Fixr
SW VA
Here's what i tried to describe:
Much better. You can even hang them in these holders.
We buy mosquito coils literally by the gross. And the fiberglass net holder bottom pieces work well with the terracotta holders that come with rock wool or something like that. Drop right in. makes the whole thing stay in place better.
Beerhippie
Far NE Oregon
We used those holders on a sailboat. No unsecured burning stuff onboard a boat.
Old Man Roger
Palm Coast Florida
Considered it but it's really out of the way.
I can't comfortably place my feet on it being that it's inward and I'm short.
Customer is 5'11 or 6'0 give or take.
Again, I’m probably just being over cautious. I’ve left some damn near serrated edges improperly using a plasma cutter by hand.lol
Obviously your brand new and properly set up table will have a much cleaner result. :beer:
KwikFab
Central Valley, CA
Even the old table left perfectly squared up edges, no serrations at all.
Going at it by hand with a hand torch though did leave slight serrations!
Zrsnopro97
Changed a noisy serpentine tensioner on the wife’s Odyssey, then got to play a bit with my stuff. Got a new Vintage Speed shifter, shift coupler, and delrin bushing for my old beetle. Started on removal of the old stuff and clean up. Brought out the old craftsman bench grinder to wire wheel the crud off the old shift rod. Always pleasantly surprised how quiet and smooth this grinder is. IMG_1916.jpeg
jawstight
Used a few sacrifical tools today, a 14mm 6pt. socket, a 3/8" drive 2-1/2" extension, and a 1/4 to 3/8" adapter, and rigged up a way to raise and lower my drill press table with my right angle drill.
I didn't want to do anything that would prevent me from putting the original parts back together. And I didn't want to rely solely on the drill motor every time I used the press, or for fine adjustments of the table. So I drilled and tapped a hole in the side of the socket for a set screw, (in the red circle). If necessary I have a deep socket that will slide further onto the shaft leading into the worm gear if the short socket doesn't hold up. I then ground a flat spot on the side of the extension to accept the set screw that holds the original crank in place. Mounting it as I did allows me to still use the hand crank for finer adjustments as well as when I just have to move the table up or down once. I then ground the ball bearing in the adapter flat (in the green circle), so that it slides in easily, and then out of the extension without pulling the extension out of the socket.
Now, with a little touch on the variable speed trigger of the drill I can move the table up and down quickly. I don't have much room between the shaft of the press and the shield and that's why I'm going with the regular socket instead of the deep one, at least for now.
phred
NC
Working on a 55 T-bird for a friend. Needs some tlc, a little wiring repair and a water pump.
JEFFREYWisconsin
Yesterday I cut down some cardboard boxes that have to go to recycling on our next trip to the dump, I also fixed the seat on my mountain bike & put away some of the lingering tools on my workbench.
my only accomplishment yesterday was crushing a million boxes and putting them into another box to take to the curb...oddly satisfying! IMG_4310.jpeg
Jay__Dub
Cold Country, Canada
Finally, got those rusted ******* bracket bolts out. Impact gun would not touch the top one. Sometimes you have to get creative, and hope for the best. I turned the jack with my impact gun, and kept my distance just in case. 2 1/2 hours to get 2 bolts out. Mercy.
I thought I might rebuild that caliper, but I'm not going to have time I have to get the back wheel off next, and then start hauling wood. Maybe this winter I'll rebuild it. Always wanted to try that. Kits are cheap enough.
