Blocks for hydraulic press
ChefRex
I'm spoiled by the press I had at my last employers place, while I don't fix as much anymore, replace every thing!
But I do throw the good stuff in a corner.
I now deal with a HF press, I need blocks for it instead turning their press plates on end, it can get sketchy real fast but I'm not dealing with high pressure and don't want to spend a fortune, the blocks I formally had access to where probably 2x6?
I looked at McMaster-Carr but here are so many choices of steel, I have the ability to cut a bar. .
Open for suggestions
ChevyEFI
Phoenix, AZ
HF 50 ton press plates kit is one easy option. Probably 1" x 3" like the Sunex comparable kit.
  • 7734ece74e470ba117bcafdb816b60967e525907_57KIT6_2_1c019875-119a-4ca2-9908-8209da5935ba.jpg
C
ChefRex
Good gravy, you don't want McMaster-Carr, you want scrap material.
I'm sure you're right, problem is around here you aren't walking into a scrap yard anymore.
Years ago I had access, no more.
cvairwerks
Within hearing distance of Texas Motor Speedway
Local?
I'm confused, there's a local airport, do you deliver?
Virtually every steel yard there is, has a drops or offcuts area or room. All the less than half stick or half plates are gathered there and sold to small buyers at something over scrap prices, by weight. I regularly buy drops for projects when I don't want to buy full sticks or plates.
danielbuck
got any old hydraulic rams or jacks? cutting up the shafts of those make good spacers for a press, if you don't need something really wide.
Mike007
I see the OP is in Jersey. Fazzio is an excellent source for steel including drops. It was a few years ago, I picked up a bunch of 4"x12"x1" thick drops for this purpose. It was cheap too. I'm certain they will have something.
Steve_P
There are plenty of press plates new on Amazon, but you'll probably spend $100 for a pair. Start calling local fab or steel vendors as said above. I have to drive ~45 minutes each way to get steel, so that factors into my decision when I need something that I can just buy from McMaster (at a high price) and have it delivered.
whateg01
doo dah, kansas, usa
Are those on Amazon forged or cast? Cheap ones are usually cast, ime
