Electrical conduit?Trying to connect 4in SCH80 to 3in SCH40. What is the easiest way to do this. Menards just seems to have 4inSCH40 to 3inSCH40 adapter
Have you tried the adapter?Drain pipe. Its 4in SCH80 at my septic tank im installing
That's what I'm thinking didn't know about using them underground thofernco coupling?
Same . OP did not get a sch40 coupling /reducer.Just use the 4x3 DWV coupling. The OD of sch. 40 and 80 is the same. I bet you grabbed an SDR 35 coupling, SDR pipe has different dimensions.
Appears i got the correct one
Now post a pic of the pipesAppears i got the correct one
Menards carries DWV reducing couplings, SKU 6892076B. Your adaptor is for Sch 40 to SDR. You will probably need to go to a plumbing supply warehouse to get a true Sch 40 3x4 adaptor. I believe the Nibco part is 4618. And it is a bushing adaptor, not a coupler.
I wouldn't bother with a sch. 80 coupling, just use a 4x3 DWV coupling. This is just for the waste line connection at the septic tank. I'm surprised he is using sch. 80 PVC, I've only seen sch. 80 PVC used for underground drain/waste once and the engineer specified it due to traffic loading.4" SCH80 Coupling (Female), 4" x 3" PVC Reducer Bushing (SCH40), then 3" SCH40 Pipe or Coupling
If you're concerned about pressure rating or mechanical fit, you can order SCH80-specific bushings online, but SCH40 parts are often fine for drainage or low-pressure setups.
Why can't I delete a post i started?I think the issue is that the OP has purchased a 4"SDR (around sch. 10) x 3" sch adapter as other posters mentioned. The receptor drawing posted above shows it to have a 4" Sch 40 outlet. Both 4" Sch 40 and Sch 80 have a 4.5" outer diameter, so the hubs would fit each other. OP just needs to get a 4" sch x 3" sch reducer.
If using a Furnco check your local codes, Many require shielded couplers to be used underground.
Edit: Didn't look at the above sku initially, but we are both basically saying the same thing.... (OP has miss-identified the outlet as sch. 80 due to buying the incorrect
No eat I'd put a fernco rubber coupling underground as a permanent fitting.I think the issue is that the OP has purchased a 4"SDR (around sch. 10) x 3" sch adapter as other posters mentioned. The receptor drawing posted above shows it to have a 4" Sch 40 outlet. Both 4" Sch 40 and Sch 80 have a 4.5" outer diameter, so the hubs would fit each other. OP just needs to get a 4" sch x 3" sch reducer.
Edit: Didn't look at the above sku initially, but we are both basically saying the same thing.... (OP has miss-identified the outlet as sch. 80 due to buying the incorrect part and needs a sch x sch reducer)
Post 11 at 4am this morning. Yet everyone ignores it.I think the issue is that the OP has purchased a 4"SDR (around sch. 10) x 3" sch adapter as other posters mentioned. The receptor drawing posted above shows it to have a 4" Sch 40 outlet. Both 4" Sch 40 and Sch 80 have a 4.5" outer diameter, so the hubs would fit each other. OP just needs to get a 4" sch x 3" sch reducer.
