How do I fix this? - Wilton Power Hacksaw
1Bad55Chevy
A few months ago I picked up a Wilton power hacksaw at an estate sale and it works awesome! The issue i am having is with the fence to set the cut angle.
The bolt pictured has a standard washer/nut on the back side which makes it almost impossible to adjust accurately.
I assume when this thing was new they didn't intend for you to hold a ratchet on top, a wrench on the bottom, a protractor with your foot, and adjust the angle with your nose!
Is there supposed to be some type of T nut in that slot?
I measured the width of the slot to be .45".
Any help on this will be greatly appreciated!
Beerhippie
Far NE Oregon
A few months ago I picked up a Wilton power hacksaw at an estate sale and it works awesome! The issue i am having is with the fench to set the cut angle.
I'll bet you can find a carriage bolt that fits the slot.
finn
The UP, God's country
I think mine has a carriage bolt.
It’s not exactly a precision tool, though.
An angle grinder or better yet, a stationary belt sander is a wonderful accessory.
OccupantRJ
Eastern North Carolina
You can drill and tap a relatively short piece of flatbar to act as a self holding nut once it rotates and stops against the casting. I have done this often in this sort of situation.
Looks like a 7/16" carriage bolt is your salvation.
1Bad55Chevy
I am probably just going to go the carriage bolt route. I wonder if I will need to drill out the fence because thats a 3/8" bolt thats currently in it.
Beerhippie
Far NE Oregon
The square section of a 3/8" carriage bolt measures out to ~ 0.41". I'll bet that fits.
It's a carriage bolt. Buy a few and find the one that fits.
little bit of slop room there might not be a bad thing.
I bought some tool a while back where the slotted portion was very poorly cast and the bolt they supplied would not make the full Arc. So I went through and filed, but the smaller bolt is a nice touch. Looks like you want to get a ratcheting one sided hand knob for that too, eliminate the need for the wrench near the fence.
mbatarga
GA
I modified/upgraded the fence on my metal bandsaw using a t-nut from some metal clamping hardware I had. I cut and filed the t-nut a little narrower to fit into the slot underside. Also like what RTM above mentioned, I had to clean up the slotted arc as the width was not consistent along the arc. I also had to shorten and round off one end to allow the bandsaw fence to adjust all the way to 90 degrees. The fence is tightened in place with a regular bolt rather than a socket head such as yours.
