Moore and Wright Sheffield England
NastyNate
Trying to figure out what these were used for. Moore and Wright we're generally all machinist tools these look more like woodworking but they're not very sharp the Chisel looking one is just blunt on the end. Let me know your thoughts thanks
larry_g
oregon
The scraper with the squared end is probably for scraping in flat surfaces, such as ways on a machine tool.
My first thought too however scrapers for machine ways are not square for the most part. They are a convex shape so they only contact a small area of the surface. That one in the picture is hard to judge and/or has been improperly ground at some point in it's life.
lg
no neat sig line
Stubby1743
UK
I have recently got one of these in a box with other tools. I'm still not clear as to its intended purpose.
As can be seen, it's not very large. The blade tapers along its length. It also tapers very slightly across its width. The handle is hollow for most of its length with an 8mm hole extending for 93mm of the 115mm length of the handle. It is marked "Moore & Wright Sheffield England like the one in the Ops picture, but on mine the "Moore & Wright" is straight rather than curved, which may mean that mine is a bit later.
I have other bearing scrapers and this tool seems very different. However, the fact that the OPs came in a set with two other tools which clearly are bearing scrapers means that it must also be one.
Anybody got any info as to its use or maybe have a M&W catalogue that shows it?
Stubby1743
UK
Yes, amazingly, the first one I looked in
Wow, thanks for that. What a fantastic catalogue which shows the extensive range of high quality tools offered by Moore & Wright in 1938.
I suspect that the scrapers like mine were offered over a long period of time and I think that mine is probably from the 1950s.
