Zoro Deals Thread
rust in the eye
Chicagoland
I did not know nonmembers were stealing the codes. If I get any more I will not post them publicly and instead ask people to PM and then I’ll post Used. More trouble for me due to inconsiderate people but I’d rather make the effort than reward poor behavior.
Nobody is "stealing" anything if they are posted to a public forum, hence the desire as gsxr stated to make this a private sub forum.
Its safe to assume the 20% coupons will be scooped up in a New York minute, private or not.
pbon
I understand the website is public and that visitors are not actually stealing the coupon codes. The solution you propose has been proposed by others but has not been adopted. So in the meantime, you can choose whether to give monetary benefits to nonmembers or you can choose to give such benefits only to members.
I have learned a lot here from members. I have learned absolutely nothing here from nonmembers. I will choose to support members. To me, the nonmembers are stealing the benefit I wanted to give nonmembers even if stealing is not the correct word to use. Let’s call it appropriating instead of stealing.
reader2580
Minneapolis, MN
I only expect them after an order. And they may send a code if you visit the site or put something in the cart but don't checkout
I find that I eventually start getting 20% off coupons again if I don't order for six to nine months. Once I place an order with a 20% off coupon I usually go back to 10% off coupons for a number of more months.
paulsomlo
Northern Colorado
Same experience here - I order every 2 months or so and hardly ever get promo codes anymore.
fourjeepin
Atlanta, GA
I placed my first order a couple of weeks ago and got this but couldn’t find anything I really needed.
Note that it expires tonight
1320
Arizona
I'm looking for a 20% code if I can find one. I have several hundred dollars worth of stuff in my cart.
PM please if you've got one.
Strouty
Southern Maine
I am looking for 20% off vehicle maintenance getting hit with an extra $140 delivery charge on a $1300 item *****. Worst case I have a 10% that will help, but in the end it just doesn't feel like a discount...
Found a local supplier that had what I needed in stock and very surprisingly, over $300 cheaper than Zoro or anywhere else I looked online. Win for both of us!
ching0n
I've advised telling members a code is available and or request to be PMd for that reason. There's been some takers to the suggestion.
ERG80
TN
Another 20% off select categories.
VHMCKQR54RPN
NUTTSGT
Northern Central Ohio
pbon, the majority of people using the coupon codes are not forum members, and therefore cannot post that they have used the code. (Not that they would necessarily post if the were forum members, but you'd like to think so.)
This is why many people have asked for this thread to only be visible to forum members. I don't know why the admins will not make this change, assuming it's possible.
:deadhorse
This is a change only Ryan can implement as it's his forum.
If you fellas want to only share through PMs, that is up to you. If you choose to "ignore" those here solely to get 20% codes, you're free to do that as well.
pfbz
Looking for a 20% off coupon usable for hand tools... frequent contributor!
PM me if you have one for me?
TIA...
winlinmac
USA
Do your research before buying anything from Zoro - often times, most of their listings are marked up higher than their competitors ;)
gsxr
...and this is why the 20% coupons are needed, to get the final price below other vendors.
:Homer:
Zpoor17
Promo Code: DEALDAYS2025
Valid through 11/16 on categories below
20% off Zoro Select products
20% off Adhesives & Tapes
20% off select 3M Safety products
15% off select Schneider Electric power control supplies
