the upper sashes which I think are very cool - my old house had leaded upper sashes and I love these older architectural details. My son bought in the same neighborhood where we used to live. The cost of cord vs chain is minimal compared to the effort. Also, the roller question is getting to the root of my original post. Does sash chain require different roller? This is the sash chain I was considering....
wood02
Evansville, Indiana
I used nylon rope. House was built in 1925. It has (13) - 64" double hung windows. I used 2" pvc pipe and cut the pipe to fit in the "air gap". I dropped the weight inside of the pipe then packed insulation around the pipe still allowing the weight to do it's job. I do not use the upper part of the window. House was originally heated with coal. The 9 ft. ceilings (I think) was an effort to allow the fumes that may have collected in the house from the coal and then the double hung window came into play (upper window lowered). I did this in 1992. I have not had a problem with them "yet" and do not expect any in my lifetime.
