Dumb Question on fuel pressure testers
ramba_ral
Hi all,
I'm in the middle of troubleshooting a fuel pressure issue on one of my vehicles so went out and bought a fuel pressure gauge.( maddox from harbor freight)
I wanted to make sure the gauge was working so I isolated the gauge from the rest of the system to test. I did this by making a hose with a ball valve , pressurized the system , bleed air out and closed the ball valve with no other components in the system.(pump -> ball valve -> gauge) Everything is dry no leaks.
Is it expected for a fuel pressure tester to slowly bleed off pressure by its self?
cgrutt
Does the fitting connected to gauge have a button on it as shown below?
That is used to (1) bleed air out of system and (2) to release pressure when done.
cgrutt
If you press it it should release pressure in hose and gauge (when pump is not running).
R
ramba_ral
yea all that works. I'm saying if i leave the gauge alone it bleeds pressure off with out pressing it.
charbar
Midwest
Clamp the line off with something (vice grips etc) between your gauge and ball valve so you can figure out if it's your ball valve or gauge leaking.
How much of a drop are we talking here? How long to drop, say, 10 psi?
R
ramba_ral
I tested the ball valve by taking the gauge off and running the pump. Not a drop past the ball valve.
I did spray down the setup with soapy water to find a leak but didn't see any. putting the whole thing in a container of water is a good idea though
it drops about 10 psi in about 2-3 minutes.
charbar
Midwest
10 psi in 2-3 minutes should be pretty easy to spot I would think.
Soapy water wouldn't be the best test for that since we aren't looking for bubbles from air escaping. Any leaking fuel would probably blend in with the soapy water and be hard to spot.
If your ball valve is for sure holding Id take that pressure tester back and exchange for a new one.
R
ramba_ral
Think I'm gonna take it back and exchange it. I will take the ball valve part and put it in water to see what happens though to make sure its not the ball valve.
jsaw
Geneva, N.Y.
If it is not leaking, but the pressure bleeds down, then the check valve in your fuel pump is defective it should hold pressure for a long time.
308guru
Do your "does it leak" testing with air instead of connecting it to the car. Once you confirm it's good then move on to the car.
joecon
If you isolated the gauge and the pressure leaked down, there would be gas were the leak was. You may have a leak at the pressure regulator or a fuel injector leaking or the check valve in the tank. Anything else will show as gas leaking out of the gauge or hose or valve.
rust in the eye
Chicagoland
How long do you expect it to take to read the pressure?
Vehicle fuel pressure checks typically are a go/no-go situation. Need 3 bar and see anything much less and you have your answer.
Not a whole lot of precision needed here
dscheidt
There are things like testing for injector leakage, where you want to see the pressure decay slowly over time (or not at all). If your gauge won't hold pressure, it's hard to know if it's the gauge or something else leaking. Fuel isn't terribly compressible, and the volumes in the lines are small, so it doesn't take much leakage to result in a substantial drop in pressure.
