oldman_pottering
Tinonee, NSW Australia
Finally got around to giving the old girl a much needed wash and polish, my wife's car generally gets cleaned each weekend and my poor old ute gets put on the back burner ( me not prioritising )
This weekend I borrowed a buffing machine from work and gave it a cut and polish, after the polish the paint work still felt .......well.... rough so I gave it the clay bar treatment and then polished again, this time the paint feels nice, it's been quite awhile since any sort of cleaning so I guess muck was embedded into the paint, the roof needs a repaint as it has a rusty type patina to it but at least it's got some protection on it, surface rust spots have started appearing over the last few years, I'm fairly sure the previous owner had the cab repainted at some point. I pressure cleaned the chassis rails and now need to finish off the windows etc but I ran out of time, at least now it looks like someone owns her
Beerhippie
Far NE Oregon
I don't understand--If you take the dirt off, what's to protect the paint?
Nothing for 3-1/2 days because I went camping! Now I'm gradually unloading
Taking a break...
I see I might want to break out the housewife and do some repairs while I'm at it.
You have a current SO not mentoned before? I know to have had some descriptive language for a former GF that washed your CI skillet...
four inch diameter dowels.
Hmm what in the world need a 4" dowel>
I got my MINI up in the air
What is the purpos og the wood block ramps?
Coleman 220E, Feb. '62.
Now to get the nice shop-made aluminum case cleaned up....
That case looks like a fair fit to the aluminum 442 Coleman stove
Beerhippie
Far NE Oregon
It would be a nice match, @Outlawmws . Just needs the diamond emboss like the cooler. That would be a nice trio!
Anyhow, the case looks as good as it's going to:
It has an inch-and-a-half of open-cell foam padding inside, which, after the full-on scrub-down this got--Barkeeper's Friend, rinse, dry, Mother's Mag and Aluminum polish, power buff, more Barkeeper's, more rinse, more dry, Mother's synthetic wax, power buff--the foam is soaking wet. The case is sitting upside-down on some pallets drying in the sun--might take a day or two.
I'm still impressed with how well built the case is--sure ain't no Bubba job!
oldman_pottering
I cleaned up the blanks for the desk. I will turn them into four inch diameter dowels.
I like those Japanese style hand planes, have you always used that style ? I don't do any hand planing but it's something that I have been interested in for awhile, am considering buying a 2nd hand traditional plane but when seeing the style you have I think I should just get one of those
Skyman
Central Maryland
Isn't something how the Art-Deco movement made it's way into so many things of the day? Love the hood on that press! Looks like the entire drill press will clean up nicely, and serve another lifetime.
Agreed. I've always admired Art-Deco style, and I do like the tiara on this machine. It is cleaning up respectably well, although I'm not attempting to turn it into a showpiece. It will be placed back in service.
oldman_pottering
I might shouldn't ought to tell you this, but Coleman made lanterns and stoves in OZ. Tilley lanterns are fairly common down there, and unique. Seems like some other makes that we rarely see here in 'Murica.
I have seen various Coleman gas camping stoves and electrical camping lanterns but not much of those cool lanterns you collect, the Tilley name I have heard of but not seen, I do have an old lantern hanging in my shed just because, I'll check for any makers markings tonight after work
If this leads into a collection I'm happy to hold you completely responsible :p
LeeG
Phoenix, AZ
I have one of those round pool type umbrellas that I use for spot shade. The base broke a few weeks back, and I wanted a heavier replacement so maybe I wouldn’t have so many issues with it tipping over. A couple local stores wanted $140+ for a 40 lb, and that seemed steep. I picked up a 55lb weight from Amazon, added a scrap of 2” aluminum tube bored to the right diameter, and now have a pretty sturdy stand.
LeonardY
Southern California
I like those Japanese style hand planes, have you always used that style ? I don't do any hand planing but it's something that I have been interested in for awhile, am considering buying a 2nd traditional plane but when seeing the style you have I think I should just get one of those
I was trained with them since I was a kid. I do use western style planes as well. But I prefer Kanna. They take practice and are not as easy to setup as western style. Blade sharpening is different as well. If you're up to the task then you will find them very satisfying to work with.
LeonardY
Southern California
Taking a break...
It's the bull nose and corners for my desk base. I don't have a 2" radius router bit. Even if I did I would be scared to use it.
oldman_pottering
thanks, I edited my post as it should have said " am considering buying a 2nd hand traditional plane", I think I will start with a traditional No 4 and give that a go
racecougar
Missouri
Dissected a '73 Mustang shifter and a '04 Mustang shifter to rework the '73 unit to run a 4R70W transmission properly. I was really surprised at the fact that Ford retained the same basic design, but changed everything just enough to require machining of every part.
Both shifter gates allow for a 45 degree rotation of the shaft, so the majority of the work comes down to moving the lever from the '04 over to the shaft from the '73 to get the correct travel.
Pressed both levers off of their respective shafts, took a few thou off the '73 shaft to utilize the '04 bushings in the '73 housing, then cut the appropriate rectangular shape (at the correct clocking) into the '73 shaft to key into the '04 lever. Plan is to tack it, try it, then weld it up.
Ran out of time to finish up yesterday, but it's getting there.
Hubmonkey
OK
Oil Change and tire rotation on the 2015 Ram2500.. found the right front hub to be a bit growley... guess a new hub is in the very near future for me... Just wish the local dealers sold OEM parts at the same prices as online instead of full List Price and above... Called Nickels dealership and the list price on a new hub assembly is $522, dealership wants $662.00 plus tax... geez...
Hub
Beerhippie
Far NE Oregon
@Beerhippie here is the lantern I have, I think it's just a cheapy job with no value
Yep, a wick-burning kerosene lantern of the Hurricane style.
It looks like "Mountain Trail" to me? I'm not familiar with that one--possibly either Asian or Ozzie make.
Good thing about those is that they don't use pressure (or highly flammable gasoline), so any holes in the fount (likely for that one) can be safely patched with solder, tank sealant, etc.
rd65
Granite Falls, WA
Worked on an old base cabinet that was at my Mom's place for my shop sink. Had to replace the floor, base to raise it back up and toe kick. I think I will look for a decent piece of plywood in my stash to use on the exposed side. I need to add a brace under the bottom for additional support for the water heater that will go inside. Hope to finish it up this week and get the floor opened up for the water line.
dangti6
Somerset, UK
Added a small sink beneath my pressure washer/hose reel today.
It was my wife that instantly looked at it and said - “won’t you bang your head on the hose reel”
I kinda knew that would be the compromise when putting it there centralised. The reel is between chest and head height so does restrict the view and prevent me hunching over in to the basin - however I’m telling myself it’s just for quick occasional hand washing to save going indoors whilst working.
I didn’t want to position it over to the right as I’m going to have shelving there.
Before I plumb it in - Is the restriction going to forever annoy me?
oldman_pottering
That's a kerosene Wick Hurricane style lantern. those have a following also, often the same people as the people that collect pressured lanterns.
I can't quite make out the markings.
the maker is " Mount 'N Trail " , it feels like it's cheaply pressed although I have no idea if good quality lanterns felt any different
oldman_pottering
I should make an electrolysis bath and give it a soak, see what remains
Beerhippie
Far NE Oregon
Doesn't your electrical code have something to say about an outlet directly under the pressure washer? Not to mention the unsheilded wired to said outlet?
That's going to splash back like crazy and soak you. :evil:
Immediately
This ^^^^^
and This ^^^^^ on both sides of the P- washer
I suggest:
  • Move the P-washer left - use spacers if needed to clear the pipes.
  • move the P-washer spook under that an below sink height.
  • Move that loser electrical outlet up well above the sink.
    • Do you gave GFCI outlets available there?
  • Where will the sink drain to?
GrayFlattop
Chicago
Looks good. If you leave it where it is, just think of the benefit of being able to tell your wife she was right!
