How often do you use a crowsfoot?
benny42
I had a steering rack failure that required those, so i bought a set.
Now i use them all the time for all kinds of stuff. Wish i had them
years ago.
fordbroncodave
you really need one if you ever have to remove the oil pump from a john deere model A. lots of plumbing lines inside that crankcase.
the obvious is rack and pinion setups. they are very common to use on those.
wafrederick
Holton,Mi
I use them on power steering lines and have been handy.I have the metric set from Harbor Freight and will be getting a SAE set tommorrow.SAE set will be a Carquest set,being delivered since trhe nearest delivers.
mdbeck1
Norman, OK
I've got a set that I picked up a couple years ago. I think I've used them once or twice. In my younger days my Dad had a set that we would use once in a while.
Crows feet are one of those tools that you don't usually use often but when you need them they are the only thing that will work...
Jay H 237
Torrington, CT
I use them enough to justify them, only need them a few times year but they are indispensible when they are needed. Last used mine to remove the ****** cooler lines on my 68 Mustang and also lube oil lines on the head of an Alco 244 in an RS3 locomotive.
Diesel_Crawler
Canada, NB
Indeed....
Jim C.
I've owned a standard set and a metric set for years. I use a couple of the standard sizes on a seldom occasion, and don't believe that I've ever used any of the metric sizes.
srmofo
SW ohio
I use my flare nut crows feet (think line wrench in crows foot style) once a week at least. honestly though its almost always a 16mm or 18mm. power steering lines are the most common.
I dont own a set of regular crows foot
therealwormey
they are like a weatherhead socket,never need them but when ya do your sure glad you got em
KWashburn
Midland, TX
A rule of thumb that I learned growing up was if you have to use it more than 3 times, you need to buy your own. That can turn into quite an account with the Tool Truck.
rsanter
visalia ca
I used to use them all the time when working under cars
now Im a desk jocky so I use them once a year at best
bob
mdbeck1
Norman, OK
That's a better rule than a friend of mine. If he EVER needed a specialized tool he bought it. He also had a rule that if he bought a tool it had to be a Snap On. The tool truck guys loved him.
Stuey
28m above sea level
I ran into a situation where I needed them and didn't have any. Sooo I went out and bought a set when they were on sale at Sears. Only used them once since!
gordsgarage
Canada
Depneds on the type of work you do and the extend of your tool coleection. I own a set of crowfoots and use them very seldom. However I also own a set of short, standard, and long wrench sets along with flex sockets, universal joint sockets and wobble extensions. I will always use anything other tool first and then go to the crowfoot as a last resort. However when you need a crowfoot you need it.
vssjim
McLean Va.
I use the flare nut crowfeet about ten to ine over open end style but if you work on stuff the racks or flare nut lines you need them. I don't know how long it would take to take off power steering lines with out them.
RLRRLRLL
Spearville Kansas
i bought metric and sae sets at napa after doing a job that if i had them it may had been a whole lot easier....i have never used them...yet.
Goinlow
I've used them once since last year. Taking off a powersteering line on a jeep Cherokee. 18mm.
srmofo
SW ohio
When it comes to the flare nut style, are is Snap-on the clear winner or are other brands worth buying?
My standars are all cornwell and my metric are SO. I havent had an issue with either and both are pretty close to the same size, cornwells just a little thicker but has never caused a clearance issue
Quik208
California
I was looking a getting a set in the near furture. What do you use more often regular set or flared?
_CY_
had a full set of Mac crowsfoot ... never used em, so sold em
lbgradwell
Oakville, ON
dankicksass
New Jersey
In large sizes they tend to be more affordable and take up far less toolbox acreage than a wrench. When I had them, I used flare crowsfeet often.
Seanbev24
Lynnwood, Wa
I use larger non-flare crowsfeet quite a bit when doing alignments. If a 22mm tie rod nut doesn't want to come loose, I use a long 1/2" flex ratchet with an adaptor and crowsfoot. Much better than smashing my elbow on the rack when the nut breaks loose with a wrench.
back2class
This is one of those tools where you can kill 2 birds with one stone. Get the crowfoot sockets in the falare nut style. With a small 3/8 breaker bar you have a great set of line wrenches in addition to the crowfoot sockets. I own a set, but if I had some decent flare crowfeet sockets they would have no real use.
crewchief888
NW indiana
most of the time i use the open ended type for "tight spots" in and around hyd hoses and tubelines.
flare nut types i dont use often except for the occasional hp fuel line on mechanical fuel inj pumps.
i think all my crowsfeet, flare, line sockets and weatherhead sockets are all SO, and 3/8" dr
:beer:
Hey Mike:
I can say it's been quite a while since I have used a crowsfoot wrench.
With all the new offset, ratcheting box wrenches and the new Gearwrench sets available, my crowsfoot wrenches gather a lot of dust. But they are still a valuable tool to have in your tool box. If you work on olds cars like I do, keep
them handy. You'll be using them sooner or later.
Mike, The Home Depot Answer Man
Goinlow
I know people who use them quite often for loosening lines that are loose but not loose enough by hand.
