YesIHaveAHammer
- Joined
- Jun 1, 2025
- Messages
- 843
Couple of things I spotted recently. What else have you spotted? How would certain changes reduce the manufacturing cost?
Exhibit A - Crescent indexing flat pry bar (DB18X, or in recent years updated DB18X-06)
The original has a hex stock shaft, terminating in a single tongue which fits into a Y on the the claw part. The newer has a round shaft and the arrangement is reversed - now the single tongue is on the claw, and the molded/cast Y is on the shaft. Not sure if the shaft diameter remains the same but if it is, round would be more metal, but I expect there's also some differences in how they're formed. This finish has also changed from a rough looking grey, to painted black. The edges of the claw part are no longer as sharp.
Exhibit B - Snap-on rigid carbon scraper CSA8C (model number unchanged)
The gradual taper from shaft to the blade area is gone, now much more abrupt. Reducing the cost of grinding, or a strength improvement? The older shape was also present on the now-discontinued SGCSA8 (left in 3rd image, credit to Last Best Tool for covering this).
Exhibit C - Hazet bit set 2240N/36
The finish has changed from a dark grey to a bright silver. The shafts now have a round section which accommodates a coloured size ring. Best case scenario this is all simply cosmetic because people like shiny colourful things.
Exhibit D - Milwaukee M18 Surge 2760-20 (model number unchanged, serial H16A vs H16B)
So this is more complex but thought it worth mentioning, reports here that newer ones are less powerful and less reliable.
