11b30b4's Vintage Classic Craftsman Drill Press Information Thread
DDOPWD23
Glen Rock, NJ
I have a question, the lock handles for the Atlas made DP. Are the lock handles the 12.5” the same length as the ones for the 15.5”? Thanks. Trying to find one for a DP. I know the table and head casting are the same length. Not like on a King Seleey where the head casting is wider than the table. I’m also referring to the Atlas ball end type handles.
Thanks!
11b30b4
GA
You will need to message FrankLee here on Garage Journal. He is the expert on the 12.5" drill press. I normally only work with the 15.5" drill presses.
FrankLee
seMI, 48317
@DDOPWD23, I'm really confused about the 12.5" size. What is the model number? Pics may help.
Anyway, Atlas had 12.75" and 15" drill presses (were there others? I dunno.).
King-Seeley had 12.25", 13.5" and 15.5" drill presses.
(The '46-'55 Craftsman catalogs say the large drill press is 15". Don't believe it, they are actually 15.5").
(K-S also had the mohawk dp. The VM Photo Index shows those in 12", 13", 13.25", 13.5", 14", 15". So who knows wtf happened there.)
Regardless, I don't have much experience with the smaller Atlas dp, but a comparison may be relevant between the Altas machines and the K-S 13.5" and 15.5" drill presses.
Because of the smaller diameter column on the 13.5" K-S dp, the lock cylinders are closer together than on a 15.5" K-S dp. Therefore, the bolt portion on the lock handles are shorter by 1/2"(?). The ball-end portion of the handles are the same on the 13.5" and the 15.5" dp.
The lock cylinders on both the the Atlas and K-S DP's are the same length and diameter (except the head lock cylinders are longer on the K-S machines.
DDOPWD23
Glen Rock, NJ
Thank you for the info, half my issue is I don’t have the proper measurements. Thank to you now I do. On the other hand it’s hard to look on eBay when items aren’t labeled correctly.
From the all it says is it came from a Craftsman 101.03581 and that it fits either the head or the table which is true. I learned that when I restored a 1942 15” they were interchangeable. I looked it up and that’s how I knew it was a 12.5”
DDOPWD23
Glen Rock, NJ
FrankLee
seMI, 48317
I was able to find a handle from a 15” Atlas so hopefully that will work as well. I hate just randomly buying things but it’s slim pickings out there. I’ll take measurements and report back what I find out. Maybe my mistakes can help someone else out.
It may be too long and the nut may bottom out on the threads, but if so, you can extend the threads with a 1/2-13 die and cut off the excess. NBD.
DDOPWD23
Glen Rock, NJ
Good idea, thank you. I believe I have that in my set but will have to double check when I return home.
11b30b4
GA
the Commercial model is great but you may still need to slow the rpms down depending on what you are drilling. There is a rare slow speed attachment for the Emerson later models. Here is a video about it.
Farmall450
Marengo, Illinois
Great video, thank you. If I get the DP, I will keep an eye out for that attachment.
11b30b4
GA
Cool, I Know someone who has the attachment and may be willing to sell it. Let me know when you are ready and I will reach out to him.
11b30b4
GA
It does, Emerson began adding the mounting point to all tables starting with the Gen 2 drill press. The tilting table does show up from time to time on ebay but the best way to get one is to buy a drill press with one on it, then resell the drill press after you remove the tilting table. This is how I got mine. I will say that I have never found a need to use the tilting table so I am not sure its worth hunting down.
Farmall450
Marengo, Illinois
Here's a cool snip of my exact model from the 82/3 tool guide.
Wish I was around to remember these catalogs back then. Neat stuff, and super concise.
11b30b4
GA
Good snag, the tilting table accessory are out there but I regularly see them sell for 150-200. I have one and have never used it. I have never found a reason to use a tilting table on any of my drill presses but I assume there was a use for them since the first 100 series had tilting tables and starting with the Emerson Gen2's the tilting table accessory was available. I see them quite often on drill presses for sale. As I said, i have not had a need to use one but if i needed to tilt my work i would likely do that with a tilting vise rather than the table. Regardless, it is a cool accessory and congrats on getting one.
Farmall450
Marengo, Illinois
I gave $50 for this one.
I recently had to drill angle iron through the "corner", so I think this would be helpful for that same exercise on square or rectangle tube.
