Could I use Brake Fluid as a paint stripper?
HalfTonTom
Waterford, NY
I have some years old Dot 3 brake fluid and a Craftsman tool chest that needs stripping. I know that brake fluid is damaging to paint, but could I use it to remove the paint on the tool chest?
no704
Probably a good start. Just be careful with what happens to it. Don’t want it getting into the ground. Maybe on a bed of cat litter?
tarmy
Nor Cal
Nasty stuff that is. I wouldn’t do it inside nor without some proper gloves.
CMB41
california
AKA aircraft remover. We used to joke this stuff actually “removes aircraft from the runway”. The new stuff is not as good as the older, I’m sure way more toxic variety. Put the box on a thick poly sheet outside. Apply. Should be good in about 30-45 minutes. Putty knife and a brass brush. Do not get on plastic/rubber.
Milton Shaw
Years ago I can tell you something else they used. I don't know how many cars I saw with 6 --3/4inch circles on fenders from people checking water in their battery and placing the caps in a line. The most I ever saw on one car was two sets as most people would figure it out after the first time, some slow ones took two times. That is one thing I'm glad we don't have to check every month anymore like back in the 50's and 60's until the low water use materials batteries came out.
NYBODYMAN
NY
I distinctly recall being taught in auto body tech school during brakes/suspension class that if you ever get brake fluid on a body panel, the paint would/could be damaged and it will not be able to be repainted. Never experienced it (thank God) and never heard otherwise.
GDM
As soon as you said "brake fluid" I got triggered with splotchy fender well images .
