Spindle Nut Socket Sets
Pontiac787
New Hampshire
I’m looking to purchase one of the better spindle nut impact socket sets. I’m thinking Astro/Gray Pneumatic/Sunex. Is there any legitimate reason not to go with a 12 point set? I’ve already got 6 point impact sockets up to 30mm. It seems the 12 point set would be more versatile with no real drawback due to the larger sizes.
Astro seems to be the best value, especially since it’s not an everyday tool for me.
We were selling CTA spindle nut sockets in the 80s. Good stuff. NO clue if level of quality has changed. At that time, they were all U.S. made. Not a clue today.
Just tossing it out there as an option.
Looks like they sell sets and onesie-twosies as well.
ecotec
I have always preferred 6pt… depending what you work on. You may also need some 4wd ones and 12pt 30mm and maybe 39mm and who knows what else. There are some sizes that I know exist… but I have never needed.
P
Pontiac787
New Hampshire
The question I’m trying to answer is if anyone has had issues rounding a 6 point nut with a 12 point socket on something larger than 30mm.
no704
Have a set that I rented at Orileys and never returned.
lund
Spindle nuts are usually not high torque, so 12pts will work.
I think for large sizes, even for a 6 pt socket, 12 pt works fine. The material engagement areas should be plenty large enough where stripping is not an issue.
jayemm
up high down low
Seems like a good place here to ask a question. A few weeks ago a neighbor removed the front drive axle nut on his 2010 VW Passat when replacing the strut. After he finished I saw the nut looked a bit chewed up. I know he bought a socket but not what kind. Is that nut a tri-square or just 12 point and are the sockets interchangeable?
vssjim
McLean Va.
I have both but the Astro set is 12 point and I use it all the time no problem just grab the box and go
vssjim
McLean Va.
12 point external is the same as triple square same thing
ChevyEFI
Phoenix, AZ
Well, not quite.
Nope
dscheidt
Thank you. Now I can see there is a difference. Why do they do this **** (triple square) when 12 point exists. Able to withstand more torque before stripping , I guess.
For internal drive at least, triple square can take the highest torque of drives that are relatively straightforward to put in a bolt head. that means you can can use a smaller head (and probably thread size), and smaller heads make it easier to put bolts where they can't be undone without taking half the car apart. I expect external triple-square is similar, but that's just a guess.
