rjacobs
Looking for some advice/opinions on how to route the EMT and wiring to the lights I am planning to put into my shop.
Im strongly considering 10x of these 4' LED fixtures. 7200 x 10 / 700 = just north of 100FC's. I would be at 13' mounting height which is the max they recommend for these lights so I dont think I would actually get 100fc's at the ground. Plus, if my overhead doors are open I lose 4 lights basically... I'm probably at the limit of overkill.
www.primelights.com
ANYWAY. I would mount them on the horizontal cross braces. Those braces are ~15' wide give or take. I would push them out as far as possible, so 10x total fixtures.
I have 2 thoughts on wire/conduit routing.
1: Center above the cross brace in EMT, j box at each, convert to MC to the fixtures.
2: Center below the cross brace in EMT, j box at each, EMT to each fixture.
I dont think cost wise I am really any different. Im buying 3x 500ft spools of #12 THHN to wire the whole shop with(probably wont be enough, but thats my starting point), so ill have the wire if I stick with EMT. Either way I need a j-box at each cross member. If I dont go "below" and use my THHN+EMT, then I need to buy like 50ft of 12-2 MC which is about 60 bucks...5 sticks of 1/2" EMT is about 35 bucks... So converting to MC is maybe 25 bucks more... I dont count fittings as both need fittings at j-box and lights so its sunk cost.
Im leaning towards "below" the cross brace and then staying with EMT to each fixture. This would allow me to run another piece of EMT "above" the cross brace to a few other circuits I have planned(2x lifts, 2x garage door openers) to keep things relatively clean without just having random *** EMT running all over the damn place.
Any other thoughts on how to run the wiring to look clean?
T8 Bolt 2 Clear *NEW* VERSION 2.0 SHOP LIGHT NEW BETTER BRIGHTER BOLT 2.0
The Bolt 2 Lamp LED Shop Light features two clear LED bulbs that generate 7,600 lumens in 5000K Daylight White. Designed for easy installation and sporting a white finish, this shop light complements both commercial and residential spaces. Ideal for garages, barns, workshops, recreational areas...
