I'm confused about how the wire-pulling feature is used.
You'd need access to both sides of the wall to get the wire into the drill bit's hole, and at that point the hole in the wall is already drilled, so why wouldn't you just push the wire through the hole in the wall?
I looked for a video, didn't find any.
Mike
I don't own any bits that short, mine are like 3 ft to 5 ft. Long and when I get to where I want to be I might attach a fish line and then pull that back up and then I can use that fish line pull the wire... And the assumption is that where it comes out you can get to it.
Last time I did it I cut a in the wall that would take a box and then I use this long bit that was long enough And flexible enough but I was able to stick the bit in the hole, shove it into the piece and the floor I wanted to drill through drilled through when it came out. The other side someone underneath tied a string to it then I pulled the bit up..
After that I installed a box and we ran ethernet cables...
