2025 Garage Sale Thread (14th Annual)
Status
Not open for further replies.
Drove over to Earthwise Recycling to look at a couple boxes that appeared in their latest newsletter, but they all required more work than I wanted to do. I did find a couple items to bring home:
Stanley 12-ounce claw hammer head, a broken handle I will fit to the Stanley head, and a 600 K-D valve spring compressor. 09/24/25
alinc100
Dearborn,MI
Facebook Marketplace again. This popped up yesterday and I was able to make arrangements to purchase today, happened to be on a route home that made sense.
Craftsman 3/8”-1/2” ,5/8” - 1” combo wrenches
Craftsman 3/4” x 7/8” dbe
Dubl-Hex 182 deep offset 5/8” x 11/16” Made in Canada
Herbrand 3/8” combo
Barcalo 7/16”,3/4’’ wrenches
12” & 15” Crescent wrenches
Record No.4 Stay Set Smoothing Plane
Fred Knox
Nor Cal
Found today at “an early weekend garage sale”:
Script Barcaloy combination wrench set
P&C spinner/extension
Plomb 4800 9/32”-drive midget set in original box
Early S-K No. 4237 1/2-drive socket set, with flex-head breaker bar, a cross-bar, and ten "S-K Chrome" sockets. All of the sockets are marked “S-K Chrome" with the fractional size only (no model numbers).
Utica three-diamond no. 82 needlenose pliers
Klein Tools 201-7CST spring loaded side cutter pliers
Hexo #15306 chrome vanadium DBE
Two Vlchek chrome molybdenum DBEs
Long C Craftsman combo
Smaller Indestro Super, Crescent, Plomb Pebble, Armaloy, Dunlap, and Barcalo scoop wrenches.
Assorted vintage None Better, Cornwell, Plomb, Mustang, Blackhawk and D-I sockets.
Friday Estate Sale - $15 all; not bad!:
2 Proto deep sockets, Proto 15 in punch, Proto LA extension, pipe tool, Burndy calipers - never seen any like this with cable conversions - , paint brush, Millers falls protractor head, a Renold chain breaker, made in England.
Nearly full DNA, Craftsman hatchet needs de-rusted, Conger Lantern Co battery lantern, the battery was inside, but was dead and rattled? I suspect the AA or AA batteries inside were falling apart... I'l test this, but this could be fun as an LED conversion? have to see what 6V LED lamps are available if it works.
Jacobs976
Indiana
Not much going on here unless your looking for baby clothes but the ditches are always free game so here's something at least interesting.
Found an interesting scene: $5 bill(soaked and bi-fold, currently dried and flattened), proto 1" drive extension(broken), 4½" hex bell end cap with 2-1/8" hex bolt and welded lock ring set with Y line anchor chain, and mystery steel bar that may have been part of the anchor for a set of the caps since the chain matches the holes(symmetrical).
I believe it may have been a workman's comp claim of a man named Jesse who was helping his high school chemistry teacher make some extra cash.
Also no clue what the bell end cap would've been for but I do intend to take it apart and clean it up despite the assumed issue. With a flat ID cap it might be a nice oil bottle for the man who uses half a gallon on cutting oil per job. Was hoping it'd finally give me an opportunity to use my 2-3/8" ratchet wrench but I think it'd at least be interesting to make something out of it. First step is figuring out what metal it is and if it would react to evaporust since the chains will most likely need a bath.
Edit: Cap is flooded with tar so that may explain its abandonment. Potentially leaked around the cap threads during/after emptying tank then hardened before they removed it leading to black thread sealer. Not really an issue if it was just loose since it's easy enough to dissolve especially outside but they could've assumed seal failed despite no apparent damage. Could've just been time to replace it by age alone too since it should've been self sealing to some extent so might not have been appreciable.
Also it is a tank cap, 2" hose would connect when plug removed and there would be a valve before the cap that would allow the liquid to display it's potential pressure when released. Also $500 new apparently. Not sure if that's machining/casting costs or if it has material(uncommon alloy) costs to justify. 23+ steps for machining from what I can tell but all basic for a machinist.
Jacobs976
Indiana
Looks like an extension that was used as a pry bar with a bigger extension? Is the female end a square broach (busted out)?
Sorry was referring to the flat stock with what looks to be broached oval holes(double circle or something resulting in slight point in centre) half under the $5 bill. Could've just been a tire flap plate for all I know but it fits the chain like it could be married parts to keep the chains from rubbing against the tank.
The round stock is a proto 1" drive extension with the side blown out on female drive end, probably used as a prybar or potentially loosely fitted ratchet anvil that binded and popped the weak point. All I know is it was sudden and fractured. Grain looks like when you snap the anvil off a ratchet. I assumed it was related to the bolt but everything's been in the ditch for months at least so it could've just been a congregation point for lost bits and bobs. Either way I'm sure the user wasn't happy with the result.
bmwrd0
Beaver Fever Oregon
I hit one sale yesterday afternoon, and two this PM.
Yesterdays sale was for a diesel mechanics compound, and by the time I got there it was pretty picked over, not sure by whom. Here I found a Central dial indicator in box (marked sears on the box), Snap-on and MATCO wrenches, two socket chisels, and a lineman's bolt bag. $4
First sale I hit today was a country place just south of town, and it was a disaster. But, that means good finds!
mill bit in tube, two Hinsdale sockets, and seven MT2 drill bits. $5
Final sale was a return to the helicopter/airplane mechanic sale from two weeks ago. Now they had opened up another hanger/repair shop. So, there were now 12+ band saws, from small Craftsman size to 16" Walker Turner sized and even larger! Also, two more lathes, and who knows what all. But I dug around, and found the following:
Crowntop ignition wrenches (with a Snap-on extra tucked inside!), Boker flat nose, two miniature cast iron pans, Mossberg 640 mag, Starrett no. 4 thread gauge, Lufkin and Ohio Art scales, channel scrub (?), center drill, two thread chasers, Snap-on m4 and Wizard spinner, 37/64" bit in tube, needle files, empty Simonds file box, valve cores, handle wedges, and sockets (APEX, SK, MAC, Bonney, SpeedMaster, unmarked universal), head of of t-handle, and a mill bit. Oh, and a Daisy 717. $2 for the Mossberg mag, $5 for everything else, and $25 for the 717. Daisy's of this series (7x7) are highly regarded target pistols, especially considering the cost. They regularly shoot equal to Steyer, FWB and other, high-end Euro pistols. Happy to have found this, as one was on my list to try out. Now I just need to find a box.
There was a community wide scheduled power shut down from 8 to 5 today so we got together with the neighbors for a trip to Nevada to check out sales. The first stop was an estate sale in Minden and it seemed pretty picked over by the time we arrived. I picked up some Craftsman pliers and a hose sprayer, although the neighbors found some treasures. IMG_4272.jpegThe most promising sale of the day was in Washoe City. The seller must have spent plenty of time at Harbor Freight since I spotted four identical Pittsburgh brand adjustable wrenches at various locations on the property. I did find some worthwhile tools and replenished my bungee cord supply. I’m always happy to find S-K tools and these 3/4” drive tools are going to be pretty nice after plenty of cleanup. We found a few Craftsman tools as wellIMG_4276.jpeg
The next sale in Carson City was getting ready to close (at Noon!) but we looked around and found a few pieces along with a cute little possibly homemade gold toolbox.IMG_4266.jpegIMG_4267.jpeg
One more listed sale led to some TOOs.
Down the same street was TOO #4. I believe the the speeder is a prewar unmarked 1/2” drive S-K.IMG_4262.jpegAfter a gas fill up and lunch we arrived home at 4:00 and the power was back on. Quite a fun day of sales.
Started cleaning up the 3/4” drive S-K tools.IMG_4294.jpeg
TOO #2 (free) & 3 at the same location.
Is the left item an extra adjustable wrench scroll (screw, snail)? I’ve only found two loose ones, and neither fits my 15” ¿crescent or Diamond, forget which?
NYBODYMAN
NY
Rolled by a sale and took a shot asking for tools. Guy comes out of the garage with a small Rubbermaid tote and says here look through this. I saw Marco, Snap On, CMAN, Etc amongst the junk and since I was pressed for time said how much for the whole thing? He told me to make an offer which I normally don't like to do but I said how about $40. He said 50 and I quickly took out the money. I'll rifle through it later after my son's baseball game and post the hits. There's already a Snap-On tamper-proof torx set on a rail as seen in the pic. That's worth more than $50 alone.1000012202.jpg
Slow day, three planned spaced an hour apart each. (first was a 3 house "block sale" advertised as a 3 street block sale...)
4 pair new buckskin gloves, -fit perfect - a box of Crossman CO2 cartridges, pack of Crossman Pellet clips, a brass hose fitting (you can get anything but barbed anymore...) and at the second place the 1-3/4" Plvmb crows foot was free.
And second stop much later 3 drivers, - the Granger one is double needed, a flex Allen driver, inside calipers, and a K_D impact driver - $2 all
Beerhippie
Far NE Oregon
Were the three households on three sides of the block?
We went to a few local sales this morning with mixed results. Few sales had tools but we found a few items. I probably need to go back to this sale tomorrow since I wasn’t very thorough. IMG_4305.jpeg
We found this draw knife at a moving sale. It is a little less rusty now.IMG_4301.jpegIMG_4304.jpegIMG_4303.jpeg
I finished cleaning yesterday’s 3/4” drive S-K tools.IMG_4299.jpegIMG_4300.jpeg
NYBODYMAN
NY
Here's the hits from the mystery box I bought.
Left to right:
Fiat wrench, 2 unmarked older wrenches, Langline 11/16x7/8 ratchet wrench, CMAN 9mmx10mm offset ratchet wrench, miscellaneous SK/Husky USA/CMAN USA sockets, CMAN stubby flathead, CMAN USA extensions, GM Goodwrench small 2" extension (made in Taiwan but thought it was cool), CMAN 13mm combo, Barcalo DOE, forged USA offset SAE, Fairmount 9/16"x1/2" offset DBE, Dunlap USA offset DBE, SK 10mmx12mm line wrench, 2 Blackhawk SAE line wrenches, Matco 18mm combo, Snap On T8-T50 tamper proof Torx socket set, Blue Point 19mmx21mm offset DBE ratchet wrench, Snap On 14mm and 17mm 3/8" drive impact swivels, Snap On FBP1 pocket spark plug gapping tool, Flex-Hone (marked Snap On Tools Corp), Snap On 3/8" extension, older looking unmarked screw clamp, 2 Proto 3/8" pear head ratchets, SK 1/4" locking extension, and Billings No. 8 adjustable pliers. Not the greatest score but I think overall I did well for $50. (There was equally as much Taiwan junk that got tossed).
alinc100
Dearborn,MI
Had 2 purchases from Facebook in the last 3 days. Got the first one sorted and inventoried today:
Snap On 1/2” drive
SW-180 9/16” 12 pt shallow date code 1940
SW-200 5/8” 12 pt shallow dc 1941
SW-260 13/16” 12 pt shallow dc G -gov’t
SW-540-1/2 , 1-1/16” 12 pt shallow dc E - emergency
Snap On 3/8” drive
2@ F-140 7/16” 12 pt shallow dc G
F-160 1/2” 12 pt shallow dc G
F-220 11/16” 12 pt shallow dc G
F-240 3/4” 12 point shallow dc G
SF-120 3/8” 12 point deep dc G
SF-140 7/16” 12 point deep dc G
PLOMB 1/2” drive
5436 1-1/8” 12 pt shallow
WF-45 9/16” 12 pt shallow
PLOMB 3/8” drive
WF-27 3/8” 12 pt shallow
WF-30 9/16” 12 pt shallow
PWA-2254 7/8” 6 pt deep
5260 3” extension
PLOMB WF-7 flex handle (looks modified from 9/32” to ¼”)
BONNEY
3/8” dr ratchet T35,also marked PWA-1394
3/8” universal PWA-1405
½” drive D24 3/4”,D25 25/32”,A28 7/8” 12 pt shallow
WILLIAMS
3/8” dr BD 1222 11/16” 12 pt deep
1/2” dr SD-1228 7/8” 12 pt deep
1/2” dr S-1240 1-1/4” 12 pt shallow
MISC 1/2” dr
New Britain NTD26 13/16” 12 pt deep
Thorsen 530 15/16” 12 pt shallow
SK 40132 1” 12 pt shallow
TRUTH 5” extension
Walden Worcester 1152 flex handle
New Britain 3/8” dr NBD20 5/8” 12 pt mid depth
Craftsman 3/8” drive set 4404 11 piece (w extras ) or 4414 15 piece (missing parts)
WRENCHES
Penen 18” pipe wrench
Crestline 14” pipe wrench
Pexto 10” pipe wrench
Bonney 1170 combination wrench
SK 1/2” x 9/16” deep offset box wrench
PLOMB WF-79 5/16” x 3/8”
WF-80 3/8” x 7/16”
WF-81 1/2” x 9/16” dbe’s
2@PLOMB WF-98 1/4” offset ign wrenches
PLOMB WF-83 ¾” x ⅞” dbe
Herbrand 1725 3/8” x 7/16” doe
Blue Point Supreme S2526 25/64” x 13/16” doe
Bonney Zenel 3729 5/8” x 3/4” doe PWA-1114
Snap On AC1818 offset wrench 9/16’’
Duro-Chrome #86 11/32”, #89 1/2” offset wrenches
Chrome Vanadium 9/16” offset wrench
WardsMaster 1/4” x 5/16” doe
Armstrong Hi tensile 5/16” x 3/8” doe
Vlchek 3/16” X 1/4” doe
(Valve adj wrench) PWA-1608
Williams 1120-5/16”,1128-7/16” offset
Williams 3721 5/16” x 3/8” doe
Williams 3727 9/16” x 5/8” doe
Barcalo 3/8” combo wrench
MISC
1/4” drive stubby CA-211
Utica diags
Tiger Tools battery pliers
Unmarked wood handle nutdriver
Wright SO1122 flex nutdriver
R&P MFG Co. Worcester and Chicago Philips screwdriver ,wood handle
Fiskars multi Screwdriver
Craftsman 6500 Hand carry box with tray + homemade 2nd tray
Chisels,punches,plumbing wrenches(2nd box not inventoried)
bmwrd0
Beaver Fever Oregon
Left to right:
That older looking clamp, as you put it, if for a saw vise. They often go missing. Good scores, and you made your money back on those Snap-on torx sockets.
Levaughn
NY
These are some items I picked up today at an Estate Sale for $20.
Williams 9/16 # B-12TB Socket
Williams 19/32 # ST1219 Wrench
Herbrand 3/8 Ratchet
Herbrand DBE 9/16 - 1/2 Wrench
Proto Socket 3/8 6pt # 5220
Blue Point # S-1214 7/16-3/8 Wrench
Plomb # 7440-H 1 ¼ Inch 3/8 6pt Socket
Power Kraft 84 4661-101 W Pliers
Stanley 4" 1/2 Inch Extension
Craftsman 17mm #44237 1/2 Inch 12pt Socket
Misc No Name Drop Forge Wrenches
MAC 13mm # M 13 CL Wrench
Crescent 10 Inch Adjustable Wrench
NYBODYMAN
NY
Would you be able to elaborate a little more on the clamp? Sorry, wood working/carpentry is not my forte.
Agreed, when I saw the torx socket set I just made an offer on the whole box.
EDIT: Just checked Snap On's site...this set is $407.00 new:eek:
bmwrd0
Beaver Fever Oregon
(photo shamelessly stolen off of the internet)
You can see where the part you picked up attaches to the vise, which is the long portion up top. The clamp is adjustable so it can be used on a work bench, or a saw horse, or any suitable attaching point.
NYBODYMAN
NY
Gotcha thank you. Is there a market for these/any value since they go missing? It's useless to me.
Had a good day today. Late Thursday I won two lots from an Estate Auction, pick up was today. Took the dogs for a run early, hit two waste of time sales, then packed up for the hour drive over the hill and south (Santa Clara for the locals). After picking up my stuff, it was over an hour back home after bailing off the freeway due to a stoppage. Found an estate sale on the route home, day two, so wasn’t expecting much. Straight to the garage I go, see a bunch of people clustered on one side, looking at NIB Matchbox cars and other “collectibles”. The other side had a pegboard with tools, and a craftsman carry box with two drawers. Went over, saw a few planes en route, picked up one, put a few others back. Made it to the corner, realized there was an oak drawered tool box against the main door, covered in dust and a few cheap plastic lights. Looked at the price sticker, verified it with the garage staffer, and decided it was going home with me. Took an oil can also. Checkout took all but one dollar in my wallet.
Here is the auction haul, one lot was 71# of old machine catalogs, will summarize in a list later. Saw a few which might be of use at ITCL, others are more “machine stuff”. The other lot included a Do-All bench center, a surface gauge of unknown make in a wooden box, wooden box of misc tools, including pliers, files, etc, metal box of locks, metal pouring can, and vintage electronic/ electric gadgets.
The Do-All is new to me, not sure exactly how much I can use it, but from quick reading, two projects seen possible. Not much mention of them here on GJ, I may have to go to PM for assistance. What’s interesting is the shipping Label on the box, USMC.
The box is probably a SIPCO, in pretty good shape, just missing the front flap. A few things of interest inside, include files, and a different square (see vintage toolbox thread later). The plane is a horned smoother, with a skewed blade, and a radiused edge on a Rabbet type plane (see the handplane page later). And an oil can full of red stuff, guessing ATF.
All in all a good day, cuz I also found my wife’s birthday present, and not at a gas station or 7-11.
Beerhippie
Far NE Oregon
The box is probably a SIPCO, in pretty good shape, just missing the front flap. A few things of interest inside, include files, and a different square (see vintage toolbox thread later). The plane is a horned smoother, with a skewed blade, and a radiused edge on a Rabbet type plane (see the handplane page later). And an oil an full of red stuff, guessing ATF.
SIPCO confirmed!
Even the same model as mine.
Status
