gizardlizard
This is a really cool bearing installation tool I bought for work. It’s designed to be able to install bearings over fairly long shafts. You can’t always install bearings with a press. Lots of times, it’s quicker, faster and easier to install on the machine. Although this install is for an electric motor, I just did it for demo purposes. In this case, the bearing is a number 6203. You look that number up on the included chart. The chart shows to use a letter “A” shaft extension with an adapter part number A 17/40. The 17 is for inside diameter and the 40 is outside diameter of the bearing. You then snap the adapter onto the shaft extension. Position the bearing square to the shaft. Then put the adapter squarely on the bearing and using a dead blow hammer, tap the bearing home. The adapter is designed to support both the inner and outer races, but the majority of the force goes to the inner race. From the time we start tearing a motor apart until the motor is completely done, it’s maybe 30 minutes. You can even leave the motor wired if you like, as long as it’s locked out. This kit will install bearings from 10mm ID to 55mm ID. Awesome tool. The tool was from SKF the bearing people.
