2025 Garage Sale Thread (14th Annual)
Status
Not open for further replies.
INSP380
Cleveland, Ohio
It was a busy weekend. Got some great deals and those led to more great deals. Found a B&S (Tessa) mic for sale pretty close to home. I bought a vintage Cornwell chest of him over the summer and he had some more to part with. After I paid for the mic, he mentioned he had a inside mic for sale too. He said he’d throw in everything in the flat with it for $20. The mic was $15. Check out the receipt for the mic service. The surface gauge is a Lufkin and stunning. The combination square is a Goodell Pratt. The extra blade is a vintage L.S.S. logo’d Starrett…
Next, I’d been watching this SK for about 2 weeks and the price kept dropping. It hit $15 and I was on it. It was full of tools. Mostly vintage. I’ll show more of those later …
Steve IMG_3893.jpegIMG_3894.jpegIMG_3895.jpegIMG_3896.jpegIMG_3897.jpegIMG_3892.jpegIMG_3890.jpegIMG_3888.jpeg
mikeinri
You **** for all of that!!! Great piece of its history, too!
Today's garbage pickin's in an industrial area.
Keys included!
5 shelves iirc between the two.
You **** too!
Mike
Jacobs976
Indiana
Got another batch done.
First a large kitchen knife with broken tip and heavy pitting on one side, rounded the tip and sharpened now although I don't have any purpose in mind. It was heavily crusted over on one side originally but evaporust made quick work of it. Mainly just something to clean up really.
Small Pexto linemens pliers, has a step on the cutter side which isn't normal but otherwise it was mainly just another usual cleanup.
What seems like some type of plug, 3" tall 2" at base cast iron some porosity but fairly polished seems to be missing the base which would attach at the hole or two openings on sides maybe both. If anybody recognizes it I'm interested in knowing it's purpose, it's quite large so no idea.
A copper spittoon(3 gallon?), previously horn was crushed and it had a large dent in side but 4 hours with a rubber capped hammer and a spoon and it's fairly good condition. Had to work it back into a cone then work the lip back to form where it was crushed more like an aluminium can(warped flat) then work inside to knock the little dents out and then work the outside to near flush. Large dent in side near bottom needed the spoon to pop it out which actually took awhile due to it fighting more. It's obviously been hammered on and not perfect but I left as much patina as possible and made it functional again. Deformation on lip is more appreciable on camera than in person but I'm not fighting it anymore because it doesn't want to be more in shape than it currently is. Also while 3 gallons of fermenting chewing tobacco spit in the open air of your living room might sound appealing to some I opted to use it as a dry waste bin(granola bar wrapper visible in closeup).
Wood box from January 2nd of 1946 recovered from the Batavia gold mine prior to army taking possession of the mine to turn into a water reservoir. It says it's from Dupont Explosives, originally containing 50lbs of "Monobel E" which was supposed to be a low flash alternative to standard dynamite utilized for high risk operations where flammable gases may be present. Box is fair build however bottom does show signs of water staining and lid is primarily missing, one nail in floor was hammered at an improper angle resulting in it sticking out inside the box. Not sure what to do with it but I cleaned it up and oiled it to preserve the wood. Originally it had some salt crystals growing and a ton of sticks of modeling clay(completely filled to the brim)but I did not take possession of the clay, salt did clean up however left some minor bleaching, so it may have been near the sea for a long duration before making it's way to Ohio. Not sure why someone would need so much modeling clay, kinda like Play-Doh, but I guess the box was convenient since it's fairly large. I was going to go back to the barn the next day but apparently there was a gas leak or something and the whole place was just gone, they haven't found the cause yet but apparently the debris field covered 3 counties so it must've been a big gas leak. They had a big propane tank for heating and I guess the whole tank must've ended up venting into the barn or something before catching a spark off something.
.22 cal blanks, significantly more spicy than normal however less powder so less chances of injury from flash. My grandfather carried them back in the 80s, I believe, for self defense at work as a fire fighter but as far as I know he never used any himself. All 5 are active however I haven't tested them myself. I have been exposed to such classes of chemicals but I prefer to limit exposure as much as possible.
LesserSon
PA USA
It IS large, and the pointy end is a bit rounded, but overall it looks a lot like a plumb bob to me.
Jacobs976
Indiana
I have a few plumb bobs, modern and 1950s, and none of them are so massive nor have a blunt tip. This thing is practically a fancy door knob, larger in fact than an antique porcelain one. I have difficulty understanding where it would be functional or why it would be cast out of iron instead of brass given the increased risk of porosity.
Edit: I mainly made the original post ambiguous because of the joke but I seriously don't know what that pattern would be useful for over a moderately sized pointed pattern.
I did look it up and it's called a turnip pattern but that's about it beyond Google AI telling me turnips aren't used with plumb bobs. No definite answer on whether a turnip can be used as a plumb bob but I'd probably just use my modern(steel, maybe chrome plated brass or pot metal with some other plating) hexagonal shaft one or the 1950s brass fine point.
M.Jay
Southern Germany
@INSP380 again earns some suckage from me!
Recently got a deal on a small assortment of different hand tools, as some guy cleaned up his workshop. Paid less than 2 bucks per pice, so I would call this a nice score.
Old "Made in West-Germany" 200mm Knipex Alligator pliers. They were a bit rusty, but after a quick spin on the wire wheel they look nearly as new.
Klauke Crimping pliers.
A Bahco Chisel, two files without any manufacturer markings and an odd looking voltage tester.
Oldschool Wera Bit-Safe, probably from the 90s.
Was pleasantly surprised when I got home and found that it mostly contained Belzer bits.
pfaustus
Does the head on the combo square say Gooddell Pratt on it? I tend to expect a heart shaped cut out with Gooddell Pratt, and think Lufkin when I see that shape. I can't declare it a rule or anything, but I am gathering evidence.
I see some name on the protractor, but that proves no more than the name on the rule. The ability to swap these things around can be frustrating.
This photo from ebay shows what I mean. You also see the heart shape on GP eggbeaters. It was carried over to MF stuff too.
Snip's
Your Curv-O-Mark looks like an earlier version of the one I found on the street, broken and took home and repaired and sold.
They made two sizes. I believe yours went up to 4" pipe and required a hit with a hammer to mark the pipe...
The one I have handles a larger range of pipe and instead of a hammer, the plunger is spring loaded and once cocked, the plunger is released with a trigger release (you can see the trigger lever peeking around the right side)...
lowbucktruck
Foothills, Northern California
Some real-nice scores there!
I acquired this tool at the local dump. My guess is, some contractor was dropping a load of construction site waste and pulled it out of his truck bed, then forgot to put it back in his truck after unloading. Price: free.
Best part is, it works! And came with a bunch of drill bits in the case.
Beerhippie
Far NE Oregon
Probably tossed it out after the second time it turned his arm into a pretzel.
If you haven't used one of these beasts before, spend some time practicing a grip that allows the pistol grip to spin out of your trigger hand (away from your thumb), instead of into it--easier to figure it out than to describe it.
Older ones, anyway, had the trigger lock on the left side of the pistol grip. If you use your left hand on the grip, it sets the lock without you knowing it. When that happens and the drill gets away from you, it'll just spin 'til it comes to the end of the cord and unplugs itself.
INSP380
Cleveland, Ohio
Good eye, the Blade is Goodell Pratt & I suspected the square head and centering head. The protractor is a B&S. I really need to dig a bit deeper, but they aren’t marked Starrett.
Steve
bmwrd0
Beaver Fever Oregon
I was supposed to head up to "the city" north of me to pick up a load of tools, but I was texted that it had sold. Small bummer, but so it goes.
Instead, I headed to the Restore, as I was in need of the fix I thought I was getting.
Two gigantic antique carpenters squares, and four sets of unused reloading dies (+ one extra shell holder)
After that I headed over to the local used bookstore, where I have a ton of credit, and picked this set up:
an 1890s edition of Stanleys travels through Africa.
INSP380
Cleveland, Ohio
Good eye, the Blade is Goodell Pratt & I suspect the square head and centering head. The protractor is a B&S. I really need to dig a bit deeper, but they aren’t marked
Steve
Here is a comparison line up… Starrett, Starrett, Union, B&S, Craftsman & Stanley. Below that a line up of 12” blades, then B&S vs Starrett Protractors, then Centering heads… Starrett Cast, Starrett Forged & B&S. Then Lufkin 6”, Starrett 6” Jr, & Machinist, Starrett 6” Machinist, Starrett 6” std…. Whew..I’m confused now… :)
ctuai
Des Moines, IA
Local machine shop online auction ($865):
A huge whack of money out the door. A 2 day auction with around 2000 items, which was also 2 hours down the road so I kind of wanted to make it worth my time. I identified around 180 items of interest. First day, got up around 7am to look at prices and they were crazy town so I didn't bother. 2nd day the prices were cheaper until they weren't, but by that point I had already bought something. You definitely sweat out whether things will work and if all the pieces are present, which I did pretty good. Tricky and expensive place to be running around in.​
($41) Micrometer: 0-4" Starrett No. 224 Set AA; 8-9" Mitutoyo 103-222A
$26 - Mitutoyo calipers 6" (500-351), Mitutoyo 8" (CD-P8); $21 - .4-.7" Takachiho cylinder bore gage set
$215 - Mahr Pocket Surf III surface roughness gage; $102 - Positector 6000 coating thickness gage.
$215 - Mahr Pocket Surf III surface roughness gage; Height stand; Reference plate; Small bore probe
$61 - Kurt 3600V 6" vise
$71 - Neo500 permanent sheet lift magnet (500lbs)
oh just to be clear, it was my wife that handed me the flyer for the auction :)
I spotted a local estate sale that looked kind of interesting but when we arrived it turned out to be put on by our absolute least favorite “fun” estate sale company. I gathered up a few tools including a decent DeWalt bit set. The woman doing the pricing dumped everything out of the bag and quoted a price that was on the high side but doable. After paying I was putting the items back in the bag to leave, she stated that she hadn’t charged for the DeWalt set and wanted $20. more. I politely suggested that she keep the set in question and we left. The worst part was it was a repeat of a scenario that had occurred a few years back. You would think that I would have learned.😢 Anyway here are the things I overpaid for. IMG_4979.jpeg
The Craftsman -v- Crown set was complete and cleaned up pretty well. IMG_4986.jpegIMG_4987.jpegIMG_4988.jpeg
Maybe I will stay away from the “Fun” Estate Sales in the future.
M.Jay
Southern Germany
That sounds interesting. I guess I now know what I'll be reading this winter.
That's a pretty shady business practice.I would have dropped everything and just demanded my money back.
They turned out beautiful! So you have atleast a really nice set of wrenches, that will ease the pain. ;)
WisJim
Menomonie, WI
I've been looking in some old hardware and tool catalogs, mostly early 1900s, and I notice that often the Goodell Pratt or Lufkin machinist tools are as expensive or more expensive than the similar Starrett or B&S items. It doesn't hold for all items, but to me it shows that there must not have been much of a perceived quality difference among them
INSP380
Cleveland, Ohio
I agree 100%….. I love them all and feel the quality is equal across the board. I am a Starrett fan, mostly because they survived. I want more GP in my collection, need more Lufkin and have been gathering B&S to complete my vintage apprentice kit. My drive is pretty high right now, excited for the next sale!!!
Steve
zanyad
NE Ohio
***** for the tools and the S-K box too!
A copper spittoon
Very cool! Good job shaping it back up!
@lowbucktruck sux for the RA drill and bits!
@ctuai some very nice ****-worthy finds at that auction, especially the Kurt vise!
You're lucky you have such an understanding wife (I do too, for the record).
Old Radar
San Antonio, TX
Okay, I've been absent for a spell and am way behind, but I read this page and @INSP380 ***** for the machinist tools and the S-K box, while @3baygarage ***** for his free cabinets.
Now lets move on to @Jacobs976.
...it's from Dupont Explosives, originally containing 50lbs of "Monobel E" Originally it had ... a ton of sticks of modeling clay(completely filled to the brim) I did not take possession of the clay. Not sure why someone would need so much modeling clay, kinda like Play-Doh, but I guess the box was convenient since it's fairly large. ...apparently there was a gas leak or something and the whole place was just gone, they haven't found the cause yet but apparently the debris field covered 3 counties.
Now, I live for subtle humor and sarcasm, so this caught my attention immediately--but no one mentioned anything. Then, a couple of posts later, you casually tossed in something about "the joke" and still no one said anything.
So I'm either completely misreading the situation or I really have to take my hat off to a true master!
ctuai
Des Moines, IA
Estate sale ($75): Traiger Pro 22 pellet smoker.
Got it only after promising to get rid of at least two if not three of my current outdoor cooking appliances. I figure I can put the whole turkey in this year rather than spatchcocking, which is how I normally do it when I use the soon to be retired Masterbuilt smoker.​
Status
