sjoseph316
- Joined
- Nov 20, 2023
- Messages
- 20
Hey all!
I want to put a sub panel in the basement of our addition. The main breaker box is 65 feet from the location I want the sub panel. I need 220 in the sub panel because I will be transferring the stove and dryer to it from the main.
I have 200 amp service and the sub panel I bought is a 125 amp. The addition is a big living room, kitchen, garage and rec room. The old kitchen will become a mud room and the old living room will become a spare bedroom. So the only things I will be adding to the entire load are some outlets and lights, and I will be eliminating some outlets from the old kitchen and living room.
Does this look correct for what I’m trying to do?
125 amp sub panel 65 feet from main, from the basement of the house to the garage of the new, they are side by side no wire will be outside
100 amp breaker in main panel to run sub panel
2/0-2/0-2/0-1 ALUMINUM SER CABLE
Also, If the 2/0-2/0-2/0-1 ALUMINUM SER CABLE is good to use, does it have to be in conduit if the whole run will be inside?
Thank you for the help, much appreciated!
