Innovate1
House has a 8 x 18 room under the porch. Hollow core planks with EPDM membrane and concrete porch poured over that. No leakage from outside but we get some moisture on the ceiling in the cold winter months from condensation. Wanting to insulate just the ceiling and 12-18" down the walls to isolate it thermally from the temp extremes but leave the rest. Seems like the insulation needs to include a good vapor barrier or any moisture will get to the cold concrete and result in mold. Was thinking of 2" rigid foam board and then seal around the gaps and edges with canned spray foam. But thinking have someone spray foam (closed cell) the ceiling would be even better. It would be a small job for a company that does this. I have no idea what this typically costs. Is this practical? Guess I need to call around and get a few quotes.
After insulation I plan to put some framing for a ceiling below that with drywall or some sort of good looking covering. Suggestions on that would be great too.
