Beerhippie
Far NE Oregon
Today was mostly "body work" If you can call putting patches on rust holes on the T-van body - "body work"
I know this is not a forever fix, but it's also not a forever rig. Its my camping beater.
I started with the SS patch I made a week back but had not installed. I did that and its in with 6 screws where there is still un-rusted steel. Then, as the SS was several inches too short to cover more I made up aluminum from flashing to cover those and used the same HVAC "repair tap" to attached them. This is the tape that had been covering the holes for 6 years or so and it's one fault is you can put a finger through it pretty easily. It lasted in the sun with no issues!
Learned today they do make this tape with a heavier aluminum backing but the Aluminum (and SS is required to get under the window rubber and its actually making a decent seal to the patches.
I'd have needed the aluminum anyway for where I had to get a bit creative on bends
SS and 2 aluminum patches the right side Aluminum had to get a near 90 deg bend back to and under the rubber, with an upwards kick:
Left corner of the right side back window needed the opposite upwards kick - the aluminum is exposed the tape is on the edges:
Left corner of the left side back window need the same upwards kick the horizontal "crease"maps to the body crease:
Back door left side of the window. -easier as the metal went straight up under the rubber:
Same on the right rear door window:
And a simple patch for a hole in the lower right corner of the body it did need a kick to map to the body. not sure why this one rusted, as it had no real avenue for the salt from SF Fog to get to it? :dunno:
I'll hit these tomorrow on both sides above the gutter:
C'mon, Outlaw--any old rust-bucket driver should know all you all you need for a rust-patch is the aluminum duct-tape!
rd65
Granite Falls, WA
Pulled the deck off the mower to sharpen the blades. Never got around to cleaning up the spare set so I had to do that tonight. Gave the deck a quick cleaning as well. I will need to spend some serious time on the deck this winter, that clay topsoil I put down last spring is like concrete. L/F tire has a slow leak too, needs more slime I guess.
SouthernIllinois
bugnut
Central Ohio
A while back I purchased a 1966 Ford 2000 Tractor. Proofmeter, shows very low hours, I am working to get the hand throttle to hold position. Struggling to balance all the linkage to make it work correctly spent 3 hours on it and still no closer. I have replaced the cork disk, tightened the tensioning screw and moved the linkages, I can get it to hold 1500 rpm and no more, should be able to hold at 2100rpm. Will continue to adjust but running out of movement on some of the rods. Starting to wonder if the throttle plate in the carb is correct.
aka Larry
Eastern, NC
Good eye!
That was indeed 1/4" and yeah, plenty overkill :ROFLMAO:
One thing about Land Cruisers is, you either have to make it yourself or pay a bunch of money for something. This is especially true for armor.
Don't know if you've done any Wrangler JL skid plates (and still have your templates), but if you do I'd be interested. I'd prefer to give my money to a fellow GJ member vs an on-line vendor if possible. PM me.
niget2002
Josephine, TX
I ran out before work this morning and threw together some scraps of plywood into a new task light for the office desk. I used some of the leftover LEDs and a spare wled controller from the House LED project. The lights are held on by clamps and I just used brads and glue to hold everything together. This is a proof of concept build to see if it helps. It's not very bright, but I also only have 6 LEDs on it right now. If it works well, then maybe next week I'll design and build something better looking.
Then I quickly put all my tools away before coming back inside.
KwikFab
Central Valley, CA
Shoot that'd be awesome to make but I never have, and don't foresee myself doing any.
My local sales are limited to an automotive shop, and a handful of various customers with only a few being repeats. All the rest of my business is online.
The large majority of people that live around me have money but do everything they can to not spend any if you catch my drift :ROFLMAO:
So it's really put a hamper on what I can offer due to the lack of such specific work for example -
1. My current press brake is really small, so I wouldn't be able to knock out a proper skid plate for bending since I got rid of my Harbor Freight kit awhile back. I plan to get the SWAG Pro kit, but it's not cheap so it may be awhile before I can get it. So far everything I bend is small enough to ship, so my current brake serves its purpose.
2. I don't have a tube bender, which I'd love to own one day as well. But if I did have one, the work done on it would be for myself due to the above mentioned reasons.
Chris Stapley
Campbellford, Ontario
I had been working on living space in my garage but it’s at a stand still for a few days so I thought I’d dig out the Alamo 2 hp Hit and Miss engine I bought from a neighbour’s widow a couple years ago, tune it up , take it off the fifties lawn tractor chassis he had it on and remove the awful paint that I’m sure he put on it with a dirty mop.. here’s a few before and afters .. I think it looks more honest with just a coat of boil linseed oil.. the red is completely wrong anyway, an Alamo was dark blue..
rd65
Granite Falls, WA
Have you tried any YouTube offerings?
CoogarXR
Decided to connect my new fog/driving lights to my high beam circuit. Opened the hood, and got lucky that the OEM headlight wiring and the aftermarket fog light wiring were like 1" apart. Couple snips, strips, solder and shrink, and my fogs kick on with the high beam lever now. Nice and easy. I added a relay to make it easy on the old wiring.
Old Man Roger
Palm Coast Florida
High beams are usually a bad idea in foggy weather.
rzims
Grass Valley, CA
Not in my shop, but at my daughter's house. Electrician did some rewiring. Offered her a pretty good discount if he didn't have to have20251007_113554.jpg20251007_110339.jpg20251007_120320.jpg his buddy do the patch work. She said, "no problem, I'll get my dad to do the drywall work"
Made her help me so she'd know how to do it in the future.
First coat of mud is done. Only took about an hour....
Beerhippie
Far NE Oregon
It's truly amazing how many people I know have never heard of the "splint" trick for drywall patching. They always want to cut back to the studs.
rzims
Grass Valley, CA
Yeah, thats exactly what my daughter thought we were going to do. When I showed up with a 2x2 piece of sheet rock, she was confused thinking we needed a much bigger piece
Beerhippie
Far NE Oregon
Just the usual **** I get paid for--sharpen kitchen knives (aholes found another steel so it took me an hour to sharpen the ten knives), fix ****, etc.
I was asked to blow the leaves off all our docks and walks. As much as I like our Stihl battery blower, the damned thing gets heavy when using it for an hour. I'd been meaning to make a shoulder strap attachment for it and this seemed like a good time to do it.
Works great! It hangs, perfectly balanced, from my shoulder and I can operate it with one finger--bonus is that the para cord defeats the stupid safeties. Now I can easily blow myself away with it. It's almost fun to use.
I have used Paint Sticks to support Dry Wall patches
I generally use 1X to give the rock a backer and shoot it in with sheet rock screws. I once patched a door knob hole (thanks kids!) by cutting it rectangular, slipping the 1X backer inside using a couple deck screws as a "handle", and maneuvering it 90 degrees, and screwed it into place; the "plug had 100% support under it!. After finish I put a "doorknob bumper" on it...
All over the map today, and internet being "intermittent" 'cause they are doing "upgrades" for the past two days didn't help my day planning...
started with no Internet @ 4:30 AM. (and it had been out since 11PM...)
so I:
  • "Fog X" treated the windshield of the T-van,
  • Disassembled the wiper arms and de-rusted them on a wire wheel.
  • Took my AM walk. (3 + miles 57 "heart points" according to my phone)
  • Caught up on internet, since it was up for a bit
  • Painted the Wiper arms since the sun was up and hitting the garage door where I hang things to paint.
  • retrieved gear from the TT for the upcoming hunting trip, mostly the side wall tarps for te canopy.
  • got the passenger side gutter rust hols cleaned and taped with the heavy aluminum tape, (I like how conforming this stuff is! I rolled it down with a deep socket...)
  • Waited for the drivers side to get shade so I wasn't staring at the sun...
  • got some of my camp food into the weekly grocery order
  • Prepped the drivers side for tape.
  • Had a needed nap!
  • Taped the Drivers side
  • went to NAPA for clear RTV 3 to seal the gutter rail itself
  • bonded between good gutter and tape to insure a seal.
  • Put stuff away and cleanup the Driveway mess...
  • still waiting for the wiper arms to cure more, to that's a tomorrow thing to reassemble and mount the new blades.
Xfinity says I have internet now, so lets see if this sends:
