Between 485 & 705 SQ/FT Bob Heine's Auto Emporium
madison069
Monroeville, PA
Turns out the screw isn't stainless steel so it came out and stuck to the lightly magnetized S2 1:0 bit from my ORIA bit set. I have smaller size screwdrivers in the watch repair kit but they aren't magnetized.
That ORIA set of bits has gotten me through a whole bunch of electronics repairs and for $15 has earned its price many times over.
I feel like I have a lot like this already, but I ordered this one incase I didn’t… 🤦🏻‍♂️
gman007
West Michigan
It's so expensive you can't afford a good digital camera or smartphone?
Is it Metabo?
1- I am just poor and can not afford a bad let alone a good digital camera or smartphone! And currently I am chiseling this message on an iStone tablet manufactured in 40000 BC by cavemen! :)
2- The photo is in fact is from internet but the resolution is low. However when I saw it , I thought it was funny.
3- In fact, I also thought the low resolution might make others curious as to what the brand is and start guessing, like you did 😀!IMG_6325.jpeg
kaymccampbell
Upstate New York
Hilti? Craftsman? Skil?
CNC_RICK
Wisconsin
Bob, my book finally came in the other day. It's the one Squankum recommended - How to Make your Car Handle. The reason it took so long to get one was my fault, It took me a while to ask Cheryl to order it. Looks pretty good, though. She ordered it through Amazon and when it came, inside the front cover was a slip of paper that showed that the book really came from Half-Price Books. I was surprised to see that. I used to go to Half-Price quite often and always hauled home a good helping of books. I thought Half-Price was kind of local to the Twin Cities, but don't know for sure about that. Anyways, I've read through the first chapter and it was kind of a primer of what to expect out of the rest of the chapters in the book.
CNC_RICK
Wisconsin
Just a little powder to encourage the already slippery plastic to wiggle about some more.
I didn't really mean caster plates for measurement so much as just slip plates to let the suspension pieces relax, not be bound, so measurements of things like caster and toe can be more accurate. Another old method was two squares of linoleum flooring with some oil between them.
And as for measuring caster, I hadn't thought of that. I've spent my life in a "that can't be adjusted" world -- or, my motorsports experience for caster and sometimes camber was "YES! As much as it will allow us!" and then, toe. I was living in Stock class world, or another class whose rules were overlaid on top of that foundation of Stock class rules. In the case of caster in the latter class, once we realized Caster Is Good, our limiting factor was the size of the hole in top of the strut tower. So basically at the rearmost spot on that circle, and caster could be created with much leniency in the rules with parts/struts down at the knuckle.
So that's how my weird little brain reacts to these topics.
Caster helps with the car steering wheel return to center, ( like a shopping cart front wheels) but the angle that happens with your ball joints and the patch on the road, I think, would do more. Once you turn your wheels, the car lifts off the ground, the more you turn the steering wheel. I think caster keeps the steering a bit from getting squirrelly, but think the ball joints angle does more. (I should check my caster for hair in the wheels.. ha. (That was classic))
CNC_RICK
Wisconsin
The reason I say this is that I had an Allis Chalmers tractor with zero caster.... I made a tow bar to fit the front end loader, and hooked up solid to the bucket on it, hooked up to my dump truck... What a disaster... That tractor had no caster to the front wheels... As I pulled forward the first time, with the dump truck, I only went about eight feet.. stopped the truck to check on progress... Cripes, the small tractor was mostly in the ditch and really almost tipped over. Good thing I didn't go any further... I tried the same thing on a John Deere "A" with a tow bar behind a Chev pickup. The tractor had a wide front end on it, much like the Allis "B" had... No contest. I hauled the Johnny with the tow bar about 20 miles to get it home behind my pickup.
CNC_RICK
Wisconsin
Was it caster or camber? I dunno... The Allis had a mustache looking front axle on it. The Deere had a real angle on the front end on it with much taper on both sides that I would call king pins at that point...
Bob Heine
Boca Raton, Florida
Bob
Thanks for the ORIA Amazon link. I just ordered a set.
No problem @gman007, I don't use the set every day but boy, when you need a weird little screwdriver bit, it's great to know where the set is.
it's always been my theory that the tyre/tire pressure stickers on the door jamb or wherever are written by auto company marketing people rather than engineers for a softer ride. I'd always put a couple more psi in than the sticker advises.
Geoff, I run the 35 and 40 profile tires on the Cadillac at 36psi and the 50 profile tires on the PT Cruiser and Corvette at 34psi.
Bob, appreciate the link to the Oria tool kit. Added to my list.
I've got a similar Citizen Eco-Drive that I used to wear daily until I went back to a Timex Expedition Atlantis. I've always had good luck with Timex watches and generally end up back with one on my wrist.
Marc, much as I love the multi-button watches, it really looks stupid when I'm biting the watch. I do have one of those health monitor doohickeys but it was strapped to my stump and looked just as stupid and sucked up a lot of time checking vitals. It did more to raise my blood pressure than any other device in my collection.
@Squankum, I think that powder in a bag would work, I just know my uncanny ability to make a mess would come to life a few seconds after I released the jack.
I can't remember if I had caster adjusters on the BMW when I installed the Eibach springs but I know for certain that I installed the cam bolts on the PT Cruiser. I also know I gave the setup instructions to the flying monkey at Tire Kingdom but I have no way of knowing if he followed them.
And thanks to the Amazon prime it arrived the next day
@gman007, I recommend you try them out and put them in a logical place like a screwdriver drawer. Kay put me onto a set of jet cleaning wires on a ring and I put them somewhere that I wouldn't forget but it seems I was able to forget where that was when I needed to clean the nozzles on an oscillating sprinkler today. Thank goodness I bought a set of numbered drill bits - a 59 in a pin vise worked great.
One of the most valuable aspects of this forum and guys like Bobs thread……
Knowledge.
Tempted, but I will ***** about not buying a set to add to my impressive collection of unused or once used tools.
Rian, I too have an impressive collection of unused tools. The tiny screwdriver set has been an exception.
A man can never have enough tools (used or unused)😀
If diamonds are a girls best friends, tools are a man’s best friends!:)IMG_6319.jpeg
@gman007, I've looked at the big sets and I know it might save me money but I end up buying one, two or three at a time. I've settled on the Milwaukee battery tool line but I own just about every brand tool available. I have very little corporate loyalty left.
What does one call themselves if they got tools for all 4?? 🧙‍♂️
Cody, I've been told I'm a tool ***** but I feel like I'm more on the 'John' side of the transaction.
Split personality?
Jeff, I think I'm more of a DID (dissociative identity disorder) personality.
Cody, you've got two garages at the moment so it's a perfect time for some duplicate tools.
Ps
Bipolar tool nuts are held in higher esteem than just plain old tool nuts by all manly men! 😀
@gman007, Bipolar has such a negative reputation. It makes me laugh and cry at the same time.
And if you don't have any children? Then you are buying Bosch or Fein I suppose? :headscrat
Patrik, our son has 9 children and he uses Bosch tools on the job. Damn, I went and Googled Fein battery tools and a magnetic base drill popped up -- Home Depot has one for $1,449.95. I had to Google Magnetic Base Drill and a Vevor unit with twist and core chucks included for $189.90. I think I found another use once tool I need to have....
Jedi young, Answer your here is 😀
@gman007, many times I can't justify the brand name stuff and I buy an off-brand. I have a little 4V hex driver for the light jobs where I don't need the brushless monster from Milwaukee.
And to top off that tiny screwdriver bit set, I bought a General AA powered driver to speed up the job when there are a bunch of tiny screws involved.
Is it Metabo?
@Squankum, I spent way too much money on Minolta 35mm SLR and Konica Minolta DSLR cameras and they just sit in an office cabinet. I can't stand using a smartphone to take pictures so I settled on a couple of Canon PowerShot SX410IS cameras (mine's black and Liane's is red). They are lightweight, easy to use and take decent photos. Bought first (used) one for $50 and the second (used) one for $70.
Well, that one sent me on a weird tour of rock music I was not aware of.
@gman007, I prefer clay tablets that don't require a hammer or chisel to put my thoughts on it. My handwriting is terrible but to make it worse I like to use a fountain pen. A bunch of them use cartridges but my most used one is a Parker 51 that I fill from a Parker Quink bottle.
Kay, maybe all of those.
Dan, a Festool in my collection wold be a crime. I think one has to master using the basic tools before upgrading to the epitome of tools. Our son-in-law bought himself a Martin guitar to learn to play. I believe it left its case once. I sprayed two cars using an old Craftsman suction gun before investing in any Iwata HVLP guns and even then wouldn't buy a Sata gun until a totally ruined one showed up for $100 -- my time at $1 an hour probably got close to the price of a new one.
G.D tool snob...🤣
Scott, pretty sure everyone on this site is a tool snob or a wannabe tool snob.
No, no......G.J. tool snob :lol:
:beer:
Dan, we stand corrected!
kaymccampbell
Upstate New York
I have a few sets of those. The newest one goes on the welding cart because they're designed to clean torch jets. The rest are in the toolbox drawer with the forceps and vascular clamps and Stihl chainsaw tools and hacksaw, and pickup fingers and stabby things for removing o-rings and other like stuff.
madison069
Monroeville, PA
With that train of thought, I technically have three garages (there is an attached garage at the old house), therefore I should order another set for the attached garage, it will come in handy to not have to go to the big garage for minor repair in the house. :giggle:
gman007
West Michigan
Bob
I always put tools, parts, etc in the most logical places where any idiot will remember! But a few weeks later, when I need these sobs , it seems my brain’s logic has changed and I can not find them in the current most logical places. Some weeks later when I am searching for something else that I need and can not find, I find the tools that I needed weeks back.
They says squirrels are responsible for a lot of reforestation because they hide the nuts and acorns in most logical places but later seem not to be able to find many of them. I suppose you and I might be related to squirrels but alas in our case the lost tools do not grow and produce more tools (wouldn’t that be nice?? 😀)!
TwoBytes
Canberra, 'Stralia
I think they're Parkside...
I'd never heard of them before, but I just went down a Google rabbit hole. Apparently they're popular in Europe (they're the in-house brand of the German retailer, Lidl), and they're good enough for the Terminator...
Craptain
Tampa Bay FL
I too occasionally use a fountain pen 🖋️ and I have 2. My favorite is a Cross that I paid way too much for many years ago. The ink I I use is as near to waterproof as I could find. It was my preference for log entries until the company changed no carbon copy logs. Then I had to change to a ball point. 😒
I also have a set of calligraphy pens that I never mastered that sit unused.
CNC_RICK
Wisconsin
I see your obsession with writing instruments. I took every mechanical drafting class I could in high school. My senior year, I took Architectural Drafting. Every single one that fit my schedule. So I started getting interested in mechanical pencils of just about every flavor available (with a high school student budget) HB for dark lines, 2H and up to 5H for everything else. I tried a fountain pen one time on one of my blueprints. I didn't wait long enough for the ink to dry, so my T-square and plastic triangles really made a mess of things. I'm not very artistic (actually, not at all) but have tried to sketch a horse in pencil. Most of my attempts at sketching animals end up looking like a bloated woodtick. Ha. But I have several very nice pens that I don't use and really just want to own them for the quality built into them.
CNC_RICK
Wisconsin
Here's my pen of choice nowadays... It is in my shirt pocket every day. I'm using it right now to write this with the rubber tip on the top end. You can see that the ruler markings have mostly worn away, there's a small screwdriver with one end being Phillips, the other end being a straight driver, if you unscrew the cap. I have a small drawer full of pen pieces, to at least keep one pen alive and working...
CNC_RICK
Wisconsin
Bob, I'm on chapter two in my book. Ha, not like I'm going to do a play by play of my readings every single week, but chapter two talks about understeer/oversteer. That was one subject I was looking forward to understanding. So far, it makes perfect sense. Vectors, center of gravity, based on weight per wheel, centrifugal force, making corners in terms of G-force... I had to wipe away some drool a few times... I love learning about this stuff. And Squankum, if you are listening, oversteer is when your back tires let loose of traction and you have to counteract with steering in the wrong direction to stay on course. Understeer, your front wheels lose traction and you end up going in a straight line. Braking and acceleration/deceleration can help or hinder you in both circumstances. Braking moves the center of gravity forward in your car. More throttle moves the COG more toward the rear of the car. The tire rubber compound makes a difference in traction. What works on a race track might not be the best on a street car. (Think rain and lots of deep tread verses a slick on a race car). The book really is geared toward race cars, and that, in my mind, is good to learn. Race cars and drivers really push the limits on just about everything. We can all learn from their experience. ( At least me...)
Squankum
Southeast
All of those things happen on street cars, too! They're just set up for understeer, and that's okay with me. Even tire slip angles happen on the street, just at a lesser degree.
It really is a good book.
Bob Heine
Boca Raton, Florida
Bob: I always love reading your responses and posts so keep up the great work.
how's the health for you and your bride down in muggyville?
stay cool!!
Drives, thanks for the kind words,
Also, thanks for checking up on me. Here's the looong story:
I know you've been doing your best to stay healthy and maintain or improve your strength. As you approach your seventh decade, the side effects start to show up and it's hips and/or knees letting you know how long you've been stressing them. Please take care of those things sooner rather than later. At a younger friend's funeral I overheard: "He was so healthy and fit so dropping dead on the tennis court came as a complete surprise."
My heart issues reminded me I was 75 when AFib (atrial fibrillation) came knocking on my door. Couple of cardioversions (mine involved the word "CLEAR") temporarily fixed the problem but when it came back for a third visit, the surgeon shoved stuff up my femoral artery into my heart and fried or froze the parts of my heart causing the problem. I've always had a slow heartbeat but when it scared the **** out of the doctor and nurses doing another invasive procedure (involving the hole right next to that femoral artery) it was suggested I get a pacemaker. What scared the **** doctor was the pulse alarm never shutting off. According to Gargle: "A heart rate exceeding 100 BPM (tachycardia) or falling below 60 BPM (bradycardia) while at rest may indicate a potential issue..." My pulse rate at rest was 37bpm but it would quickly go to 130 during a heart stress test. The little smartphone in my chest lets my pulse rise quickly but provides little electrical shocks whenever my heart tries to slow below 60bpm.
About three weeks ago, Liane fell in the garden. She loves working on her gardens and often bends over to pull a weed or pull leaves out of her bromeliads (the Pineapple is a member of this family of plants). While bent over, she took a step and something tripped her. She fell the short distance and hit her right shoulder. It began hurting the next day but she was going to see her Pain specialist the following week. He moved her arm through a full rotation of her shoulder and told her it was an arthritis issue. We saw our primary care physician this week and after poking and prodding her shoulder, prescribed an x-ray. There is a lab connected to our big fancy hospital on the first floor of his building so she had one taken on the way out. Next morning (this past Friday) he called to tell us nothing showed up on the x-ray and gave her the name of the orthopedist he uses. Hopefully the first proposal isn't a joint replacement.
An hour before the call, Liane asked me to move a pot full of Aloe plants to one of her potting benches. I picked the pot up and moved it to the granite slab that's sitting on a couple of wooden saw horses. Turned around and was heading back to the house when my bare foot caught on a section of metal edging that keeps the curved section of 12x12 concrete pavers in place. Over the years the pavers have settled so the metal edge is an inch higher. Feeling myself headed for a fall, I took a step forward and simply extended my fall. The side effect of the Prednisone (and generic Zytega that suppress testosterone, the fertilizer for prostate cancer cells) causes muscle weakness, especially in the long thigh muscles. I extended my arm to break my fall, now headed to a block wall, and impaled my left chest on the gate fence post next to the wall. That slowed my fall but I still bounced off the impaler and landed on the pavers. My hand did a good job slowing the fall but I still hit that post hard. I know my hand helped because the gate latch bent and cracked the wedding band. Liane immediately sprang into action and slathered Arnica Gel on my chest to prevent bruises to form on my otherwise perfect chest. It seems to have worked, with the only evidence being some red spots and a line from the edge of the post. That white scar is the pacemaker installation locator:
The shot to my left chest was concerning because that's where my pacemaker is located. After lying on the walkway for five minutes (felt like five but probably only two) while Liane repeatedly reminded me to breathe, even when I suggested the blow was to my chest and not my head so I still remembered how to breathe. Got up, went in the house and got out my cellphone and Kardia Mobile device and determined my heart controller was still working as designed. Put the pulsometer on my finger and the blood pressure cuff on my arm. Pulse 60, oxygen 98% and blood pressure 128/74 and confirmed 60 bpm. I told our primary care doctor about the incident during his call about Liane's x-ray and called my cardiologist (his office monitors my pacemaker from the wi-fi box next to my bed). I assured both I would schedule a visit if anything changes.
As to the ring, it looks like we'll be shopping for another. My first wedding band was cut off my left hand when I arrived at the hospital in 1965. Had they waited for Liane to arrive and make the decision to amputate or try to re-attach my useless left forearm, they could have cut the damn finger off instead of ruining a gold band. Pawn shops, here we come (I'm thinking another flimsy one that won't rip my finger off when this sort of thing happens again).
Scene of the 'stupid' crime:
Kay, I'm going to order a few more sets. They are much easier to use than a drill bit because they have that loop on the end of each one. I can also grab the whole set without worrying about scattering a bunch of my best guess drill bit sizes around the yard. My forceps/vascular clamp tray sounds like a good spot, along with both welding carts. Turns out Jeff's river has a set of four on sale right now:
Cody, you know I always have thoughts of trains of thought that go off track. I forgot about your attached garage. You realize this is the GJ so buying triplicates of every tool is completely reasonable and respected. Have you thought about a trio of forklifts?
Bob
@gman007, after a very brief search of the Internet, I discovered the reason for the problem:
"The left brain/right brain" concept refers to the idea that the two hemispheres of the brain are specialized for different functions, with the left hemisphere associated with logic and language and the right hemisphere associated with creativity and spatial reasoning."
Obviously my right brain put the thing away in the perfect, most ingenious and space saving place possible. When my left brain goes looking for it, it's not in the logical location and I utter a continuous stream of curses until have used them all. The next time my right brain is conscious, I find the thing exactly where I put it. I am fully aware that neither side of my brain works very well.
Mat, I think you have the right term but the image that term triggered in my mind was more along these lines:
[I believe I have to pay to show the movie character Hannibal Lecter but CPAP Bob is a freebie.]
Mat, thanks for diving down that rabbit hole. I worries me that the tool requires the strength of the Terminator to lift it. The reason I buy so many Milwaukee M12 tools is for their lighter weight. I do buy other battery powered tools but they either take AA or AAA batteries or have a charging port (and are therefore disposable when they stop holding a charge).
Andrew, I had Parker 21, Cross and Schaefer fountain pens that i really liked. The Parker was old and didn't take cartridges so when it wouldn't refill itself from an ink bottle, I stopped using it. When our daughter asked for a calligraphy set, I bought two. She mastered the skill and made some really nice unofficial invitation and award cards I gave out at IBM (boy do the managers who didn't do that show me some hate). I should probably be embarrassed that I have 20 fountain pens and all the tools and parts to repair the non-cartridge ones). The calligraphy pens are not shown but this is the current stable:
When I was simply signing store-bought cards, I signed them with calligraphy pens but now I use Hallmark Card Studio on my Windows desktop (There's a Mac version as well). They also have IOS and Android apps if you prefer to send electronic cards.
That Parkside drill looks very similar to my Bosch. :headscrat
:beer:
Dan, if the Bosch batteries fit, our son would be interested (if the price is right).
They are German cousins! :)
@gman007, if they're first cousins, I don't think you can legally put the batteries in them both.
Rick, it's not a healthy obsession. The pen side has already been confessed but the pencil side is about as bad. The mechanical pencils are 0.3, 0.5, 0.7 and whatever size the IBM Electromagnetic lead is.
Now you tell me I need more variety in my pencil leads. I'm beginning to perspire....
Rick, I feel a little better but I'm looking away. I can only take so much pen and pencil overload.
"Come with me if you want to drill."
@Squankum, is he talking to my maid?
Rick, I have read a fair amount about the whole subject but in bits and pieces from magazine articles in auto enthusiast and science magazines. I tried to explain it to Liane but she wasn't interested so I took her to an empty parking lot after a decent snowstorm in the Hudson Valley. I showed her how to recover from oversteer and when trying to turn and brake at the same time be able to decide if changing direction or stopping was the desired result. Never told her it was 'understeer.'
All of those things happen on street cars, too! They're just set up for understeer, and that's okay with me. Even tire angles happen on the street, just at a lesser degree.
@Squankum, in Florida they require people to renew their driver's license every 10 years -- until you reach 80 when it's every 6 years. I am doing my best to control my impulse to drive like I did 60 years ago, avoid tickets and above all not have an accident. At $4,700 a year for our three vehicles, a little OOPs could be very expensive. Should I ever get the big block Corvette back on the road, all bets are off.
OutlawDrifter
KS
Bob, it's been about 7yrs+ since I've worn a metal wedding band. My original is made out of cobalt, which cannot be sized, it just breaks I guess 🤷‍♂️. They (Helzberg), would however, replace it for "free" with the care plan purchased. I'm not willing to part with it, biggest problem is the 35lbs I've gained since my nuptials :LOL:.
I've worn a few different silicon rings over the years, some look very similar to metal, some didn't. I like how they don't scratch the finish on cars, attract weld activity, or simply tear away when caught where your finger shouldn't be.
madison069
Monroeville, PA
Let’s start with one first, but I’ve been kinda day dreaming of a small front loader tractor. But be nice if it was 36” wide instead of the 42” that was available to rent.
Bob, don’t be bouncing on the ground now, I’m sure you can’t bounce as good as you once did.
As for your ring, I’m thinking of getting a silicone one myself. I quit wearing my ring a long time ago when I had a close call. I believe my ring is in my little box on the dresser.
madison069
Monroeville, PA
My original wedding ring is cobalt too. Seemed to be a good option at the time. Considering I gave $150 for it, I thought it was nice for the price.
kaymccampbell
Upstate New York
Dingoes are under 36 inches wide. Mine will drive through a 36 inch door frame.
madison069
Monroeville, PA
At one time, I had a pen and pencil hoarding issue. I amassed a huge collection of free pens and pencils during college from those free give away stands. They all worked ok enough to not buy any special pens or pencils. Then at one point I started buying pens cause I wanted something specific and found it. But now it’s been so long since I’ve written enough to justify the obsession for pen type that I forgot what the pen was I liked.
Now I just buy the G2 pilot pens when I need any as they come in bulk at Sam’s. Problem is I bought a bulk pack some odd years back and haven’t used a pen’s ink to start a new pen yet. The few checks I write just don’t use up the ink like I did in college note taking days.
Pencils I just stick with the basic bic .7mm mechanical pencil as my kids steal my pencils anyway.
madison069
Monroeville, PA
The rental places had a 42” bucket for the dingo mini skid steer and no smaller options. Seems it wasn’t a high demand so they didn’t keep smaller sizes.
The opening I was dealing with was 48” and I didn’t want to risk hitting the wall.
CNC_RICK
Wisconsin
Bob, I have nothing to offer this week. I haven't read my book, I haven't done my homework... Nothing. Nada. Dang overtime. I'll get there, I promise. Sorry about your medical issues. Hope to write more this weekend....
