Vinny
I had a structural engineer come to my house and provide plans to maximize ceiling space in my garage. It involves installing a large glu lam beam (5.125"x15"x22') under the current ridge beam, and then sistering 2x10s to the current rafters and connecting to the new larger beam. On the two perpendicular walls to the beam, 4x4 posts with 4x10 headers with 4x6s on top will hold the new beam up in place. Then there's various ties installed across the rafters, and Simpson ties holding various parts together.
All this is work I can do and have done in the past, but I'm not sure how I can get this new large beam in place with how the garage is currently built. See attached pictures, but I can't use my preferred method of using Genie lifts to lift it straight up into place because the joists are in the way. I can remove the collar ties, but I don't think I can remove the joists, even temporarily to lift the beam in place, can I? I'm worried the roof would just flatten in without them, even if this is just temporary, like an hour tops to get the new beam in place.
I can think of two ways, neither of which I'd prefer to do:
- Cut a hole on the side of the wall that goes outside, lift the new beam up, and push it through the hole into place. I'd prefer not to do this because I'll have a hole in the side of my garage, and I'll have Genie lifts on my lawn (unstable) or need a crane to lift it in place (expensive) while pushing it in.
- Brace the outside of the walls, remove the current joists, and lift the beam into place from inside the garage with Genie lifts. I'm not a fan of this option because I'm not exactly sure how to brace the walls (seen this done, never done it myself) and I don't think I can remove the braces until all other work is done. I'm working alone and would want to do this over the course of a few weekends.
