Anyone know anything about septic systems? (This seems closet to a "Plumbing" forum here)
N_Jay
Seems my septic system needs some replacement and looking for some knowledge.
Tank had a cracked lid about 3 years ago.
Just got pumped and guy said he thinks the sides are getting ready to collapse. (1958 cement tank)
Probably don't have enough land for a new field, and figure the city is probably not going to permit a new tank into a old field.
Neighborhood has sewer now, but guessing the line is above our basement floor and lines are below floor.
So, I am thinking a sewerage pump in a vault outside the house to pump up to the street.
Thoughts, warnings, am I crazy?
LOW1
ontario
We have one to pump our sewage away from a lake and 150 feet up a hill. No issues in over 10 years.
I suggest a larger vault to give yourself some “storage room” in the event of a power outage.
Keeping a spare pump and Check valve on hand would not be completely foolish.
BillK
Beautiful Southern Maryland
Dont know why they wouldnt allow you to just replace the tank if there is nothing wrong with the field ? What did the guy that pumped it for you say ? Pretty simple to call them and ask.
While youre at it ask them how deep the sewer lines are. You might be surprised.
I would get some real information instead of speculating.
Firebrick43
West central Indiana
It’s like any repairs on any building system that is governed by code.
If major repairs are required then the whole system has to be brought
Up to code.
larry4406
Northern Virginia
e-one is the gold standard in my opinion on whole house grinder pumps.
My first house had a gravity sewer basement plus the whole house into one of these. It shreds and pumps the effluent thru a 2" PVC pressure pipe and can push almost 1 mile I recall.
Ours and the ones I have installed, come in a green corrugated manhole assembly. It is set in place, and concrete is then poured around it to ballast it in place and prevent it from popping out of the ground.
dscheidt
You need to ask your sewer utility. sewer lines are often deeper than you'd think. They are always below the water lines, which themselves are below the frost line. And they have to run down hill, so depending on lots of things, they're often deep.
micromind
Fernley, Nevada, about 30 miles east of Reno.
As an electrician, I've spent a considerable amount of time with sewer pumps, all the way from little bitty house ones to sewer plant ones that were 500HP.
One thing I've learned so far is that grinder pumps are way worse than solids-handling types. Their GPM per HP is much lower and it doesn't take much to wreck the grinder blades.
The best systems use a septic tank and pump the effluent to the drainfield. A properly designed system of this type can easily last 30 years with single phase pumps, twice that long with 3 phase ones.
N
N_Jay
No one knows where the field is, so that would be a bunch of exploration.
I don't know how you test the field till you hook up the new tank and THEN find out it is taking effluent too slowly. (I will ask)
I also understand that the standards/codes for what an acceptable field is have tightened in the last 68 years. (I will ask)
N
N_Jay
I will ask.
I'm used to new construction where the top of the sewer line is about 6' below grade. Charlotte NC, so about a 4" Frost-line if hell freezes over.
N
N_Jay
Even going up hill I doubt I have space for a new drain field. (1/2 acre neighborhood lot)
No 3 phase here, and I read elsewhere that grinder pumps should only be used when "needed" as they don't last as long.
Thanks everyone, guessing I am about to start a $15K to $25K learning cycle.
mepstein
I live in the woods so I can do most anything at my house and the township doesn’t bother me with what they don’t know about.
If I lived in a neighborhood, I would probably set up a big inflatable bouncy house and drop in a new tank behind the inflatable toy. I would order up the tank, have it delivered, rent a backhoe and have my friend who is really good at heavy equipment remove and replace the tank. Probably a bunch of bad ideas in a single paragraph but if you ever saw what’s involved in building a septic system, you would understand why I wouldn’t spend $25k + on one.
Firebrick43
A lot of new septic systems are not more than 2’ deep depending on soils as the don’t want anaerobic digestion but aerobic to happen.
Many systems if the soil is poor or percs too well(sand or gravel) are actually above ground in the form of mound systems.
Around here the days of tile lines posing as fingers 4’ deep are long gone on new systems.
zendriver
Indiana
Replacing a normally function, septic system was only known problem was a riser cracked lid seems ludicrous
Personally, I just wait for the” total collapse”. Maybe I’ll die first. What difference does it make otherwise?
Like firebrick outlined, you’re gonna have to get out the big checkbook and start completely over anyway.
Or, just tap into the sewer system and pay
N
N_Jay
Just put on in on my future home lot.
I know!@@@
N
N_Jay
I think people are confusing the septic field lines from the city sewer line.
N
N_Jay
Maybe I was not clear.
If I have to replace the system, I probably don't have the room for a new field.
If the line to the tank is good, i probably need a new field, and don't have the room.
If I have to replace the line, given that both last pumpings ended up with tank repairs, so it (with my luck) will require a new tank, and hence a new field. ( Which is don't have room for).
So, I am going to root the line, and if it works without bringing back mud, I am good till the next pumping.
If it still does not drain, we are back to a bad field.
If it brings back mud then I have a decision to make.
Tapping into the city will require the pump I was asking about.
N
N_Jay
It's not draining well right now.
Hoping it is just some roots the plumber midget, but if the tank is full after having it pumped and cleaned a month ago, would tell me i have a bigger problem.
Am I guessing wrong?
captaindiode
NC
Here, once they run sewer line by your property, you cannot get a permit to repair a septic system. If yours fails, you must hook into the sewer line. This also means you get a meter on your well, as that is how sewer is billed, based on water usage. You are not billed for the well water, but the gallons of water used determines the sewer bill.
N
N_Jay
Probably depends on the area about the permits.
I already have city water on this property.
dscheidt
I'd be very surprised if there's many places that would let you put in a new septic system if access to the sewer is available. Failed septic systems are a public health disaster anywhere dense enough to have a sewer. I know some places not only prohibit new systems, the prohibit the use of existing systems if ownership changes.
zendriver
Indiana
OK, I understand now
That’s good you have a choice. I’ve heard some municipalities won’t permit a septic tank upgrade or new install, if there is a municipal sewer line available.
PCustoms
VT
What's not draining well?
Your tank should be full, of liquids, shortly after a pump. The liquid material will eventually reach the output, and go into the field. The solids are the "issue" that need to be pumped. If you let the solids enter the field, then you may have problems. If the tank is bone dry, it's probably cracked.
Around here "repair" is allowed without a permit (state controlled). If my line from house to tank is bad I dig it up and "repair" it. When I get to the tank, if it is bad (damaged), I "repair" it, potentially swapping in a new tank...
N
N_Jay
Maybe I need to pull the cover and see if the talk is full, or not.
The issue is the house line is not draining fast enough.
Symptoms are backing up into basement shower vase, and basement toilet not flushing.
Had tank pumped and fixed it fir a few weeks.
Had line (poorly) rooted and helps a little bit, but not much. (Did pull some roots back, but he only used an auger not a cutter.)
zendriver
Indiana
Did you do the rooting from the tank out to the leach field?
Sounds like that’s where the problem is. Probably not roots anyway since that would only be water no solids.
PCustoms
VT
If easy, yes
Sounds like having some scope work done would be helpful. You should be able to do house to tank, and then with tank open tank to d-box or into the field.
zendriver
Indiana
If easy, yes
The OP had the tank pumped out and everything drained normally for a couple of weeks. Since most likely till the tank filled back up.
I had a similar problem pumped out, and it made no difference since I had roots between the tank and the house
PCustoms
VT
Yes, this is why a scope would be helpful.
His tank likely isn't failed if he's backing up. The tank could be full, and not draining, but unlikely.
A scope job is a cheap confirmation of what/where the issues are
dcg9381
Austin, TX
Might check on that. There are also more "modern" (powered) septic designs that take up less space. No one can tell you because local jurisdictions are so different.
Not crazy at all. These are called "grinder pumps" around here and most of the houses have one. I'd probably go "city sewer" all day long over having to implement septic.
micromind
So watering your garden raises the sewer bill..........
Chuckster in NJ
Hunterdon County NJ
Look for greener grass compared to other areas and that should be where the field is.
You will have to call a professional to do a "load test"
TIP! If you have city sewer in front of the house I highly suggest hooking up to it because this will be an investment for the future.……. Nowadays nobody wants a septic system if you have a city sewer that you can hook up to.
mm08822
I would switch to city sewer in a heartbeat! Nothing like owning a $50K hole in the ground that can fail again.
65ranchero
Danville, VT left NJ forever
Getting a sewer hook up estimate at about $20k.
Yea that's about right
I think that was the cost in highly regulated NJ when I finally was able to hook up to city sewer.
I had to milk the septic for about 2 years waiting for the main line to be installed courtesy of a condo complex near me.
While I was waiting, I had a conversation with the one of the town inspectors.
My question to him was "So I just put in a 30K septic system, will I be able to get a deferment on hooking up to the town sewer?"
Answer: If you don't hook up when the main line is installed, we will fine you and then take your house in eminent domain.
