Wrench97
Southeastern Pa
Tried cleaning them? A deep cycle in the dishwasher is a good start. Maybe not while the wife's around....
Now there's a solution! Go from an OS I'm deeply familiar with, but is slightly different from the last iteration, to a system whose motto is "does not play well with others". Then replace all my software that still runs fine on Win 11 after twenty years, replace all my peripherals as, well, Apple doesn't play at ALL with others....
I'd say photographers are split about 60-40 Win-Apple, based on my experience.
Buddy had to replace the camshaft in a big cam Cummins years ago, instructions said to heat the gear to 450f so he put it in the oven for 3 hrs, his wife came home and asked what he was making for dinner as it didn't smell that great........I don't think she ever cooked in that oven again :lol:
Wrench97
Southeastern Pa
Pet peeve of the day....have a 23 Chevy Tahoe PPV on the lift Chevy dealer replaced the motor 2 weeks ago reusing the broken motor mounts told the local PD the mounts aren't covered under warranty....5.8hrs to change the mounts no extra labor if done with the engine swap. To change the mounts the inner fender liners come out, the exhaust manifolds come off(plugs and plug wires to get the manifolds off) so far every bolt I've touched has been overtightened, some cross threaded. last bolt I tried to get out today is on the right side mount to the block it's crooked and feels like it's about to break off if it does it means the motors is coming back out to be able to drill and tap it.
Brand new 5.3l screwed up this bad because someone didn't give a **** and put it together with a impact gun to make better time..Err.
ObnoxiousFumes
Southwest Sask
Dang! Yeah not the oven, I keep a toaster oven in the garage for that kinda stuff.
Haven’t tried it but apparently you can use a microwave to heat bearings if you wrap them in a wet rag. Only works for up to 100°C though, because if all the water in the rag evaporates then you’ll have problems lol.
Beerhippie
Far NE Oregon
I do , too. Great for curing paint on smaller projects--and reheating lunch.
jblnut
In the Middle of MN
Not inside as the shop isn’t large enough for the disk and tractor but we replaced a disk blade pops busted yesterday. Here is the new one. 30” diameter, 75lbs and $305. There are 52 on the disk total so around $15k for all of em 🤣
Got the 1” breaker and torque multiplier out. My fatass on the end of the 8’ pipe is well over 2,000ft/lbs and I had to bounce to get it to creak loose.
Annnnnnnnnnnnnd it’s frozen with rust onto the shaft. Great.
I got sort of wild with the bearing housing and ended up dissembling it balls and all and decided to persuade it with a little game of heat and beat.
I tired quite quickly of the heat and beat game so I sliced it off. I knicked the spacer but the shaft is unharmed.
Applied a good melty layer of some green crayon on reassembly. The wax will keep rust from forming and will melt if I need to play the heat and beat game again. Antisieze will get full of dirt and accelerate the rust process in this particular application. Wax is king in a lot of ways here.
Mr.zippy
Wyoming
Red crayons saved for the case disk?
kaymccampbell
Upstate New York
I have a half bath off my attached garage.
I replaced the toilet flush valve. The prior one would decide to get hung up randomly at the last flush of the evening. In turn, it would dump water filling the septic tank. The septic alarm would then go off around 11:30-12:30 at night affecting my sleep.
That would happen once.
2001ZR2
Kansas City
Today wrestled the new to me 2nd work bench into its final location. Used longer screws to hold the MDF top on the metal frame. Added the back plate using much longer screws...then tried to reinstall the drawers and the slide clips attempted to escape. That defiant action use put down.
Moved my old Craftsman stack into it's new position. The key stuck in the lock broke off.
Took the wins and called it a day.
Tomorrow begin cleaning up the area and setting up my now main work bench.
This a small step towards taming the disaster that is the "Evil" garage.
That's a good trick to know!
Is green somehow better, of was it just the next sick on the box?
I assume only "Crayola"? (I know most restaurant "crayons" are **** to even draw with...)
Ha! same/similar Q!
Motorman55
South Jersey
Sorted, stacked and moved some tools and equipment around in preparation for dropping it off at the local Fire Museums' workshop this coming Saturday. Going to try and get as many things loaded onto my 4x6 trailer as possible.
Extra benefit of todays exercise resulted in opening up a wider walking path to the overhead door.
jblnut
In the Middle of MN
😂 I think I used a combination of scented candle remnants for the red disk when we did it this spring.
Don’t over think it. Wax is wax for the most part here. I usually use leftovers of the fancy candles Mama Bear buys but I happened across a bucket of crayons on the shop office table the littles left there and decided to use that lol.
I’ll melt the candles into big crayons and use them as antisieze on things with no torque spec. Wax and antisieze do funny things with unless a lubricant is called out to be used when tightening.
niget2002
Josephine, TX
I'm an electronics GOD! Not really, but I did fix something this morning. The power outage yesterday took out the weather station console that hangs on the wall in our kitchen. So I did the right thing and tossed it in a corner of the office where I was going to ignore it and then spent too much time modifying all my Home Assistant automations to pull the same data off the ecoWitt receivers I have. For those that don't know, ecowitt and ambient weather devices talk the same protocols, but ecowitt will read AW devices while AW won't read ecowitt devices. ... Anywho. My initial plan was to replace the console with a wall mounted tablet, but I decided to take one last look at the console. Went out to the shop and cut the power supply cable to verify polarity. The 5v PS when hooked to a multimeter read 1v 5v 3v 4v 1v... anyways... It made a better AC PS than 5v DC... Hooked the console up to my benchtop PS at 5v and everything worked fine. So I modified a USB-A cable to the small DC connector the console uses so I can use any USB-A brick to power the console. And now the console works again! If you go this far, thank-you for reading my wall of text.
Beerhippie
Far NE Oregon
Making a case for my studio lights:
I'll be playing around with the arrangement some before I start cutting foam. That's two LED continuous lights, two light stands and two simple reflectors. I'll probably remove the reflectors to make more room for padding. I use soft boxes and such much more than bare bulb and reflector.
This is also the first picture I've taken with my new Nikon D850. Just simple JPEG, nothing fancy--but it looks great right out of camera! The only processing was a little downsizing for the 'net.
JEFFREYWisconsin
Getting color on the walls on the main level just off the kitchen. Furniture is being moved up from downstairs on the 10th.
I have a chair and a lamp I cover while working and sit out here planning etc. It will stay approximately where it is in the picture.
It occurred to me where I found the inspiration for the pieces... I will move one of my Marshall speakers in place and try to create wind at some point.
Mike65
Horse Pasture, Va.
My wife & I did a little work on her "new to her" trike. It is a 2003 Honda Goldwing GL1800 in Jupiter orange. We had to adjust the height of the brake pedal & the toe/heal shifter. Installed the trickle charger quick disconnect end on the battery, & the inspection sticker plate. While we had the l/s side cover off we installed a gromet that was missing that the clip on the side cover goes into to hold it tight. I ordered a new light up license plate bracket to replace the terrible one that is on there.
Beerhippie
Far NE Oregon
@JEFFREYWisconsin : I recognized it immediately! Well done!
Wasn't that an ad for Maxell tapes?
More progress on the case:
Bagged the reflectors and rearranged a bit. Foam is cut--except for the lid. Now to figure out the best adhesive to use... contact cement?
Gotta go mow some more leaves before we open at 3.
bornbadbob
I was on my way to the grocery store this morning and went out to the truck, the doors unlocked with the remote, jumped in put the key in and it “click’ once and nothing else happened. Never had any indication of a starting issue before.Suspected a bad battery and confirmed that with a couple of quick tests. I just happened to have a brand new Optima red top sitting on the bench, double checked the physical measurements and the post orientation ( battery was destined for my Mustang but the F150 was in immediate need so it volunteered itself for the truck. Put the battery in, cleaned the connections and away we went. It doesn’t seem normal for me to have the parts o hand but got lucky this time. I had an Optima yellow top in the truck since 09/16 so I can’t really complain about a 9 year service life.
LeonardY
Southern California
My reply was mostly tongue in cheek.
Anyone who has used PCs as long as you would probably never like macs anyway.
I used both.
I designed and modified chassis for MACs in the eighties for Apple. Using AutoCad on an HP computer. Because AutoCAD wasn't available for the MAC.
I stopped buying MAC's after the VX. I had an FX at work. It was a piece of ****. Constantly giving me a bomb.
We used MAC's at work for 3D modeling but they were configured with Windows. Since half the software we used wasn't available for MAC's. We switched to HP work stations because we had less problems with them. Better support from IT.
My brother has done the opposite. He had a original IBM PC. Was a Lead C++ programmer at a very large software company.
He now uses a MAC.
I don't have any loyalty to either Apple or Windows based machines. But I have a lot of very expensive software that would cost me a lot of money to switch. So I stay with my PC.
Beerhippie
Far NE Oregon
Case is done:
Not the best foam cutting job ever, but with the tools I have.... The black thing is the remote for the lights.
I used 3M Super 77 spray adhesive to glue the foam in. It's now all over my fingers. Rolling a smoke with glue-covered fingers is a challenge.
A place for everything, and everything in its place.
Nothing moves or rattles when shaken.
The case is one of those yard sale things you buy because someday you'll find a use for it. It only took me a decade or so. The latches are camming by turning the keys 180 degrees, which seems cool. It has a military/instrument feel to it, but no markings.
bmwrd0
Beaver Fever Oregon
That was the 4 foot aluminum case my canopy poles live in when not being a canopy. - didn't take me a decade for that at one though! It has the same 1/2 turn latches.
rharman
SoCal
@jblnut Recent article in a vintage tractor magazine pointed out IH used wax paper wrap on wheel axle shafts. It does not retain water and creates a layer, much like the crayon.
Another benefit of using the wax paper wrap is you won't incur the wrath of the "littles" when they want to color a tree or lawn and discover you stole the green crayon!
Jgaz
Made a lot of sawdust the last few days.
All the rabbets and dados are cut for my desk build.
Trying to be somewhat efficient. I setup a tool and do all the parts and operations. I only do one particular operations a day. I find I make less mistakes that way. I say less...not any...
Homemade dust collection cyclone?
Blue Chips
Maine
Continuing work on my New Holland GT18 garden tractor (basically the same as a Toro 518xi). On these tractors, the plastic fuel tank (HDPE, I assume?) is secured at its top and sides by several irregularly-shaped pieces of foam rubber sandwiched between the tank and the rear fender. The old foam rubber had deteriorated to what was essentially powder, which allowed the tank to flop around, and it's probably not in any better shape on my 522xi, which is the same vintage (2001).
I haven't (yet) found any available OEM or specific aftermarket replacements for the foam pieces, but if anyone knows of any, let me know. In the meantime, I'm going to experiment a bit and try fabricating the replacements.
I didn't know how thick the original foam was, since there wasn't any intact foam to measure, so I thought I would start by determining what the space is between the fender and the tank. To measure the space, I stuck little mounds of modeling clay at several locations on the tank, placed a little piece of polyethylene over each one to keep it from sticking to the fender, laid the fender in place with the mounting holes aligned with the corresponding captive nuts in the frame, and pushed straight down on the fender until it contacted the frame. When I lifted off the fender, the height of each mound of clay was mashed down to match the space. All of the mounds measured 9/16" or very close to it.
The foam rubber will need to be a little thicker than 9/16 inch, so that it compresses just enough against the tank to hold it securely without stressing anything. I'm starting with a semi-educated guess as to what thickness and compressibility would work best, based on a combination of intuition, logic, and black magic. I might have to try a few different foam rubber combinations before I find one that works to my satisfaction. At least I know what shapes the foam pieces will need to be, as I could still see the outlines of the adhesive backing before I cleaned it off.
For my first experiment, I just ordered some 3/4" foam rubber made of a blend of Buna-N, neoprene, and vinyl. It's listed as having good oil resistance, and it's considered ultra soft (rated at 4 psi to compress it 25%). This is a closed-cell foam, but the original foam 'might' have been open cell (I think there are pros and cons to each). I will need to be careful to place the foam pieces to allow drainage and not trap water. The foam should arrive in a day or two, and I'll post an update on how it goes.
Jgaz
I’d be lost without my outdoor garage extension for routing and sanding here in AZ.
I have this “knock down” bench for large projects. (it also has a 3/4” top not shown here)
I also use my trusty, lives outdoor, workmate a ton.
Here it’s moved into the last sliver of shade available mid morning during the summer.🥵
@LeonardY since we seem to own a lot of the same tools, do you have that fantastic Bosch saber saw? 🤣
