oldman_pottering
Tinonee, NSW Australia
With a lot of patience I've rewound unraveled ropes like that- the trick is, twisting each strand as you rewind them together, You have to be like Kay said - uninterrupted, and focus. Make sure you keep the twist tension on them...
that's good to know, I thought it was too far gone, I should practice on other ropes to get the technique correct.
I'd be happy to purchase some new rope made of the same material but I don't know what it is , I have lengths of nylon/polyester ropes that I have cut to varying lengths and just burnt the ends but I don't really like that stuff
KwikFab
Central Valley, CA
@Outlawmws
@LeonardY
Give you a better idea of the layout; with the garage door open you can see just how much lower it sits in relation to the ceiling height
The steel is normally placed on the wall to the right of that picture
All I've got left are two 3/16" sheets
I just use grip strength and lift them to carry to the table
And I've also got some sprinklers in the garage (fire suppression)
Space being the biggest limitation, followed by budget and lack of how-to
JEFFREYWisconsin
Well not today but last night unloaded the new to me drill press from recent auction. Now have to ponder the work space rearranging to make this fit. But first have to replace a tube in the lawn tractor front tire
Edit. Not sure what is happening with pic. Resized it to well under a meg. Well sometime later as I have lawn mowage to do
Fixed it
looked at this without my glasses thought it was a model of something from star wars!
kaymccampbell
Upstate New York
There's nylon and nylon. The soft stuff is nice for little boats and easy splices. It has lots of give. The hard stuff is for bigger things and pulling, and it's a bit harder to splice. I bought soft for my boat. The tree pulling rope, that I use with the Dingo, is hard nylon. It was a bit of a ***** to splice an eye around a thimble with it.
kaymccampbell
Upstate New York
@Outlawmws
@LeonardY
Maybe a HF engine lift? You could park it under the CNC when it's sleeping.
Black300zx
Elkton, Md
Put up the door screen so I could work in the garage without dealing with mosquitos.
I need that screen. What brand?
Dad came down and lent a hand dropping in my motor and trans. Hoping to fire it up this weekend.
Cleaned out the 4X4 post hole and chuncked out one oak tree rood knot that was still in the way, and sank the 4X4 post today. need to pour the concrete cap for the top chunks that got busted out.
Rain-X ed both Toys front and rear, since its getting to be that time of year, the "Fog-X" inside is a pain as that requires ALL the inside scunge from plastic out gassing deposits to get cleaned off...
Yard cleanup (never ending) but more progress on Ivy. put stuff away and reorganized a few things.
LeonardY
Southern California
You might want to read my thread about it. It's not perfect but it works.
Beerhippie
Far NE Oregon
Don't forget Dacron. While most Dacron marine lines are kernmantle, the rope I used for my towrope is hard-laid three-strand. Also not the easiest stuff in the world to splice. For practice, I recommend good ol' Manila rope. Cheap and fairly easy to splice.
I prefer a single eye at one end of a towrope so I can adjust the length to my needs. I can throw a bowline on the other end so fast you'll miss it if you blink.
2001ZR2
Kansas City
Beer Hippie if that is her happy face then her angry face must be truly terrifying....
carved about 45 minutes to work on hanging my power tool storage rack...discovered I built a frame for the peg board so now I either have to locate a couple of cleats on the wall for the mounting screws or figure out how I would like to add a couple of stringers to my frame. sketched out a couple of ideas but thinking a quick install of 1x2 on the short side of my rectangle is the answer. Gonna sleep on it.
In a grand bit of irony moving things off my workbench meant my fastener bits were hidden by the displaced treasures so time was spent or more properly defined as wasted looking for them until I remember my secret stash or the drawer in my old top box that would have some junk ones....found what I needed so the hand powered screwdriver made way for the impact driver.
This cracked me up!
But I suspect that is her "Why are you taking my picture?" look...
Look at french cleats, I use them a lot and hey allow for a lot of mounting flexibility. I usually cut my own.
bmwrd0
Beaver Fever Oregon
More work on the lathe
Got the counter shaft set up all set, just need to order some square head set screws of the right length - 1-1/2"
Also started tearing down the chuck that came in the big box o' lathe parts I picked up:
need to pick up some Simple Green and give it a soak, this thing hasn't been cleaned in decades probably.
KwikFab
Central Valley, CA
Yeah - when the time comes this will probably be the most effective method
Still got plenty of strength and I'm careful never to hurt my back - this huge flare up was due to all the weeds I was picking in the front yard (for about +1 hour straight) followed by a family get together and our son's baptism
Was on my feet a good 6 or 7 hours after that morning labor and it's been kicking my *** ever since
kaymccampbell
Upstate New York
I was looking at this site
https://ropewarehouse.com.au/ and it lists polyester or polypropylene as the main types of rope, not sure if that comes under the same name as nylon or not
Nope. Type nylon into the search. You'll get plenty of listings for 3 strand. There may be better ropes nowadays, but nylon boat ropes have been a staple all my life.
kaymccampbell
Upstate New York
The time is already here. You have hurt your back. Why wait until you can't stand or lift or whatever. I have lifts n ropes n chainfalls n a Dingo to make sure I don't hurt what little I have of a back.
Absolutely, positively, correct!
I injured lower back muscles in HS. They "spasm" periodically,. you need lifting aids, and a back Physical Therapy Regime, and stick with it daily. (I forget and then I pay for it...)
Oddly, for me the best routine PT is "toe touches" while siting in a "straight back chain" (height and firm seat is the key here, not off an easy chair... This keeps those lower back muscles stretched out and flexible. It isn't bad for the upper back shoulder muscles I've torn 2X either.
Oh yeah, I also wear a "kidney belt" whenever dong any heavier lifting. Makes a huge difference.
Beerhippie
Far NE Oregon
Just nope to polypro rope! It's absolutely the wrong thing for a towrope. It's one redeeming feature is that it floats, so is sometimes used for things like mooring lines on small boats. It stretches a lot--and permanently--weathers horribly in the sun, and doesn't take knots particularly well.
It is used for practice splicing--probably because it's cheap.
Polyester fibers include Dacron, which is used primarily where its low-to-no stretch is desirable--halyards on boats, rope tows, etc. If you're used to a rope with some "give", this isn't it. Towing with Dacron is like towing with a cable--gently!
For absolute strength-to-weight and about zero stretch (and therefore give), the aramid fibers are the thing. Blue Steel is one brand. These are commonly used to replace steel cable on vehicle winches. Aramid usually requires special splices and doesn't like knots much.
Nylon is excellent for a towrope. Most ropes that have appreciable stretch--rock climbing, ****** straps, safety lines--are nylon. Because it stretches some--elastically--it "cuts you some slack" when towing. Nylon takes knots very well and in the softer lays, is very nice in hand.
LeeG
Phoenix, AZ
I've had the basic version of this tool for years and not used it much until recently. I dug it out and was using it enough to get the newer version.
I like it much better than hose clamps for this sort of thing.
Fixed up the ends on my garden hoses last night.
Beerhippie
Far NE Oregon
Interesting!
Now, damnit, stop trying to spend more of my money!
oldman_pottering
I have watched many YT vids about home made versions of these, I think it looks much neater than hose clamps
Interesting!
Spend it !........ you can't take it with you :)
nadogail
Coronado, CA
The technician and garage door arrived today 5 minutes before the “window started”
The technician who took the order for the door didn’t tell anybody about what machines and materials were in the garage.
The installer will be back next week to prepare the work site. We are blaming the mixup on the failure of the original technician to effectively communicate the requirement to have a large clear area to assemble the new door.
The Garage Door dealer may try to up charge me for the extra trip, at this point I feel no obligation to be responsible for the failure of the original technician to communicate that unwritten requirement.
Beerhippie
Far NE Oregon
We called our local Door Guys (company name) two weeks ago. Called again Monday and we're "on the list". Meanwhile, we now have two doors that don't open automatically--the other one died yesterday with a horrible noise.
Beerhippie
Far NE Oregon
Best part is that these folks are the only door service company within about three hours' drive of here.
I'd like to get up and take a look at the drive for the warehouse door. From the sounds of it, it could just be a loose set-screw. But that requires a scissors lift, which we'd need to rent. I used to service it from a ladder, but now I have a manager who's terrified of ladders.
Copymutt
Colorado
IMG_6017.pngIMG_6018.pngIMG_6019.pngIMG_6020.pngMade a set of skids for the snow plow. Having invested in regrading the driveway and hauling in new gravel, I dont want to have it end up in the pond!
Factory set up is fine for asphalt or concrete, but dont work on gravel.
These should float enough to do the trick.
2001ZR2
Kansas City
Finally stopped trying for perfect...not falling off the wall is good enough. The levels say it's close but my eyes are more critical.
First photo is the pegboard stripped of most and my old 4 slot power tool storage.
Second is the trial run will make some adjustments tomorrow. Life started happening so I'll add the charging stations and mount the power strip tomorrow.
One more step towards getting the Evil Garage reformed. Just need to keep getting tools homes and returning them.
