tominboise
- Joined
- Jan 17, 2022
- Messages
- 196
I want to make a tall, narrow rack system for my garage. It will fit between the two garage doors. It will be about 7' tall, 24" wide, 20" deep. With 4 shelves. I will be using 4 legs, as the top shelf needs to hold 250 lbs of rotary phase converter. The legs will sit on the concrete to bear the vertical load and the legs against the wall will be lag screwed to studs in the wall.
My conundrum - how to join the four pieces of unistrut that will form each shelf. I get using the 90deg brackets for the struts that meets on the side with the holes/open side. But how to join the other piece 90deg to that? It will be landing with an open end again the sides of the Unistrut with no holes.
What am I missing- is there a bracket that form that 90deg joint?
Of course, I want it as cheap as possible and strong.....
