rd65
Granite Falls, WA
In my experience, a non starting Briggs is almost invariably the flywheel key sheared and its simply out of timing.
I will say my dislike for the Briggs we still have around at is tempered by the fact that the 21hp unit on our mower still ran fine despite this spark plug. I was just having a look at it because engine had the typical Briggs head gasket leak at that time.
2001ZR2
Kansas City
More adjacent to the garage but the tools were inside.
Grabbed my 15mm socket, extension and ratchet. Broke open the new oil filter sockets and grabbed two containers of oil.
Had to go to O'Reilly for an oil filter as I didn't replace the last one from the previous oil change.
Tried to get finished before it rained...no such luck. Truck was on the driveway so finished buttoning up and set oil in driver side footwell..
Walked dogs and when I got the rain slowed to drizzle. Finished by adding oil and checked for leaks. Job done so took oil to be recycled.
Now to get oil and filter for 2.8 diesel in the next 3 months of 5k miles.
Old Man Roger
Palm Coast Florida
The Silverado died again, so I stuck a new distributor in it.
It was cheaper to replace the whole distributor than to replace the cap rotor and magnetic pick up. I don’t know why this thing eats up cap rotor and pickups, but maybe there was something with the distributor causing it.
Hopefully it will stay running longer than 6 months with the new distributor. It’s got a lifetime warranty, so if it dies again, I’ll stick another one in it.
Ben Buck
S. W. Ohio
Just outside the barn .
It has FINALLY RAINED ! Here in the Miami Valley ( Dayton Ohio Area)
I Warshed ( no R ) the hood of my old S10.
I thought why not! Let the rain Warsh the suds off!
My truck looks happy to me !!
Just something to do !!
I have had this car warsh soap for ever- REAL CAR NUBER WAX !!
Listening to Oldies also .
Felt great on both my hairs ( on my head )getting rained on , after 1000 degrees.
DGersic
DeKalb, IL
Replaced the inside dust seal.
I had replaced it earlier this year, along with the bearings and races, as part of the suspension rebuild, but it didn’t go in straight and trying to fix that buggered it up so it didn’t sit right. Ordered another one, it’s been sitting on my bench waiting.
This one also didn’t want to go in straight, but I was able to correact that with a few hammer taps.
Reassembled, but left the wheels off for cleaning.
rharman
SoCal
This morning, emptied out my wife's car to take to the dealer this morning. Dropped a cylinder last week.
This afternoon, loaded the stuff back in the car after getting it fixed. $$$
Bent a hinge pin for our master closet door. Earthquakes and settling over the years and now it kind of wants to slowly close on its own. A little tension from the bent pin helps tremendously.
nateo
Embrun, ON
In another baby step to getting stuff out of my own way, last night I hung up the 8 3' LED pluggable lights that I've been tripping over for ages. I picked them up dirt cheap on sale at Princess Auto a while back. One less pile (on top of the other piles) and a huge lighting improvement over all the main work areas.
I took some pictures, but I'm going to keep them to myself. I wouldn't want any of you tidy shop guys to have an aneurysm.
LeonardY
Southern California
Removed the power antenna from the Volvo. It reaches full extension and keeps clicking. If I push down on the antenna it stops. I thought the rack got stripped. Bought a new one on Ebay for $12.
Took it apart and found the rack was fine. All the gears were fine. After some examination, I figured it might need to be preloaded. I put the new antenna in anyway. I'll hook everything up today and see if it works.
Few more minor fixes and it time to sell it.
LeonardY
Southern California
Hooked up the antenna. Worked perfectly.
Reinstalled it. Put all the interior panels back in place.
I'm finishing up a few of last years ornaments. I'm seeing a friend this Friday that I missed during the holidays.
Of course, I missed counted the number of parts that I needed.
Printer is running as I type...
jimkinney
Florida's Space Coast
Continued with the drawer fronts, got the first coat of primer sprayed on.
While waiting for it to dry, I turned some steel drill bushings to replace aluminum ones for my brother. I can't part steel on my wimpy lathe, so I marked them to cut off with the bandsaw. Then I put them back in the lathe to clean them up. Looks like they will work fine.
Beerhippie
Far NE Oregon
Spent a couple of hours polishing someone else's turd. A coworker sanded off the old finish on a table for the pub. He doesn't understand the difference between stain-grade and paint-grade sanding, so he left horrible gouges and across-grain scratches with a belt sander--not to mention a wavy surface. Looked like warm doggy-doo when stained.
I went over it with three grits of belts on the belt sander--the right way--then 80-150-220 Cubitron Xtract on the RO sander hooked up to the shop vac.
An old trick for sanding:
Scribble on, sand off.
Unsolicited product plug: I love Cubitron Xtract disks. With the shop vac sucking, they cut like nobody's business--and no wood-putty boogers afterwards.
Still damp from the mineral spirit rub. It was a little hot for staining, but It'll look fine from my place.
I'll get some spar varnish on it this afternoon when the shade returns to the shop.
kaymccampbell
Upstate New York
Didn't be shy, show us your **** pile.
Fell off for a day or so (Again)
Yesterday:
messed with the Wheelless trailer, it does not swing out far enough to cleat the back hatch on this van (worked perfect on thee Villager and Sammy...) It will have to be a "remove to open more than a foot or so" until I have the energy/strong reason to "make it better"
Working on a stainless panel for one of the rust holes in the T-van. (the worst one)
Wired a new 220 plug onto the big compressor, (a Hubbell straight plug, not the angled PITA plug)
Today:
EARLY changed the left lo-beam on the DD toy. (2 months after changing the right... Buy those lamps in pairs guys!)
Stripping the white vinyl off the SS, it's taking a hot bath -one end at a time in SG in the USC and then comes off in sheets cold its a tiny piece at a time...
Not sure if its the heat, the SG, or the USC... :dunno: but the center section will get some boiling water to see if heat alone was needed.. I know Hot tap water did nothing...
Otherwise avoiding the heat.
